totow
1. Dezember 2025 um 18:32
2
Integration neu laden bzw. alles Neu starten hast du wahrscheinlich schon gemacht?
Sonnst ist das wahrscheinlich ein Fehler in der Integration, das könntest du hier melden:
bzw. würde es da schonmal gemacht und es wurde gesagt man sol das per customize ändern:
offen 09:11AM - 21 Feb 25 UTC
geschlossen 10:50AM - 21 Feb 25 UTC
### I agree to the following
- [x] I have read the [documentation](https://gith… ub.com/sukramj/custom_homematic#custom_homematic) right now
- [x] I have read the [FAQs](https://github.com/sukramj/custom_homematic#frequently-asked-questions) right now
- [x] I am aware of the latest [release notes](https://github.com/sukramj/custom_homematic/releases)
- [x] I am aware that an integration that was installed via HACS also needs to be updated via HACS
- [x] The Backend (CCU/Homegear/...) is working as expected, devices are taught in and are controllable by its own UI.
- [x] I am running the latest version of the custom_component (and Home Assistant)
### The problem
I use an HM-ES-TX-WM to measure gas consumption. It creates a system variable for totals: `svEnergyCounterGas_XXXX_XXXXXXXXXXXX:1`. It contains the consumption in m3, but there is no way in the integration to set the measurement unit to m3 or any other volume related unit, just kWh or similar energy related ones.
### What version of HomematicIP (local) has the issue?
1.81.2
### What was the last working version of HomematicIP (local)?
_No response_
### What type of installation are you running?
Home Assistant OS
### What type of installation are you running for your homematic backend?
RaspberryMatic Standalone
### Which version of your homematic backend are you running?
3.79.6
### What hardware are you running for your system?
Pi4
### Which config details do you use
- [x] TLS
- [ ] callback data ([see](https://github.com/sukramj/custom_homematic#callback_host-and-callback_port))
### Which interfaces do you use?
- [x] Homematic IP
- [x] Homematic (Bidcos-RF)
- [x] Groups (Heating-Group)
- [ ] BidCos-Wired (HM-Wired)
### Diagnostics information (no logs here)
_No response_
### Log file extract. Anything in the logs that might be useful for us? The log (Setting/System/Logs -> load full log) is the best source to support trouble shooting!
```txt
### Additional information
_No response_
Ja das geht über die Helfer z.B. mit einem Template Sensor.
Tobi
