Einbindung Sonoff Zigbee Stick mit Proxmox
Leider gelingt es mir nicht den Sonoff Stick oder conbee II mit Proxmox und Home Assistant zu installieren.
Gibt es hier eine Anleitung ?
hier das log…
`[21:16:37] INFO: Preparing to start...
[21:16:37] INFO: Socat not enabled
[21:16:37] INFO: Starting Zigbee2MQTT...
[2024-08-25 21:16:39] info: 	z2m: Logging to console, file (filename: log.log)
[2024-08-25 21:16:39] info: 	z2m: Starting Zigbee2MQTT version 1.39.1 (commit #unknown)
[2024-08-25 21:16:39] info: 	z2m: Starting zigbee-herdsman (0.55.3)
[2024-08-25 21:16:39] info: 	zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2254347-if00","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-08-25 21:16:39] info: 	zh:zstack:znp: Serialport opened
[2024-08-25 21:16:39] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-08-25 21:16:40] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-08-25 21:16:59] error: 	z2m: Error while starting zigbee-herdsman
[2024-08-25 21:16:59] error: 	z2m: Failed to start zigbee
[2024-08-25 21:16:59] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-08-25 21:16:59] error: 	z2m: Exiting...
[2024-08-25 21:16:59] error: 	z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:119:27)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:127:29)
    at Zigbee.start (/app/lib/zigbee.ts:63:27)
    at Controller.start (/app/lib/controller.ts:139:27)
    at start (/app/index.js:154:5)
[21:17:44] INFO: Preparing to start...
[21:17:44] INFO: Socat not enabled
[21:17:45] INFO: Starting Zigbee2MQTT...
[2024-08-25 21:17:46] info: 	z2m: Logging to console, file (filename: log.log)
[2024-08-25 21:17:46] info: 	z2m: Starting Zigbee2MQTT version 1.39.1 (commit #unknown)
[2024-08-25 21:17:46] info: 	z2m: Starting zigbee-herdsman (0.55.3)
[2024-08-25 21:17:46] info: 	zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2254347-if00","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-08-25 21:17:46] info: 	zh:zstack:znp: Serialport opened
[2024-08-25 21:17:47] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-08-25 21:17:48] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-08-25 21:18:06] error: 	z2m: Error while starting zigbee-herdsman
[2024-08-25 21:18:06] error: 	z2m: Failed to start zigbee
[2024-08-25 21:18:06] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-08-25 21:18:06] error: 	z2m: Exiting...
[2024-08-25 21:18:06] error: 	z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at start (/app/index.js:154:5)`
Du musst den USB-Port in Proxmox an HA übergeben. In Proxmox haos unter Hardware findest Du die Einstellung.
Das kann eigentlich nicht sein. Wenn der Stick als USB-Device unter Proxmox vorhanden und sich dort auch an die HA VM durchreichen lässt, dann sollte der bei HA auch unter Hardware auftauchen.
Ich vermute mal das Du doch irgendwo irgendeine Kleinigkeit falsch gemacht hast, aber was und wo darüber könnte ich jetzt auch nur spekulieren. :slightly_smiling_face:
Um welchen Zigbee USB Dongle geht es bei Dir überhaupt?
VG JIm
Danke, schon erledigt. Neustart hat gefehlt
Der “Klassiker” also. :laughing:
AEG
Auschalten, Einschalten, Geht :laughing:
Hallo, bei mir funktioniert es trotz Neustart nicht. Hat jemand eine Idee was sein könnte. Hier das Protokoll:
@Michl1: ich kann leider nicht sagen was es bei dir hat, aber generell ist es ratsam den Stick nicht über den allgemeinen Namen /dev/ttyUSB0 anzusprechen. Besser du nimmst das exaktere Gerät /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee… den genauen Namen musst du nachschauen.
Warum? wenn du irgendeinen zweiten Stick ansteckst der auch ein /dev/ttyUSB ist dann kann es sein dass die beiden Sticks nach einem Neustart vertauschte Nummern haben. Je nachdem was das Linux zuerst findet.
E-Dongle oder P-Dongle?
Richtiger Adapter gesetzt?
Keine ZHA Integration?
  • es funkioniert auch mit dem exakten Namen nicht
  • E-Dongle
  • wollte Z2M benutzen (ohne bestimmten Grund), wäre ZHA besser?
Dann ist der Adapter zstack aber falsch.
