Super, danke für das Feedback.. dann mache ich mal auf meiner Liste " 9/11" einen Haken dran
Fehlermeldung im Log mit 54.0.2 (HAOS noch auf 10.4)
2026-11-05 23:49:11 - custom_components.solar_forecast_ml.data.db_manager - WARNING - Database stayed locked for 35.0s across 1 attempts: database is locked
2026-11-05 23:50:48 - custom_components.solar_forecast_ml.sensors.sensor_actual_sot - WARNING - SFML actual live-state refresh deferred for 1s: database is locked
2026-11-05 23:52:01 - custom_components.solar_forecast_ml.forecast.forecast_weather - INFO - Background forecast update task cancelled
2026-11-05 23:52:06 - custom_components.solar_forecast_ml.data.db_manager - WARNING - Database stayed locked for 35.0s across 1 attempts: database is locked
2026-11-05 23:52:06 - custom_components.solar_forecast_ml.data.data_operational_forecast_handler - WARNING - Operational reforecast settings unavailable (database is locked); keeping last known settings
2026-11-05 23:52:08 - custom_components.solar_forecast_ml.data.db_manager - INFO - Database closed
2026-11-05 23:52:08 - custom_components.solar_forecast_ml.sensors.sensor_base - WARNING - Failed to load OperationalHybridForecastSensor: 'NoneType' object has no attribute 'execute'
2026-11-05 23:52:08 - custom_components.solar_forecast_ml.sensors.sensor_base - WARNING - OPS day forecast unreadable, customer view uses regular rows: 'NoneType' object has no attribute 'execute'
2026-11-05 23:52:08 - custom_components.solar_forecast_ml.sensors.sensor_base - WARNING - ConservativePlanningForecastSensor: failed to load forecast lock state: 'NoneType' object has no attribute 'execute'
2026-11-05 23:52:08 - custom_components.solar_forecast_ml.sensors.sensor_actual_sot - WARNING - SFML actual live-state refresh deferred for 2s: 'NoneType' object has no attribute 'in_transaction'
2026-11-05 23:52:08 - custom_components.solar_forecast_ml.data.data_operational_forecast_handler - WARNING - Operational reforecast settings unavailable ('NoneType' object has no attribute 'execute'); keeping last known settings
2026-11-05 23:52:08 - custom_components.solar_forecast_ml.sensors.sensor_base - WARNING - Failed to load HybridForecastStatusSensor: 'NoneType' object has no attribute 'execute'
SFML 54.0.02 - Neueinrichtung:
Die erste Gruppe wird gespeichert. Gruppe 2-4 verschwinden im Nirvana, auch nach mehrmaligem wiedereingeben.
TFS meckert dann auch, weil Gruppe 2-4 nicht bestätigt ist.
Neustart auf HA 2026.10.4
Hallo Zara, hallo zusammen,
bei mir trifft die Prognose seit Wochen den Tagesertrag praktisch nicht, und die KI ist nach über 5 Wochen immer noch in der Lernphase. Vielleicht könnt ihr einschätzen, ob das normal ist oder ob bei mir etwas nicht stimmt.
System
- Home Assistant 2026.11.0
- Solar Forecast ML V54.0.2, nur SFML (ohne STATS, EAI, GPM, S-INV)
- Standort: Nordwestmecklenburg (Ostseenähe)
- Installiert am 02.10.2026, danach Updates auf V50 (13.10.), V52 (ca. 24.10.), V52.0.4 (31.10.), V54.0.2 (05.11.)
Anlage (Enpal, Hybrid-Wechselrichter 5 kW, Speicher 8,7 kWh brutto / 7,78 kWh nutzbar)
- 16 Module, 5,4 kWp, keine Einspeisebegrenzung
- Gruppe 1: 2,7 kWp, 45°, Azimut 200°, Sensor DC-Leistung String 2
- Gruppe 2: 2,7 kWp, 25°, Azimut 200°, Sensor DC-Leistung String 1
- Wechselrichter max. 5 kW eingetragen, Speicher aktiv (SOC + Solar-zu-Batterie-Sensor)
- Pirate-Weather-Key aktiv, Wintermodus an
- Daten kommen über die Enpal-Webparser-Integration
Tageswerte Prognose / Ist
| Tag | Prognose | Ist |
| 27.10. | 16,6 | 6,9 kWh |
| 28.10. | 16,3 | 9,3 kWh |
| 30.10. | 12,0 | 2,9 kWh |
| 03.11. | 4,9 | 6,7 kWh |
| 04.11. | 12,3 | 7,9 kWh |
| 05.11. | 11,2 | 18,7 kWh |
| 06.11. | 12,4 | 1,8 kWh |
| 07.11. | 12,2 | 15,4 kWh |
| 08.11. | 11,6 | 3,6 kWh |
Auffällig
- Die Prognose liegt fast jeden Tag bei 11–14 kWh, der echte Ertrag schwankt zwischen 1,8 und 18,7 kWh. Trübe und sonnige Tage werden kaum unterschieden.
- AI Status und AI Gate Status stehen seit Beginn auf „forecast_learning“.
- System Status steht fast durchgehend auf „warning“ („The forecast is still updating. No action is required.“), nur direkt nach einem Neustart kurz „ok“.
- Ø Genauigkeit 7 Tage: 54 %.
- Anfang Oktober lag die Prognose eher zu niedrig, seit Ende Oktober meist deutlich zu hoch.
Bekannte Datenlücken
- 01.11. ab ca. 12:40: String-Sensoren versehentlich deaktiviert, abends wieder aktiv
- 02.11.: Enpal-Box nach Internetausfall mehrere Stunden offline
Fragen
- Ist es normal, dass die KI nach über 5 Wochen (mit Kalibrierungs-Neustart durch V50) noch nicht freigegeben ist?
- Woran kann es liegen, dass die Prognose kaum zwischen trüben und sonnigen Tagen unterscheidet?
- Ist der dauerhafte System Status „warning“ so gewollt?
Falls ihr weitere Daten braucht, liefere ich die gern nach.
Sorry wenn ich hier im falschen Post bin.
Vielen Dank und viele Grüße
Frank
Hallo @franksch50
Ich muss mir unbedingt deine DB und LOG ansehen um hier klare Hilfe zu geben und zu sehen was das Problem ist, ob zum Beispiel falsche Sensor-Werte in der DB gelandet sind, es ein anderes Problem gibt. Du hast PN!
Ich schaue es mir an, ob ich etwas finde das es erklären könnte. Sollte ich etwas zur Kontrolle von Dir brauchen, melde ich mich via PN.
Moin @Tom-HA , ist nicht mehr nötig.
Ich bin Deinem alten Rat befolgt und habe HA über Safari aufgerufen und nicht über die Mac HA App – jetzt geht’s.
Wollte Dir schon schreiben, dass ich keinen Fehler im Option-Flow gefunden habe!
