Bluetooth USB Stick funktioniert nicht mehr
Hallo, mein Bluetooth Stick funktioniert nicht mehr und verursacht Dauer-Logs.
Das hier zeigen die Logs vom Supervisor:
2026-09-28 19:28:32.010 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/076 - None
2026-09-28 19:28:34.379 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/077 - None
2026-09-28 19:28:42.757 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/077 - None
2026-09-28 19:28:45.126 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/078 - None
2026-09-28 19:28:53.508 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/078 - None
2026-09-28 19:28:55.877 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/079 - None
2026-09-28 19:29:04.269 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/079 - None
2026-09-28 19:29:06.634 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/080 - None
2026-09-28 19:29:15.014 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/080 - None
2026-09-28 19:29:17.377 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/081 - None
2026-09-28 19:29:25.768 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/081 - None
2026-09-28 19:29:28.133 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/082 - None
2026-09-28 19:29:36.518 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/082 - None
2026-09-28 19:29:38.880 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/083 - None
2026-09-28 19:29:47.269 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/083 - None
2026-09-28 19:29:49.632 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/084 - None
Er wird wohl auch erkannt:
Bus 001 Device 092: ID 0b05:1bef Realtek Bluetooth Controller
Modul wird wohl auch geladen laut Ausgabe:
hwinfo --bluetooth
04: USB 00.1: 11500 Bluetooth Device
  [Created at usb.124]
  Unique ID: VfjA.kWpOjjaOtT2
  Parent ID: k4bc.2DFUsyrieMD
  SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1
  SysFS BusID: 1-3:1.1
  Hardware Class: bluetooth
  Model: "ASUSTek Bluetooth Controller"
  Hotplug: USB
  Vendor: usb 0x0b05 "ASUSTek Computer, Inc."
  Device: usb 0x1bef "Bluetooth Controller"
  Driver: "btusb"
  Driver Modules: "btusb"
  Module Alias: "usb:v0B05p1BEFd0200dcE0dsc01dp01icE0isc01ip01in01"
  Config Status: cfg=new, avail=yes, need=no, active=unknown
  Attached to: #2 (Hub)
Habe auch schon den Usb-Port gewechselt, ohne Erfolg.
Gruss
