Ok hab sie jetzt noch ausfindig gemacht:
Logger: [homeassistant.components.hassio](http://homeassistant.components.hassio)
Source: helpers/[update_coordinator.py:332](http://update_coordinator.py:332)
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 13:13:58 (1 occurrences)
Last logged: 13:13:58
Error fetching hassio data: Error on Supervisor API:
Logger: homeassistant.components.hassio
Source: helpers/update_coordinator.py:332
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:235
Integration: Recorder (documentation, issues)
First occurred: 13:13:58 (3 occurrences)
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: SELECT state_attributes.attributes_id, state_attributes.shared_attrs FROM state_attributes WHERE state_attributes.hash IN (?)] [parameters: (3303323990,)] (Background on this error at: https://sqlalche.me/e/20/4xp6)
Logger: homeassistant.components.recorder.core
Source: components/recorder/core.py:912
Unrecoverable sqlite3 database corruption detected: (sqlite3.DatabaseError) database disk image is malformed [SQL: SELECT state_attributes.attributes_id, state_attributes.shared_attrs FROM state_attributes WHERE state_attributes.hash IN (?)] [parameters: (3303323990,)] (Background on this error at: https://sqlalche.me/e/20/4xp6)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1969, in _exec_single_context
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/default.py", line 922, in do_execute
sqlite3.DatabaseError: database disk image is malformed
The above exception was the direct cause of the following exception:
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 912, in _process_one_task_or_recover
File "/usr/src/homeassistant/homeassistant/components/recorder/tasks.py", line 281, in run
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1020, in _process_one_event
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1131, in _process_state_changed_event_into_session
File "/usr/src/homeassistant/homeassistant/components/recorder/table_managers/state_attributes.py", line 77, in get
File "/usr/src/homeassistant/homeassistant/components/recorder/table_managers/state_attributes.py", line 98, in get_many
File "/usr/src/homeassistant/homeassistant/components/recorder/table_managers/state_attributes.py", line 111, in _load_from_hashes
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 230, in execute_stmt_lambda_element
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1416, in execute
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/sql/lambdas.py", line 604, in _execute_on_connection
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1639, in _execute_clauseelement
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1848, in _execute_context
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1988, in _exec_single_context
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 2343, in _handle_dbapi_exception
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed
Source: components/recorder/util.py:347
The system will rename the corrupt database file //config/home-assistant_v2.db to //config/home-assistant_v2.db.corrupt.2024-01-05T12:13:58.984439+00:00 in order to allow startup to proceed
Source: components/recorder/core.py:901
Error while processing event EventTask(event=<Event state_changed[L]: entity_id=update.home_assistant_supervisor_update, old_state=<state update.home_assistant_supervisor_update=off; auto_update=True, installed_version=2023.12.0, in_progress=False, latest_version=2023.12.0, release_summary=None, release_url=https://github.com/home-assistant/supervisor/releases/tag/2023.12.0, skipped_version=None, title=Home Assistant Supervisor, entity_picture=https://brands.home-assistant.io/hassio/icon.png, friendly_name=Home Assistant Supervisor Update, supported_features=1 @ 2024-01-04T12:08:57.196383+01:00>, new_state=<state update.home_assistant_supervisor_update=unavailable; entity_picture=https://brands.home-assistant.io/hassio/icon.png, friendly_name=Home Assistant Supervisor Update, supported_features=1 @ 2024-01-05T13:13:58.713850+01:00>>): [Errno 30] Read-only file system: '//config/home-assistant_v2.db' -> '//config/home-assistant_v2.db.corrupt.2024-01-05T12:13:58.984439+00:00'
During handling of the above exception, another exception occurred:
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 901, in _guarded_process_one_task_or_recover
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 914, in _process_one_task_or_recover
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1152, in _handle_database_error
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1208, in _handle_sqlite_corruption
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 360, in move_away_broken_database
OSError: [Errno 30] Read-only file system: '//config/home-assistant_v2.db' -> '//config/home-assistant_v2.db.corrupt.2024-01-05T12:13:58.984439+00:00'
