Hi, mir ist gerade beim stöbern im MQTT Explorer aufgefallen dass 2 Geräte (Stecker mit Strommessung) ununterbrochen Nachrichten Senden, mehrere die Sekunde…
Im Tab “Berichte” bei Z2M sehe ich nichts ungewöhnliches…
Hier ein auszug aus dem Z2M Log:
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Stecker Pool Pumpe', payload '{"child_lock":"UNLOCK","countdown":0,"current":2.06,"energy":374.7,"indicator_mode":"off/on","last_seen":"2024-10-24T07:04:19.857Z","linkquality":45,"power":255,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":235}'
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Switch Kühlschrank Gartenhaus', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"energy":49.23,"indicator_mode":"off","last_seen":"2024-10-24T07:04:19.921Z","linkquality":45,"power":0,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":235}'
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Pool Pumpe Sswitch', payload '{"backlight_mode":"OFF","last_seen":"2024-10-24T07:04:19.998Z","linkquality":45,"power_on_behavior_l1":"previous","power_on_behavior_l2":"previous","power_on_behavior_l3":"previous","power_on_behavior_l4":"previous","state_l1":"OFF","state_l2":"ON","state_l3":"OFF","state_l4":"OFF"}'
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Stecker Pool Pumpe', payload '{"child_lock":"UNLOCK","countdown":0,"current":2.06,"energy":374.7,"indicator_mode":"off/on","last_seen":"2024-10-24T07:04:20.057Z","linkquality":45,"power":255,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":235}'
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Switch Kühlschrank Gartenhaus', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"energy":49.23,"indicator_mode":"off","last_seen":"2024-10-24T07:04:20.121Z","linkquality":45,"power":0,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":235}'
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Pool Pumpe Sswitch', payload '{"backlight_mode":"OFF","last_seen":"2024-10-24T07:04:20.214Z","linkquality":48,"power_on_behavior_l1":"previous","power_on_behavior_l2":"previous","power_on_behavior_l3":"previous","power_on_behavior_l4":"previous","state_l1":"OFF","state_l2":"ON","state_l3":"OFF","state_l4":"OFF"}'
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Sicherung BKW', payload '{"current":0.23,"energy":604.21,"indicator_mode":"off/on","last_seen":"2024-10-24T07:04:20.229Z","linkquality":84,"over_current_breaker":"ON","over_current_threshold":16,"over_voltage_breaker":"ON","over_voltage_threshold":265,"power":29,"power_breaker":"ON","power_outage_memory":"on","power_threshold":4,"state":"ON","temperature":22.44,"temperature_breaker":"ON","temperature_threshold":100,"under_voltage_breaker":"ON","under_voltage_threshold":75,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":235}'
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Stecker Pool Pumpe', payload '{"child_lock":"UNLOCK","countdown":0,"current":2.06,"energy":374.7,"indicator_mode":"off/on","last_seen":"2024-10-24T07:04:20.258Z","linkquality":48,"power":255,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":235}'
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Switch Kühlschrank Gartenhaus', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"energy":49.23,"indicator_mode":"off","last_seen":"2024-10-24T07:04:20.322Z","linkquality":45,"power":0,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":235}'
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Pool Pumpe Sswitch', payload '{"backlight_mode":"OFF","last_seen":"2024-10-24T07:04:20.410Z","linkquality":45,"power_on_behavior_l1":"previous","power_on_behavior_l2":"previous","power_on_behavior_l3":"previous","power_on_behavior_l4":"previous","state_l1":"OFF","state_l2":"ON","state_l3":"OFF","state_l4":"OFF"}'
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Stecker Pool Pumpe', payload '{"child_lock":"UNLOCK","countdown":0,"current":2.06,"energy":374.7,"indicator_mode":"off/on","last_seen":"2024-10-24T07:04:20.459Z","linkquality":45,"power":255,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":235}'
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Switch Kühlschrank Gartenhaus', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"energy":49.23,"indicator_mode":"off","last_seen":"2024-10-24T07:04:20.527Z","linkquality":45,"power":0,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":235}'
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Pool Pumpe Sswitch', payload '{"backlight_mode":"OFF","last_seen":"2024-10-24T07:04:20.600Z","linkquality":45,"power_on_behavior_l1":"previous","power_on_behavior_l2":"previous","power_on_behavior_l3":"previous","power_on_behavior_l4":"previous","state_l1":"OFF","state_l2":"ON","state_l3":"OFF","state_l4":"OFF"}'
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Stecker Pool Pumpe', payload '{"child_lock":"UNLOCK","countdown":0,"current":2.06,"energy":374.7,"indicator_mode":"off/on","last_seen":"2024-10-24T07:04:20.660Z","linkquality":45,"power":255,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":235}'
info 2024-10-24 09:04:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Switch Kühlschrank Gartenhaus', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"energy":49.23,"indicator_mode":"off","last_seen":"2024-10-24T07:04:20.728Z","linkquality":48,"power":0,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":235}'
info 2024-10-24 09:04:21z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Pool Pumpe Sswitch', payload '{"backlight_mode":"OFF","last_seen":"2024-10-24T07:04:20.807Z","linkquality":45,"power_on_behavior_l1":"previous","power_on_behavior_l2":"previous","power_on_behavior_l3":"previous","power_on_behavior_l4":"previous","state_l1":"OFF","state_l2":"ON","state_l3":"OFF","state_l4":"OFF"}'
Alles das in einer Sekunde… Es sind die Geräte “Stecker Pool Pumpe” und “Switch Kühlschrank Gartenhaus”.
Kennt ihr dieses Verhalten auch? Woran kann das liegen/was kann ich dagegen tun?
Andere Stecker vom gleichen Typ habe ich problemlos im Einsatz.
