Moin Leute,
mein Zigbee2MQTT meldet alle paar Tage alle geräte als Offline und laut log nicht pingbar ![]()
[2025-01-11 12:58:43] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Pflanze 1', payload '{"battery":42,"battery_state":"medium","linkquality":40,"soil_moisture":97,"temperature":20.8,"temperature_unit":"fahrenheit"}'
[2025-01-11 12:58:43] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Thermostat Bad', payload '{"battery":97,"humidity":36.58,"linkquality":123,"power_outage_count":19,"pressure":982.2,"temperature":20.94,"voltage":2995}'
[2025-01-11 13:00:14] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Cube Kai', payload '{"action":null,"action_angle":null,"action_from_side":null,"action_side":null,"action_to_side":null,"battery":97,"current":0,"device_temperature":19,"linkquality":142,"power":3,"power_outage_count":221,"side":0,"voltage":2995}'
[2025-01-11 13:00:32] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Pflanze 3', payload '{"battery":50,"battery_state":"high","linkquality":123,"soil_moisture":63,"temperature":25,"temperature_unit":"celsius"}'
[2025-01-11 13:05:01] warning: z2m: Failed to ping 'Repeater Abstellkammer' (attempt 1/2, ZCL command 0xb4e3f9fffe6c431b/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms))
[2025-01-11 13:05:10] warning: z2m: Failed to ping 'Repeater Abstellkammer' (attempt 2/2, ZCL command 0xb4e3f9fffe6c431b/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms))
[2025-01-11 13:05:10] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Repeater Abstellkammer/availability', payload '{"state":"offline"}'
[2025-01-11 13:12:12] warning: z2m: Failed to ping 'Steckdose Schlafzimmer Werner' (attempt 1/2, ZCL command 0x7cb03eaa0a084d8d/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms))
[2025-01-11 13:12:21] warning: z2m: Failed to ping 'Steckdose Schlafzimmer Werner' (attempt 2/2, ZCL command 0x7cb03eaa0a084d8d/3 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms))
[2025-01-11 13:12:21] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Steckdose Schlafzimmer Werner/availability', payload '{"state":"offline"}'
[2025-01-11 13:12:48] warning: z2m: Failed to ping 'Licht Schlafzimmer Kai' (attempt 1/2, ZCL command 0x9035eafffeb44dd6/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms))
[2025-01-11 13:12:57] warning: z2m: Failed to ping 'Licht Schlafzimmer Kai' (attempt 2/2, ZCL command 0x9035eafffeb44dd6/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms))
[2025-01-11 13:12:57] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Licht Schlafzimmer Kai/availability', payload '{"state":"offline"}'
[2025-01-11 13:15:28] warning: z2m: Failed to ping 'Steckdose Flur' (attempt 1/2, ZCL command 0x54ef4410004ebc4a/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms))
[2025-01-11 13:15:37] warning: z2m: Failed to ping 'Steckdose Flur' (attempt 2/2, ZCL command 0x54ef4410004ebc4a/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms))
[2025-01-11 13:15:37] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Steckdose Flur/availability', payload '{"state":"offline"}'
Nach neustart des Addons Funktioniert es wieder für einige Tage und dann wiederholt es sich.
In anderen Logs schaut alles Gut aus und aus den Zigbee2MQTT Lese ich nur raus das sie nicht Pingbar sind. Überlese ich was oder verstehe ich davon was falsch?
Schonmal danke
