Wetter Entität Openweather.condition wird nicht erkannt
Hey Freunde,
Meine Automation funktioniert soweit, zumindest das ausfahren wenn es sonnig ist oder partlycloudy.
Allerdings fährt sie nicht mehr ein wenn es cloudy ist… Woran kann das liegen ich weis nicht mehr weiter… wie kann man das am besten lösen. Ich will das die Markise sicher einfährt wenn es regnet oder bewölkt ist…
LG Michi
[{"id":"fc898b125c16389f","type":"tab","label":"Markise","disabled":false,"info":"","env":[]},{"id":"df80fdbc3cb12549","type":"server-state-changed","z":"fc898b125c16389f","name":"Azimuth ist 115Grad","server":"60e063e9.e56e0c","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.sun_solar_azimuth","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"115","halt_if_type":"num","halt_if_compare":"gte","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":130,"y":120,"wires":[["a0137b770efd4681"],[]]},{"id":"a0137b770efd4681","type":"api-current-state","z":"fc898b125c16389f","name":"Temperatur über 22Grad","server":"60e063e9.e56e0c","version":3,"outputs":2,"halt_if":"22","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.sonoff_snzb_02_1_temperature","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":390,"y":120,"wires":[["d74b16aac2055cde","822377f4859d8f36"],[]]},{"id":"822377f4859d8f36","type":"api-current-state","z":"fc898b125c16389f","name":"wird es sonnig?","server":"60e063e9.e56e0c","version":3,"outputs":2,"halt_if":"sunny","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.openweathermap_condition","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":660,"y":60,"wires":[["266972065666fc1d"],[]]},{"id":"d74b16aac2055cde","type":"api-current-state","z":"fc898b125c16389f","name":"wird es teilweise bedeckt?","server":"60e063e9.e56e0c","version":3,"outputs":2,"halt_if":"partlycloudy","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.openweathermap_condition","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":670,"y":200,"wires":[["266972065666fc1d"],[]]},{"id":"0f344a891c936370","type":"api-call-service","z":"fc898b125c16389f","name":"Markise ausfahren","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.fernbedienung_markise_tasmota"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1150,"y":200,"wires":[["41021588aad8d68c","452947f1e03e3587","6112e0b140c2719c","d02a1013b112afaf"]]},{"id":"41021588aad8d68c","type":"delay","z":"fc898b125c16389f","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1440,"y":60,"wires":[["25ba0d4e2ae31670"]]},{"id":"25ba0d4e2ae31670","type":"api-call-service","z":"fc898b125c16389f","name":"Relay ausschalten","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":["12dd0d7ad1ffb6cb8e5299262d33f824"],"entityId":["switch.fernbedienung_markise_tasmota"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1650,"y":60,"wires":[[]]},{"id":"b7dea9dd7c876a9b","type":"comment","z":"fc898b125c16389f","name":"abends sicher einfahren","info":"","x":140,"y":960,"wires":[]},{"id":"d02a1013b112afaf","type":"api-call-service","z":"fc898b125c16389f","name":"Iphone benachrichtigen","server":"60e063e9.e56e0c","version":5,"debugenabled":true,"domain":"notify","service":"mobile_app_iphone_vo_irgendoam","areaId":[],"deviceId":[],"entityId":[],"data":"{\t\"message\": \"wird ausgefahren...\",\t\"title\": \"Markise\"\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":1510,"y":280,"wires":[[]]},{"id":"452947f1e03e3587","type":"api-call-service","z":"fc898b125c16389f","name":"Hilfsbutton Markise ausgefahren auf ON","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.markise_ausgefahren"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1580,"y":160,"wires":[[]]},{"id":"6112e0b140c2719c","type":"api-call-service","z":"fc898b125c16389f","name":"Hilfsbutton Markise eingefahren auf OFF","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.markise_eingefahren"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1560,"y":220,"wires":[[]]},{"id":"266972065666fc1d","type":"api-current-state","z":"fc898b125c16389f","name":"Markise schon ausgefahren?","server":"60e063e9.e56e0c","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.markise_ausgefahren","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":920,"y":140,"wires":[["0f344a891c936370"],[]]},{"id":"4701f884266f414f","type":"api-call-service","z":"fc898b125c16389f","name":"Iphone benachrichtigen","server":"60e063e9.e56e0c","version":5,"debugenabled":true,"domain":"notify","service":"mobile_app_iphone_vo_irgendoam","areaId":[],"deviceId":[],"entityId":[],"data":"{\t\"message\": \"wird eingefahren...\",\t\"title\": \"Markise\"\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":1030,"y":660,"wires":[[]]},{"id":"f2457858bf567f62","type":"api-call-service","z":"fc898b125c16389f","name":"Hilfsbutton Markise eingefahren auf ON","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.markise_eingefahren"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1080,"y":600,"wires":[[]]},{"id":"ca878374f4d29a53","type":"api-call-service","z":"fc898b125c16389f","name":"Relay ausschalten","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":["12dd0d7ad1ffb6cb8e5299262d33f824"],"entityId":["switch.fernbedienung_markise_tasmota"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1210,"y":480,"wires":[[]]},{"id":"60541626049c0bf1","type":"delay","z":"fc898b125c16389f","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1000,"y":480,"wires":[["ca878374f4d29a53"]]},{"id":"5838b0cf40879970","type":"api-call-service","z":"fc898b125c16389f","name":"Markise einfahren","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.fernbedienung_markise_tasmota2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":710,"y":580,"wires":[["60541626049c0bf1","ade3018e1ee396c1","f2457858bf567f62","4701f884266f414f"]]},{"id":"ade3018e1ee396c1","type":"api-call-service","z":"fc898b125c16389f","name":"Hilfsbutton Markise ausgefahren auf OFF","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.markise_ausgefahren"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1080,"y":540,"wires":[[]]},{"id":"1580e991e86c6ffb","type":"api-current-state","z":"fc898b125c16389f","name":"Markise schon eingefahren","server":"60e063e9.e56e0c","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.markise_eingefahren","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":440,"y":600,"wires":[["5838b0cf40879970"],[]]},{"id":"ca05b8c6745b3727","type":"server-state-changed","z":"fc898b125c16389f","name":"Azimuth ist 250Grad","server":"60e063e9.e56e0c","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.sun_solar_azimuth","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"250","halt_if_type":"num","halt_if_compare":"gte","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":130,"y":540,"wires":[["1580e991e86c6ffb"],[]]},{"id":"07b47a4a3663d781","type":"comment","z":"fc898b125c16389f","name":"Markise ausfahren","info":"","x":130,"y":40,"wires":[]},{"id":"12d538591466d1f3","type":"comment","z":"fc898b125c16389f","name":"Markise einfahren","info":"","x":130,"y":460,"wires":[]},{"id":"52d62c574687caaf","type":"api-call-service","z":"fc898b125c16389f","name":"Iphone benachrichtigen","server":"60e063e9.e56e0c","version":5,"debugenabled":true,"domain":"notify","service":"mobile_app_iphone_vo_irgendoam","areaId":[],"deviceId":[],"entityId":[],"data":"{\t\"message\": \"wird eingefahren... weil 19Uhr ist.\",\t\"title\": \"Markise\"\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":950,"y":1100,"wires":[[]]},{"id":"f2733668e25ff0e0","type":"api-call-service","z":"fc898b125c16389f","name":"Hilfsbutton Markise eingefahren auf ON","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.markise_eingefahren"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1000,"y":1040,"wires":[[]]},{"id":"bf4670128a6b3368","type":"delay","z":"fc898b125c16389f","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":920,"y":920,"wires":[["f416823f145baf14"]]},{"id":"f3153e42e12c3582","type":"api-call-service","z":"fc898b125c16389f","name":"Markise einfahren","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.fernbedienung_markise_tasmota2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":650,"y":1020,"wires":[["bf4670128a6b3368","a3faf3d052002445","f2733668e25ff0e0","52d62c574687caaf","a709e214873ba0a7"]]},{"id":"a3faf3d052002445","type":"api-call-service","z":"fc898b125c16389f","name":"Hilfsbutton Markise ausgefahren auf OFF","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.markise_ausgefahren"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1000,"y":980,"wires":[[]]},{"id":"82e2fdba8ff831e8","type":"api-current-state","z":"fc898b125c16389f","name":"Markise schon eingefahren","server":"60e063e9.e56e0c","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.markise_eingefahren","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":380,"y":1040,"wires":[["f3153e42e12c3582"],[]]},{"id":"1f19d7efe5a1cda2","type":"inject","z":"fc898b125c16389f","name":"18 Uhr täglich","props":[{"p":"payload"}],"repeat":"","crontab":"00 18 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":1040,"wires":[["82e2fdba8ff831e8"]]},{"id":"f416823f145baf14","type":"api-call-service","z":"fc898b125c16389f","name":"Relay ausfahren ausschalten","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":["12dd0d7ad1ffb6cb8e5299262d33f824"],"entityId":["switch.fernbedienung_markise_tasmota"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1160,"y":920,"wires":[[]]},{"id":"a709e214873ba0a7","type":"api-call-service","z":"fc898b125c16389f","name":"Relay Markise einfahren ausschalten","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":["12dd0d7ad1ffb6cb8e5299262d33f824"],"entityId":["switch.fernbedienung_markise_tasmota2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":990,"y":1180,"wires":[[]]},{"id":"8b213254.19585","type":"server-state-changed","z":"fc898b125c16389f","name":"wenn´s regnet","server":"9405c3fe.d0a6c","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":["sensor.openweathermap_condition"],"entityidfiltertype":"list","outputinitially":false,"state_type":"str","haltifstate":"rainy","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":110,"y":660,"wires":[["1580e991e86c6ffb"],[]]},{"id":"3105becfcdaa94d1","type":"server-state-changed","z":"fc898b125c16389f","name":"wenn bewölkt","server":"9405c3fe.d0a6c","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":["sensor.openweathermap_condition"],"entityidfiltertype":"list","outputinitially":false,"state_type":"str","haltifstate":"cloudy","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":110,"y":720,"wires":[["1580e991e86c6ffb"],[]]},{"id":"60e063e9.e56e0c","type":"server","name":"Home Assistant","addon":true},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","addon":true}]tippe oder füge den Code hier ein
zeig doch mal deine Automation oder ist das deine Automation?
Ist das ein NodeRED Flow?
Ein Paar Infos können nicht schaden, wir wollen ja helfen aber nicht rumraten. :sweat_smile:
Tobi
Moinsens,
das wird ein NodeRed Flow wenn man am Ende das hier
löscht.
Eine Automation für eine Markise nach Openweather.condition halte ich für nicht empfehlenswert da die Aussagen von dort für den eigenen Standort zu ungenau sind.
Grüße
LL
Servus @LuckyLuke du schon wieder :stuck_out_tongue:
danke das du mir immer hilfst!
Was für eine Condition würdest du dann empfehlen? Ich habe auch schon gemerkt das es nur alle 10 Minuten akutalisiert…
Bis dahin ist meine Markise nass wenn´s regnen anfängt… :smiley:
Wie würdest du das Problem lösen? LG Michi
Hier mal mein aktuellstes Dingens. Was wie wo würdest du es verbessern und wenn du Lust hast kannst du mir ja die verbesserte Node schicken :stuck_out_tongue:
[{"id":"fc898b125c16389f","type":"tab","label":"Markise","disabled":false,"info":"","env":[]},{"id":"a0137b770efd4681","type":"api-current-state","z":"fc898b125c16389f","name":"Temperatur über 22Grad","server":"60e063e9.e56e0c","version":3,"outputs":2,"halt_if":"22","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.sonoff_snzb_02_1_temperature","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":370,"y":120,"wires":[["d74b16aac2055cde","822377f4859d8f36"],[]]},{"id":"822377f4859d8f36","type":"api-current-state","z":"fc898b125c16389f","name":"wird es sonnig?","server":"60e063e9.e56e0c","version":3,"outputs":2,"halt_if":"sunny","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.openweathermap_condition","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":640,"y":60,"wires":[["266972065666fc1d"],[]]},{"id":"d74b16aac2055cde","type":"api-current-state","z":"fc898b125c16389f","name":"wird es teilweise bedeckt?","server":"60e063e9.e56e0c","version":3,"outputs":2,"halt_if":"partlycloudy","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.openweathermap_condition","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":650,"y":180,"wires":[["266972065666fc1d"],[]]},{"id":"0f344a891c936370","type":"api-call-service","z":"fc898b125c16389f","name":"Markise ausfahren","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.fernbedienung_markise_tasmota"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1150,"y":220,"wires":[["41021588aad8d68c","452947f1e03e3587","6112e0b140c2719c","d02a1013b112afaf"]]},{"id":"41021588aad8d68c","type":"delay","z":"fc898b125c16389f","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1480,"y":80,"wires":[["25ba0d4e2ae31670"]]},{"id":"25ba0d4e2ae31670","type":"api-call-service","z":"fc898b125c16389f","name":"Relay ausschalten","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":["12dd0d7ad1ffb6cb8e5299262d33f824"],"entityId":["switch.fernbedienung_markise_tasmota"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1690,"y":80,"wires":[[]]},{"id":"b7dea9dd7c876a9b","type":"comment","z":"fc898b125c16389f","name":"abends sicher einfahren","info":"","x":140,"y":960,"wires":[]},{"id":"d02a1013b112afaf","type":"api-call-service","z":"fc898b125c16389f","name":"Iphone benachrichtigen","server":"60e063e9.e56e0c","version":5,"debugenabled":true,"domain":"notify","service":"mobile_app_iphone_vo_irgendoam","areaId":[],"deviceId":[],"entityId":[],"data":"{\t\"message\": \"wird ausgefahren...\",\t\"title\": \"Markise\"\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":1490,"y":280,"wires":[[]]},{"id":"452947f1e03e3587","type":"api-call-service","z":"fc898b125c16389f","name":"Hilfsbutton Markise ausgefahren auf ON","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.markise_ausgefahren"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1580,"y":160,"wires":[[]]},{"id":"6112e0b140c2719c","type":"api-call-service","z":"fc898b125c16389f","name":"Hilfsbutton Markise eingefahren auf OFF","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.markise_eingefahren"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1560,"y":220,"wires":[[]]},{"id":"266972065666fc1d","type":"api-current-state","z":"fc898b125c16389f","name":"Markise schon ausgefahren?","server":"60e063e9.e56e0c","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.markise_ausgefahren","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":920,"y":120,"wires":[["0f344a891c936370"],[]]},{"id":"4701f884266f414f","type":"api-call-service","z":"fc898b125c16389f","name":"Iphone benachrichtigen","server":"60e063e9.e56e0c","version":5,"debugenabled":true,"domain":"notify","service":"mobile_app_iphone_vo_irgendoam","areaId":[],"deviceId":[],"entityId":[],"data":"{\t\"message\": \"wird eingefahren...\",\t\"title\": \"Markise\"\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":1030,"y":660,"wires":[[]]},{"id":"f2457858bf567f62","type":"api-call-service","z":"fc898b125c16389f","name":"Hilfsbutton Markise eingefahren auf ON","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.markise_eingefahren"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1080,"y":600,"wires":[[]]},{"id":"ca878374f4d29a53","type":"api-call-service","z":"fc898b125c16389f","name":"Relay ausschalten","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":["12dd0d7ad1ffb6cb8e5299262d33f824"],"entityId":["switch.fernbedienung_markise_tasmota"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1210,"y":480,"wires":[[]]},{"id":"60541626049c0bf1","type":"delay","z":"fc898b125c16389f","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1000,"y":480,"wires":[["ca878374f4d29a53"]]},{"id":"5838b0cf40879970","type":"api-call-service","z":"fc898b125c16389f","name":"Markise einfahren","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.fernbedienung_markise_tasmota2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":730,"y":640,"wires":[["60541626049c0bf1","ade3018e1ee396c1","f2457858bf567f62","4701f884266f414f"]]},{"id":"ade3018e1ee396c1","type":"api-call-service","z":"fc898b125c16389f","name":"Hilfsbutton Markise ausgefahren auf OFF","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.markise_ausgefahren"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1080,"y":540,"wires":[[]]},{"id":"1580e991e86c6ffb","type":"api-current-state","z":"fc898b125c16389f","name":"Markise schon eingefahren","server":"60e063e9.e56e0c","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.markise_eingefahren","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":500,"y":540,"wires":[["5838b0cf40879970"],[]]},{"id":"ca05b8c6745b3727","type":"server-state-changed","z":"fc898b125c16389f","name":"Azimuth ist 250Grad","server":"60e063e9.e56e0c","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.sun_solar_azimuth","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"250","halt_if_type":"num","halt_if_compare":"gte","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":130,"y":560,"wires":[["1580e991e86c6ffb"],[]]},{"id":"07b47a4a3663d781","type":"comment","z":"fc898b125c16389f","name":"Markise ausfahren","info":"","x":130,"y":40,"wires":[]},{"id":"12d538591466d1f3","type":"comment","z":"fc898b125c16389f","name":"Markise einfahren","info":"","x":130,"y":460,"wires":[]},{"id":"52d62c574687caaf","type":"api-call-service","z":"fc898b125c16389f","name":"Iphone benachrichtigen","server":"60e063e9.e56e0c","version":5,"debugenabled":true,"domain":"notify","service":"mobile_app_iphone_vo_irgendoam","areaId":[],"deviceId":[],"entityId":[],"data":"{\t\"message\": \"wird eingefahren... weil 19Uhr ist.\",\t\"title\": \"Markise\"\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":950,"y":1100,"wires":[[]]},{"id":"f2733668e25ff0e0","type":"api-call-service","z":"fc898b125c16389f","name":"Hilfsbutton Markise eingefahren auf ON","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.markise_eingefahren"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1000,"y":1040,"wires":[[]]},{"id":"bf4670128a6b3368","type":"delay","z":"fc898b125c16389f","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":920,"y":920,"wires":[["f416823f145baf14"]]},{"id":"f3153e42e12c3582","type":"api-call-service","z":"fc898b125c16389f","name":"Markise einfahren","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.fernbedienung_markise_tasmota2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":650,"y":1020,"wires":[["bf4670128a6b3368","a3faf3d052002445","f2733668e25ff0e0","52d62c574687caaf","a709e214873ba0a7"]]},{"id":"a3faf3d052002445","type":"api-call-service","z":"fc898b125c16389f","name":"Hilfsbutton Markise ausgefahren auf OFF","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.markise_ausgefahren"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1000,"y":980,"wires":[[]]},{"id":"82e2fdba8ff831e8","type":"api-current-state","z":"fc898b125c16389f","name":"Markise schon eingefahren","server":"60e063e9.e56e0c","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.markise_eingefahren","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":380,"y":1040,"wires":[["f3153e42e12c3582"],[]]},{"id":"1f19d7efe5a1cda2","type":"inject","z":"fc898b125c16389f","name":"18 Uhr täglich","props":[{"p":"payload"}],"repeat":"","crontab":"00 18 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":1040,"wires":[["82e2fdba8ff831e8"]]},{"id":"f416823f145baf14","type":"api-call-service","z":"fc898b125c16389f","name":"Relay ausfahren ausschalten","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":["12dd0d7ad1ffb6cb8e5299262d33f824"],"entityId":["switch.fernbedienung_markise_tasmota"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1160,"y":920,"wires":[[]]},{"id":"a709e214873ba0a7","type":"api-call-service","z":"fc898b125c16389f","name":"Relay Markise einfahren ausschalten","server":"60e063e9.e56e0c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":["12dd0d7ad1ffb6cb8e5299262d33f824"],"entityId":["switch.fernbedienung_markise_tasmota2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":990,"y":1180,"wires":[[]]},{"id":"03fe47bf8f65424f","type":"trigger-state","z":"fc898b125c16389f","name":"Azimuth zw. 115-249","server":"5a3777c7.b71588","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"sensor.sun_solar_azimuth","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":">=","comparatorValueDatatype":"num","comparatorValue":"115"},{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"<=","comparatorValueDatatype":"str","comparatorValue":"249"}],"inputs":0,"outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"num","enableInput":false,"x":120,"y":120,"wires":[["a0137b770efd4681"],[]]},{"id":"4a623eea67464a9d","type":"server-state-changed","z":"fc898b125c16389f","name":"Regen?","server":"60e063e9.e56e0c","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.openweathermap_rain","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"0.1","halt_if_type":"num","halt_if_compare":"gt","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":90,"y":620,"wires":[["1580e991e86c6ffb"],[]]},{"id":"32af55c3575027dc","type":"server-state-changed","z":"fc898b125c16389f","name":"kein Regen aber bewölkt?","server":"60e063e9.e56e0c","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.openweathermap_rain","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"0.1","halt_if_type":"num","halt_if_compare":"gte","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":150,"y":680,"wires":[[],["a2703636ac0505f8"]]},{"id":"a2703636ac0505f8","type":"api-current-state","z":"fc898b125c16389f","name":"wird es bewölkt","server":"60e063e9.e56e0c","version":3,"outputs":2,"halt_if":"cloudy","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.openweathermap_condition","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":400,"y":640,"wires":[["1580e991e86c6ffb","8d20dbef4552d166"],[]]},{"id":"8d20dbef4552d166","type":"api-call-service","z":"fc898b125c16389f","name":"Iphone benachrichtigen","server":"60e063e9.e56e0c","version":5,"debugenabled":true,"domain":"notify","service":"mobile_app_iphone_vo_irgendoam","areaId":[],"deviceId":[],"entityId":[],"data":"{\t\"message\": \"wegen Bewölkung einfahren...\",\t\"title\": \"Markise\"\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":450,"y":720,"wires":[[]]},{"id":"60e063e9.e56e0c","type":"server","name":"Home Assistant","addon":true},{"id":"5a3777c7.b71588","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
Genau, ich schon wieder :wink:
Selber habe ich keine Markisen oder ähnliches was wetterabhängig gesteuert werden kann aber wenn dann würde ich nicht nur auf den Regen sondern auch auf den Wind achten. Auch würde ich mir eine eigene Sensorik aufbauen auf deren Basis die Automation läuft. Hier mal ein paar Bastel-Anregungen die ich für sinnig halte (habe allerdings nur was für Regen gefunden):
Smarterkram - ZigBee Regensensor mit Xiaomi/Aqara Türsensor
CoHoB - NodeRED: wetterabhängige Markisensteuerung
Es gibt sicherlich auch einige fertige Module für Home Assistant aber da kenne ich mich nicht aus.
Hier noch ein Online Dienst bzgl. Regen der offensichtlich recht schnell und genau ist:
ajfriesen - Rain Warning Sensor with Home Assistant
Grüße
LL
