ich bin neu hier und grade von io.Broker auf HA umgestigen und habe noch nicht alles verstanden. Zum Beispiel die sachen in Node Red. Das ist alles anders als bei io.broker.
mein Flow läuft nicht und ich habe keine Ahnung warm. Wenn ich es mit einem Injekt teste, klappt das. Mit der Entity nicht.
Flow:
[{"id":"be377dc9f59e5a66","type":"poll-state","z":"8154e55cf41edf85","name":"Abs. Feuchte Außen","server":"3b5fcaf1.e65276","version":3,"exposeAsEntityConfig":"","updateInterval":"2","updateIntervalType":"num","updateIntervalUnits":"seconds","outputInitially":false,"outputOnChanged":false,"entityId":"sensor.thermal_comfort_aussen_absolute_luftfeuchtigkeit","stateType":"num","ifState":"","ifStateType":"str","ifStateOperator":"is","outputs":1,"outputProperties":[{"property":"aussen","propertyType":"msg","value":"","valueType":"entityState"}],"x":290,"y":280,"wires":[["e2796af237bf5f6b"]]},{"id":"7765ea814d805895","type":"poll-state","z":"8154e55cf41edf85","name":"Abs. Feuchte Oben","server":"3b5fcaf1.e65276","version":3,"exposeAsEntityConfig":"","updateInterval":"2","updateIntervalType":"num","updateIntervalUnits":"seconds","outputInitially":false,"outputOnChanged":false,"entityId":"sensor.thermal_comfort_oben_absolute_luftfeuchtigkeit","stateType":"num","ifState":"","ifStateType":"entity","ifStateOperator":"is","outputs":1,"outputProperties":[{"property":"innen","propertyType":"msg","value":"","valueType":"entityState"}],"x":290,"y":200,"wires":[["e2796af237bf5f6b"]]},{"id":"821d630fe85f5f60","type":"switch","z":"8154e55cf41edf85","name":"","property":"innen","propertyType":"msg","rules":[{"t":"gt","v":"aussen","vt":"msg"},{"t":"lt","v":"aussen","vt":"msg"}],"checkall":"true","repair":false,"outputs":2,"x":650,"y":240,"wires":[["4c8b1268556ea10f"],["342e7d15f10530eb"]]},{"id":"4c8b1268556ea10f","type":"api-call-service","z":"8154e55cf41edf85","name":"","server":"3b5fcaf1.e65276","version":5,"debugenabled":false,"domain":"homeassistant","service":"turn_on","areaId":["wohnzimmer_oben"],"deviceId":[],"entityId":["input_boolean.luften_wohnzimmer_oben"],"data":"true","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","x":900,"y":220,"wires":[[]]},{"id":"342e7d15f10530eb","type":"api-call-service","z":"8154e55cf41edf85","name":"","server":"3b5fcaf1.e65276","version":5,"debugenabled":false,"domain":"homeassistant","service":"turn_off","areaId":["wohnzimmer_oben"],"deviceId":[],"entityId":["input_boolean.luften_wohnzimmer_oben"],"data":"true","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","x":900,"y":280,"wires":[[]]},{"id":"e2796af237bf5f6b","type":"junction","z":"8154e55cf41edf85","x":560,"y":240,"wires":[["821d630fe85f5f60"]]},{"id":"3b5fcaf1.e65276","type":"server","name":"Home Assistant","addon":true}]
