Moin Phasenkasper,
ich habe einen Switch gelöscht und eine current state node dazwischen gesetzt die den Schaltzustand prüft und 10 Sek. wartet bevor geschaltet wird.
[{"id":"c9a45c5fa0f63278","type":"tab","label":"Heizung Esszimmer","disabled":true,"info":"","env":[]},{"id":"8efb8e698227df64","type":"switch","z":"c9a45c5fa0f63278","name":"Heizung Ein- Ausschalten <= -1800W / >-200","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"-1800","vt":"str"},{"t":"gt","v":"-200","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":220,"wires":[["aa282a57fe2394cd"],["6dbefe87fbf2ec16"]]},{"id":"2e94718ebd0e815b","type":"server-state-changed","z":"c9a45c5fa0f63278","name":"Strom Haus","server":"27bc988471afc791","version":5,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":[],"outputinitially":false,"haltifstate":"","halt_if_type":"str","outputs":1,"output_only_on_state_change":false,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":90,"y":220,"wires":[["8efb8e698227df64"]]},{"id":"7311ae82c0d37979","type":"api-call-service","z":"c9a45c5fa0f63278","name":"Heizung Esszimmer","server":"27bc988471afc791","version":5,"debugenabled":false,"domain":"homeassistant","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.heizung_esszimmer"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":710,"y":180,"wires":[["f4ac2284f757128a"]]},{"id":"565630be4660d9fb","type":"api-call-service","z":"c9a45c5fa0f63278","name":"Heizung Esszimmer","server":"27bc988471afc791","version":5,"debugenabled":false,"domain":"homeassistant","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.heizung_esszimmer"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":710,"y":240,"wires":[["8de09adf7953e665"]]},{"id":"f4ac2284f757128a","type":"debug","z":"c9a45c5fa0f63278","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":840,"y":100,"wires":[]},{"id":"aa282a57fe2394cd","type":"api-current-state","z":"c9a45c5fa0f63278","name":"Ist Schalter aus?","server":"cf06b6ae.a4f438","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.heizung_esszimmer","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"10","forType":"num","forUnits":"seconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":510,"y":120,"wires":[["7311ae82c0d37979"],[]]},{"id":"6dbefe87fbf2ec16","type":"api-current-state","z":"c9a45c5fa0f63278","name":"Ist Schalter ein?","server":"cf06b6ae.a4f438","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.heizung_esszimmer","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"10","forType":"num","forUnits":"seconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":500,"y":320,"wires":[["565630be4660d9fb"],[]]},{"id":"8de09adf7953e665","type":"debug","z":"c9a45c5fa0f63278","name":"debug 18","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":840,"y":320,"wires":[]},{"id":"27bc988471afc791","type":"server","name":"Home Assistant","addon":true},{"id":"cf06b6ae.a4f438","type":"server","name":"Home Assistant","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"","statusSeparator":"","enableGlobalContextStore":false}]
Du musst es noch auf dein System anpassen, probier mal ob das so geht.
Grüße
LL
