Roborock Integration Benötigt Aufmerksamkeit; Fehler beim Einrichten
Hallo Leute
HA Core: 2024.7.2
Supervisor: 2024.08.0
roborock: 1.0.13
Zurück aus dem Urlaub stelle ich fest, dass die Integration nicht mehr funktioniert. Habe bereits einiges im Internet gelesen, möchte aber nicht noch “mehr” zerschiessen, da ich doch ein grosser Aufwand betrieben habe, das ganze zu implementieren - mit Automationen, Stockwerke etc. etc. Bevor ich einfach irgend etwas lösche und neu installiere frage ich lieber hier nach.
Log:
2024-08-26 06:54:41.058 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spook_inverse which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-08-26 06:54:41.059 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration thermal_comfort which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-08-26 06:54:41.059 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration watchman which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-08-26 06:54:41.060 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration roborock which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-08-26 06:54:41.060 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spook which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-08-26 06:54:41.062 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-08-26 06:54:41.063 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration homematicip_local which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-08-26 06:54:41.064 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration meteoswiss which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-08-26 06:54:41.065 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nuki_ng which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-08-26 06:54:41.065 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration swissweather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-08-26 06:54:43.663 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform legacy unifi_direct
  File "/usr/src/homeassistant/homeassistant/components/device_tracker/legacy.py", line 335, in async_setup_legacy
    scanner = await hass.async_add_executor_job(
  File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
    result = self.fn(*self.args, **self.kwargs)
  File "/usr/src/homeassistant/homeassistant/components/unifi_direct/device_tracker.py", line 38, in get_scanner
    return scanner if scanner.update_clients() else None
  File "/usr/src/homeassistant/homeassistant/components/unifi_direct/device_tracker.py", line 69, in update_clients
    self.clients = self.ap.get_clients()
  File "/usr/local/lib/python3.12/site-packages/unifi_ap/unifi_ap.py", line 80, in get_clients
    ap_data = self._fetch_ap_data()
  File "/usr/local/lib/python3.12/site-packages/unifi_ap/unifi_ap.py", line 47, in _fetch_ap_data
    client.connect(
  File "/usr/local/lib/python3.12/site-packages/paramiko/client.py", line 409, in connect
    raise NoValidConnectionsError(errors)
paramiko.ssh_exception.NoValidConnectionsError: [Errno None] Unable to connect to port 22 on 192.168.0.114
2024-08-26 06:54:44.731 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'nuki_ng' calls async_forward_entry_setup for integration, nuki_ng with title: Keller and entry_id: c7814261374d51a82d63679a0d15eeda, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead at custom_components/nuki_ng/__init__.py, line 31: hass.async_create_task(hass.config_entries.async_forward_entry_setup(entry, p)), please create a bug report at https://github.com/kvj/hass_nuki_ng/issues
2024-08-26 06:54:45.373 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' calls hass.http.register_static_path which is deprecated because it does blocking I/O in the event loop, instead call `await hass.http.async_register_static_paths([StaticPathConfig("/hacsfiles/themes", "/config/themes", True)])`; This function will be removed in 2025.7 at custom_components/hacs/base.py, line 1182: self.hass.http.register_static_path(f"{URL_BASE}/themes", self.hass.config.path("themes")), please create a bug report at https://github.com/hacs/integration/issues
2024-08-26 06:54:45.380 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' calls hass.http.register_static_path which is deprecated because it does blocking I/O in the event loop, instead call `await hass.http.async_register_static_paths([StaticPathConfig("/hacsfiles/frontend", "/config/custom_components/hacs/hacs_frontend", False)])`; This function will be removed in 2025.7 at custom_components/hacs/frontend.py, line 54: hass.http.register_static_path(f"{URL_BASE}/frontend", locate_dir(), cache_headers=False), please create a bug report at https://github.com/hacs/integration/issues
2024-08-26 06:54:45.389 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' calls hass.http.register_static_path which is deprecated because it does blocking I/O in the event loop, instead call `await hass.http.async_register_static_paths([StaticPathConfig("/hacsfiles/iconset.js", "/config/custom_components/hacs/iconset.js", True)])`; This function will be removed in 2025.7 at custom_components/hacs/frontend.py, line 57: hass.http.register_static_path(, please create a bug report at https://github.com/hacs/integration/issues
2024-08-26 06:54:45.393 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' accesses hass.components.frontend. This is deprecated and will stop working in Home Assistant 2024.9, it should be updated to import functions used from frontend directly at custom_components/hacs/frontend.py, line 68: hass.components.frontend.async_register_built_in_panel(, please create a bug report at https://github.com/hacs/integration/issues
2024-08-26 06:54:45.400 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' calls hass.http.register_static_path which is deprecated because it does blocking I/O in the event loop, instead call `await hass.http.async_register_static_paths([StaticPathConfig("/hacsfiles", "/config/www/community", True)])`; This function will be removed in 2025.7 at custom_components/hacs/base.py, line 1162: self.hass.http.register_static_path(, please create a bug report at https://github.com/hacs/integration/issues
2024-08-26 06:54:50.674 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration nuki_ng with title: Keller and entry_id: c7814261374d51a82d63679a0d15eeda, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
Stack (most recent call last):
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
    sys.exit(main())
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
    exit_code = runner.run(runtime_conf)
  File "/usr/src/homeassistant/homeassistant/runner.py", line 190, in run
    return loop.run_until_complete(setup_and_run_hass(runtime_config))
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete
    self.run_forever()
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever
    self._run_once()
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once
    handle._run()
  File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
    self._context.run(self._callback, *self._args)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2122, in async_forward_entry_setup
    _report_non_awaited_platform_forwards(entry, "async_forward_entry_setup")
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1175, in _report_non_awaited_platform_forwards
    report(
  File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 151, in report
    _LOGGER.warning(msg, stack_info=True)
2024-08-26 06:54:50.688 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration nuki_ng with title: Haustüre and entry_id: 89b0f09e798e67679b319a752417fb40, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-08-26 06:54:50.704 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration nuki_ng with title: Keller and entry_id: c7814261374d51a82d63679a0d15eeda, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-08-26 06:54:50.716 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration nuki_ng with title: Keller and entry_id: c7814261374d51a82d63679a0d15eeda, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-08-26 06:54:50.722 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration nuki_ng with title: Keller and entry_id: c7814261374d51a82d63679a0d15eeda, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-08-26 06:54:50.729 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration nuki_ng with title: Keller and entry_id: c7814261374d51a82d63679a0d15eeda, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-08-26 06:54:50.736 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration nuki_ng with title: Keller and entry_id: c7814261374d51a82d63679a0d15eeda, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-08-26 06:54:50.754 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration nuki_ng with title: Haustüre and entry_id: 89b0f09e798e67679b319a752417fb40, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-08-26 06:54:50.770 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration nuki_ng with title: Haustüre and entry_id: 89b0f09e798e67679b319a752417fb40, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-08-26 06:54:50.776 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration nuki_ng with title: Haustüre and entry_id: 89b0f09e798e67679b319a752417fb40, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-08-26 06:54:50.784 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration nuki_ng with title: Haustüre and entry_id: 89b0f09e798e67679b319a752417fb40, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-08-26 06:54:50.790 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration nuki_ng with title: Haustüre and entry_id: 89b0f09e798e67679b319a752417fb40, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-08-26 06:54:51.645 WARNING (MainThread) [homeassistant.components.sonos] Could not get visible Sonos devices from 192.168.0.127: HTTPConnectionPool(host='192.168.0.127', port=1400): Max retries exceeded with url: /xml/DeviceProperties1.xml (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f6a29e84fe0>: Failed to establish a new connection: [Errno 111] Connection refused'))
2024-08-26 06:55:08.249 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({% set result = namespace(sensors=[]) %}
{% for state in states.sensor | rejectattr('attributes.device_class', 'undefined') | selectattr('attributes.device_class', '==', 'timestamp') %}
    {% if 'last_seen' in state.entity_id and (states(state.entity_id) == 'unavailable' or ((as_timestamp(now()) - as_timestamp(states(state.entity_id))) > ((24 | int) * 60 * 60))) %}
        {% set result.sensors = result.sensors + [state.name | regex_replace(find=' last seen', replace='') ~ ' (' ~ relative_time(strptime(states(state.entity_id), '%Y-%m-%dT%H:%M:%S%z', 'unavailable')) ~ ')'] %}
    {% endif %}
{% endfor %}
{{ result.sensors | join('\n') | truncate(254, True) }}) renders=2>
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2078, in forgiving_as_timestamp
    return dt_util.as_timestamp(value)
  File "/usr/src/homeassistant/homeassistant/util/dt.py", line 153, in as_timestamp
    raise ValueError("not a valid date/time.")
ValueError: not a valid date/time.
2024-08-27 06:48:39.440 DEBUG (MainThread) [roborock.local_api] [Roborock S5 Max] Connecting to 192.168.0.121
2024-08-27 06:48:39.443 DEBUG (MainThread) [roborock.local_api] [Roborock S5 Max] Connecting to 192.168.0.121
2024-08-27 06:48:39.444 DEBUG (MainThread) [roborock.local_api] [Roborock S5 Max] Connecting to 192.168.0.121
2024-08-27 06:48:39.446 DEBUG (MainThread) [roborock.local_api] [Roborock S5 Max] Connecting to 192.168.0.121
2024-08-27 06:48:39.543 DEBUG (MainThread) [roborock.local_api] [Roborock S5 Max] Connecting to 192.168.0.121
2024-08-27 06:48:39.546 DEBUG (MainThread) [roborock.local_api] [Roborock S5 Max] Connecting to 192.168.0.121
2024-08-27 06:48:39.548 DEBUG (MainThread) [roborock.local_api] [Roborock S5 Max] Connecting to 192.168.0.121
2024-08-27 06:48:39.708 DEBUG (MainThread) [roborock.local_api] [Roborock S8 Pro Ultra] Connecting to 192.168.12.127
2024-08-27 06:48:39.810 DEBUG (MainThread) [roborock.local_api] [Roborock S8 Pro Ultra] Connecting to 192.168.12.127
2024-08-27 06:48:39.811 DEBUG (MainThread) [roborock.local_api] [Roborock S8 Pro Ultra] Connecting to 192.168.12.127
2024-08-27 06:48:39.813 DEBUG (MainThread) [roborock.local_api] [Roborock S8 Pro Ultra] Connecting to 192.168.12.127
Und was genau läuft nicht?
Hast du das HA System mal neu gestartet?
Habe sogar das System vollständig herunter gefahren und neu gestartet. Ich bekomme diese Fehlermeldung und dadurch funktioniert natürlich das Ganze auch nicht
Also bei mir zickt Roborock auch hin und wieder. Nach paar stunden hat er aber meistens wieder eine Verbindung. Falls nichts passiert, die integration mal löschen und neu einrichten. Normalerweise werden alle Entitäten wieder so erstellt wie es vorher war. Zumindest ist es meine Erfahrung das danach alles ist wie vorher und auch die Automation so laufen als wäre nichts gewesen.
@ciddi89 Danke Dir für den Hinweis, also nur hier die Integration löschen - nicht auch unter HACS?
Ne nur unter Integrationen. Meistens reicht das. Und falls der Fehler wieder kommt vielleicht auch nur warten. Da es eine Cloud Api ist kann es sein das die Anfragen nur geblockt werden oder der Server nicht erreichbar ist etc. Die Robbis sind aber noch eingeschaltet und haben auch eine Alan Verbindung ja?
Ok, werde ich einmal versuchen… drücke mir die Daumen :smiling_face:. Ja, WLAN steht, da ich beide via roborock APP weiterhin bedienen kann.
@ciddi89 Ein ganz ganz grosses DANKESCHÖN :ok_hand:.
Auf dem ersten Blick scheint es wieder zu funktionieren, alles wieder da. Ausführlicher Test muss erst noch folgen aber sieht gut aus.
Es ist echt toll, wie hier im Forum geholfen wird - oder wenn und aber. Vielen herzlichen Dank dafür.
Gruss aus der Schweiz
Hey vielen Dank hatte ich auch das Problem. Konnte es genau so lösen :+1:
bei mir funktioniert die Integration auch nicht mehr.
Vor einigen Tagen habe ich die Fehlermeldung entdeckt - wissentlich geändert hatte ich nichts.
Version ist 1.0.16.
Hab’s jetzt mal komplett gelöscht und neu eingerichtet, bekomme aber den gleichen Fehler - jetzt natürlich ohne Geräte, da waren vorher drei…
Hat das noch jemand?
Hey, hatte das Problem auch. Ich musste die Intergration und den Roborock Ordner unter custom_components löschen. Nach einem Neustart und neuer Installation hat er sie dann wieder gefunden.
Danke.
Das löst es bei mir leider nicht.
Hab die Integration schon gelöscht und neu installiert. Sowohl die aktuelle als auch x.13.
Den Roborock-Ordner unter custom_components habe ich nach Deinstallation der Integration gar nicht mehr.
jetzt wird’s noch besser.
alter version via HACS entfernt.
dann mal 1.0.13 installiert.
bei hinzufügen der integration werde ich dann statt mit dem einrichtungsdialog werde ich hiermit begrüßt:
:thinking:
Hab das selbe Problem, falls jemand eine Lösung hat wäre ich dankbar über einen Tipp.
Edit: Hab nochmal alles wie oben beschrieben durchgeführt und jetzt geht es wieder.
Ich habe alles genau wie beschrieben mehrmals durchgeführt und bekomme konsistent den Fehler:
Einrichtungsfehler: Überprüfe die Protokolle
Alles deinstalliert also nicht nur die Integration, sondern auch das HACS repository. Der Ordner roborock in custom_components war entsprechend auch verschwunden. HA neu gestartet, HACS repository neu heruntergeladen, Integration neu installiert und trotzdem wieder o.g. Fehlermeldung. Habe das Ganze dreimal wiederholt, ohne Erfolg. Wäre superdankbar, wenn jemand noch einen Tip hätte.
Einfach mal abwarten. Manchmal liegt es auch den Servern und es kann sogar 1-2 Tage dauern bis es plötzlich wieder funktioniert. So ist bisher meine Erfahrung.
btw.: Ich meine sogar das die Entwickler der Integration sich mehr auf die Integration von HA direkt konzentrieren und empfehlen diese zu benutzen statt der HACS Integration. Hast du es schon mal mit der probiert?
Danke für den Tip, bin jetzt auf die core Integration umgestiegen und was die reine Anzahl der Entitäten angeht, sind es jetzt bei meinem Qrevo Curv mit 42 sogar ein paar mehr als bei der HACS Integration.
Leider hat der Umstieg Simon’s Xiaomi Vacuum Card zerhauen, die ich mir auf der Grundlage seines Videos und seines Codes eingerichtet habe. U.a. finde ich die camera Enität nicht, die man im Code angeben muss, damit die Karte der Wohnung angezeigt wird. Ich habe es mit image versucht, bekomme dann aber die Fehlermeldung “Ungültige Kalibrierung”. Konkret geht es um diesen Teil des Codes:
  - type: custom:xiaomi-vacuum-map-card
    map_source:
      camera: image.roborock_qrevo_curv_map
    calibration_source:
      camera: true
    entity: vacuum.roborock_qrevo_curv
    vacuum_platform: send_command
Ja da hat sich auch was geändert. Dafür muss man tatsächlich leider erstmal eine extra Integration aus dem Hacs Store Laden. Auf der Seite ist auch ein Beispiel Code für die Xiaomi vacuum card.
Super, damit wird die Karte wieder korrekt eingebunden, vielen Dank!
Das letzte Problem ist der Dienstaufruf im Code, der so nicht mehr funktioniert, konkret dieser Teil:
    map_modes:
      - name: Wohnung
        icon: mdi:select-drag
        selection_type: ROOM
        service_call_schema:
          service: roborock.vacuum_clean_segment
          service_data:
            segments: "[[selection]]"
            entity_id: "[[entity_id]]"
Ich habe mir die neuen Dienstaufrufe der core Integration mal angeschaut und dort finde ich nur vacuum.send_command und vacuum.start, mit denen es aber nicht klappt. Ich habe es auch mit app_segment_clean versucht, aber dann passt das service_call_schema nicht mehr.
Update:
Falls jemand in Zukunft über das gleiche Problem stoßen sollte: Ich konnte das Problem mittlerweile mit der Dokumentation zum Einbinden der Roborock core Integration in die Xiaomi Vacuum card lösen: lovelace-xiaomi-vacuum-map-card/docs/templates/roborock.md at f54603d47ae0cad2f5692ce50f918e1840753801 · PiotrMachowski/lovelace-xiaomi-vacuum-map-card · GitHub
Wie der Code zu ändern ist, wird dort erklärt. Was meinen Fall aus dem letzten Post angeht, sieht die richtige Konfiguration so aus:
map_modes:
  - template: vacuum_clean_segment
    predefined_selections:
      - id: "1"
        icon:
          x: 24200
          "y": 28375
        label:
          text: Küche
          x: 24200
          "y": 28375
          offset_y: 35
        outline:
          - - 22000
            - 25150
          - - 26400
            - 25150
          - - 26400
            - 31600
          - - 22000
            - 31600
