ich versuche seit ein paar Tagen meine beiden Reolink Kameras (RLC-410W und RLC-511W) in Frigate zu integrieren, damit ich sie in Home Assistant nutzen kann.
Sie laufen jetzt soweit auch. Die Objekterkennung läuft. Es wird aufgezeichnet. Alles gut sollte man meinen, aber wenn ich in das Log schaue, erblicke ich folgende Fehlermeldungen:
2023-12-06 16:20:31.386101217 [2023-12-06 17:20:31] ffmpeg.HWR_Cam.detect ERROR : [rtsp @ 0x562e961bbe40] method DESCRIBE failed: 404 Not Found
2023-12-06 16:20:31.386115766 [2023-12-06 17:20:31] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Server returned 404 Not Found
2023-12-06 16:20:31.402661375 [2023-12-06 17:20:31] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 16:20:31.403009033 [2023-12-06 17:20:31] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:20:31.403013966 [2023-12-06 17:20:31] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:20:36.423930588 [2023-12-06 17:20:36] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 16:20:36.424479555 [2023-12-06 17:20:36] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 16:20:41.413944304 [2023-12-06 17:20:41] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 16:20:41.414416160 [2023-12-06 17:20:41] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 16:20:41.415042352 [2023-12-06 17:20:41] ffmpeg.HWR_Cam.detect ERROR : [rtsp @ 0x55f1bb047e40] method DESCRIBE failed: 404 Not Found
2023-12-06 16:20:41.415648187 [2023-12-06 17:20:41] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Server returned 404 Not Found
2023-12-06 16:20:41.430960705 [2023-12-06 17:20:41] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 16:20:41.431195130 [2023-12-06 17:20:41] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:20:41.431551040 [2023-12-06 17:20:41] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:20:46.451200374 [2023-12-06 17:20:46] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 16:20:46.451395394 [2023-12-06 17:20:46] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 16:20:51.441734615 [2023-12-06 17:20:51] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 16:20:51.442097104 [2023-12-06 17:20:51] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 16:20:51.442578407 [2023-12-06 17:20:51] ffmpeg.HWR_Cam.detect ERROR : [rtsp @ 0x561f427a8e40] method DESCRIBE failed: 404 Not Found
2023-12-06 16:20:51.442959014 [2023-12-06 17:20:51] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Server returned 404 Not Found
2023-12-06 16:20:51.458263173 [2023-12-06 17:20:51] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 16:20:51.458725344 [2023-12-06 17:20:51] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:20:51.458730537 [2023-12-06 17:20:51] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:20:53.734284970 [2023-12-06 17:20:53] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 16:20:53.734606301 [2023-12-06 17:20:53] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 16:21:01.468919967 [2023-12-06 17:21:01] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 16:21:01.469467577 [2023-12-06 17:21:01] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 16:21:01.469913609 [2023-12-06 17:21:01] ffmpeg.HWR_Cam.detect ERROR : [rtsp @ 0x55d2b086ae40] method DESCRIBE failed: 404 Not Found
2023-12-06 16:21:01.470352430 [2023-12-06 17:21:01] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Server returned 404 Not Found
2023-12-06 16:21:01.485399183 [2023-12-06 17:21:01] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 16:21:01.485830023 [2023-12-06 17:21:01] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:21:01.485853814 [2023-12-06 17:21:01] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:21:04.548285559 [2023-12-06 17:21:04] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 16:21:04.548781544 [2023-12-06 17:21:04] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 16:21:11.496088084 [2023-12-06 17:21:11] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 16:21:11.496476453 [2023-12-06 17:21:11] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 16:21:11.498426297 [2023-12-06 17:21:11] ffmpeg.HWR_Cam.detect ERROR : [rtsp @ 0x56393fed0e40] method DESCRIBE failed: 404 Not Found
2023-12-06 16:21:11.498442891 [2023-12-06 17:21:11] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Server returned 404 Not Found
2023-12-06 16:21:11.516279237 [2023-12-06 17:21:11] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 16:21:11.516532132 [2023-12-06 17:21:11] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:21:11.516699853 [2023-12-06 17:21:11] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:21:14.596577982 [2023-12-06 17:21:14] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 16:21:14.596773784 [2023-12-06 17:21:14] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 16:21:21.527025494 [2023-12-06 17:21:21] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 16:21:21.527633479 [2023-12-06 17:21:21] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 16:21:21.527639439 [2023-12-06 17:21:21] ffmpeg.HWR_Cam.detect ERROR : [rtsp @ 0x55954c2b8e40] method DESCRIBE failed: 404 Not Found
2023-12-06 16:21:21.527858561 [2023-12-06 17:21:21] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Server returned 404 Not Found
2023-12-06 16:21:21.538934769 [2023-12-06 17:21:21] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 16:21:21.549052398 [2023-12-06 17:21:21] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:21:21.549058400 [2023-12-06 17:21:21] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:21:26.653641007 [2023-12-06 17:21:26] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 16:21:26.654122621 [2023-12-06 17:21:26] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 16:21:31.557679324 [2023-12-06 17:21:31] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 16:21:31.558209474 [2023-12-06 17:21:31] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 16:21:31.558638267 [2023-12-06 17:21:31] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 16:21:31.573727147 [2023-12-06 17:21:31] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 16:21:31.574020935 [2023-12-06 17:21:31] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:21:31.574026730 [2023-12-06 17:21:31] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:21:41.586692624 [2023-12-06 17:21:41] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 16:21:41.588417882 [2023-12-06 17:21:41] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:21:41.588605414 [2023-12-06 17:21:41] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:21:51.614240815 [2023-12-06 17:21:51] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 16:21:51.614739420 [2023-12-06 17:21:51] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:21:51.614744809 [2023-12-06 17:21:51] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:22:01.621181522 [2023-12-06 17:22:01] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 16:22:01.621571104 [2023-12-06 17:22:01] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:22:01.622033895 [2023-12-06 17:22:01] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:22:11.638222172 [2023-12-06 17:22:11] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 16:22:11.638742871 [2023-12-06 17:22:11] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:22:11.639207220 [2023-12-06 17:22:11] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:22:21.656125932 [2023-12-06 17:22:21] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 16:22:21.656833006 [2023-12-06 17:22:21] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:22:21.657159146 [2023-12-06 17:22:21] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:22:31.672893427 [2023-12-06 17:22:31] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 16:22:31.673252007 [2023-12-06 17:22:31] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:22:31.673815079 [2023-12-06 17:22:31] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:22:41.690853710 [2023-12-06 17:22:41] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 16:22:41.692355277 [2023-12-06 17:22:41] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:22:41.692844865 [2023-12-06 17:22:41] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:22:51.710044011 [2023-12-06 17:22:51] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 16:22:51.720660243 [2023-12-06 17:22:51] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:22:51.721022529 [2023-12-06 17:22:51] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:23:01.728448484 [2023-12-06 17:23:01] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 16:23:01.728461424 [2023-12-06 17:23:01] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:23:01.728468089 [2023-12-06 17:23:01] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:23:11.746099579 [2023-12-06 17:23:11] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 16:23:11.746764330 [2023-12-06 17:23:11] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:23:11.746777741 [2023-12-06 17:23:11] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:23:21.762519386 [2023-12-06 17:23:21] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 16:23:21.763031275 [2023-12-06 17:23:21] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:23:21.763392131 [2023-12-06 17:23:21] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 16:23:31.787590360 [2023-12-06 17:23:31] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 16:23:31.788024624 [2023-12-06 17:23:31] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 16:23:31.788207307 [2023-12-06 17:23:31] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:19:22.320038875 [2023-12-06 19:19:22] watchdog.HWR_Cam INFO : No frames received from HWR_Cam in 20 seconds. Exiting ffmpeg...
2023-12-06 18:19:22.320399861 [2023-12-06 19:19:22] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:19:22.401230647 [2023-12-06 19:19:22] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:19:22.402936775 [2023-12-06 19:19:22] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:19:32.405409542 [2023-12-06 19:19:32] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:19:32.406905922 [2023-12-06 19:19:32] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:19:32.407807072 [2023-12-06 19:19:32] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Connection timed out
2023-12-06 18:19:37.535746779 [2023-12-06 19:19:37] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:19:37.536022902 [2023-12-06 19:19:37] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:19:42.424064985 [2023-12-06 19:19:42] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:19:42.424534471 [2023-12-06 19:19:42] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:19:42.424833068 [2023-12-06 19:19:42] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:19:47.553666484 [2023-12-06 19:19:47] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:19:47.554313104 [2023-12-06 19:19:47] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:19:52.441255280 [2023-12-06 19:19:52] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:19:52.441792482 [2023-12-06 19:19:52] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:19:52.442075384 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:19:52.463197024 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:19:52.463622277 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:19:52.463627721 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:19:52.463631059 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:19:52.464220274 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:19:52.464227761 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:19:52.464231948 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:19:52.464235694 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:19:52.464240216 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:19:52.464288005 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:19:52.464605630 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:19:52.464610106 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:19:52.464613166 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:19:52.464616481 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : [segment @ 0x55ba040e1440] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2023-12-06 18:19:52.464637998 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : [segment @ 0x55ba040e1440] Non-monotonous DTS in output stream 0:0; previous: 0, current: 0; changing to 1. This may result in incorrect timestamps in the output file.
2023-12-06 18:19:52.464912753 [2023-12-06 19:19:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Connection timed out
2023-12-06 18:19:52.464917056 [2023-12-06 19:19:52] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:19:52.464919794 [2023-12-06 19:19:52] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:19:57.575600270 [2023-12-06 19:19:57] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:19:57.576073505 [2023-12-06 19:19:57] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:20:02.473883884 [2023-12-06 19:20:02] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:20:02.474254959 [2023-12-06 19:20:02] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:20:02.474816216 [2023-12-06 19:20:02] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:20:02.490690682 [2023-12-06 19:20:02] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:20:02.490983208 [2023-12-06 19:20:02] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:20:02.490987960 [2023-12-06 19:20:02] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:20:07.603917057 [2023-12-06 19:20:07] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:20:07.604334572 [2023-12-06 19:20:07] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:20:12.500460309 [2023-12-06 19:20:12] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:20:12.501172750 [2023-12-06 19:20:12] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:20:12.501570957 [2023-12-06 19:20:12] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:20:12.518100968 [2023-12-06 19:20:12] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:20:12.522538927 [2023-12-06 19:20:12] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:20:12.522668641 [2023-12-06 19:20:12] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:20:17.630845024 [2023-12-06 19:20:17] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:20:17.631101502 [2023-12-06 19:20:17] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:20:22.528043794 [2023-12-06 19:20:22] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:20:22.528457286 [2023-12-06 19:20:22] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:20:22.528876000 [2023-12-06 19:20:22] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:20:22.544507310 [2023-12-06 19:20:22] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:20:22.544797328 [2023-12-06 19:20:22] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:20:22.544802418 [2023-12-06 19:20:22] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:20:27.657349556 [2023-12-06 19:20:27] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:20:27.657654060 [2023-12-06 19:20:27] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:20:32.554436261 [2023-12-06 19:20:32] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:20:32.564119048 [2023-12-06 19:20:32] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:20:32.564772767 [2023-12-06 19:20:32] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:20:32.571733371 [2023-12-06 19:20:32] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:20:32.571975367 [2023-12-06 19:20:32] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:20:32.572058336 [2023-12-06 19:20:32] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:20:37.686281426 [2023-12-06 19:20:37] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:20:37.686414968 [2023-12-06 19:20:37] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:20:42.582543063 [2023-12-06 19:20:42] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:20:42.583680257 [2023-12-06 19:20:42] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:20:42.584593940 [2023-12-06 19:20:42] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:20:42.601189045 [2023-12-06 19:20:42] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:20:42.601316728 [2023-12-06 19:20:42] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:20:42.601491443 [2023-12-06 19:20:42] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:20:47.714067088 [2023-12-06 19:20:47] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:20:47.714452260 [2023-12-06 19:20:47] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:20:52.611795806 [2023-12-06 19:20:52] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:20:52.612170964 [2023-12-06 19:20:52] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:20:52.612645317 [2023-12-06 19:20:52] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:20:52.627983020 [2023-12-06 19:20:52] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:20:52.628267946 [2023-12-06 19:20:52] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:20:52.628273381 [2023-12-06 19:20:52] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:20:57.741630841 [2023-12-06 19:20:57] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:20:57.741905291 [2023-12-06 19:20:57] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:21:02.637911370 [2023-12-06 19:21:02] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:21:02.638275703 [2023-12-06 19:21:02] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:21:02.638781598 [2023-12-06 19:21:02] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:21:02.654138105 [2023-12-06 19:21:02] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:21:02.654493722 [2023-12-06 19:21:02] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:21:02.654818957 [2023-12-06 19:21:02] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:21:05.675870988 [2023-12-06 19:21:05] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:21:05.676511569 [2023-12-06 19:21:05] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:21:12.664156135 [2023-12-06 19:21:12] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:21:12.664777305 [2023-12-06 19:21:12] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:21:12.665320606 [2023-12-06 19:21:12] ffmpeg.HWR_Cam.detect ERROR : [rtsp @ 0x563e7716de40] method DESCRIBE failed: 404 Not Found
2023-12-06 18:21:12.665780986 [2023-12-06 19:21:12] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Server returned 404 Not Found
2023-12-06 18:21:12.681570115 [2023-12-06 19:21:12] ffmpeg.HWR_Cam.record ERROR : [rtsp @ 0x55ec38fb9f00] method DESCRIBE failed: 404 Not Found
2023-12-06 18:21:12.681707934 [2023-12-06 19:21:12] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Server returned 404 Not Found
2023-12-06 18:21:12.681957925 [2023-12-06 19:21:12] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:21:12.681962505 [2023-12-06 19:21:12] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:21:17.793895693 [2023-12-06 19:21:17] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:21:17.794171062 [2023-12-06 19:21:17] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:21:22.692622049 [2023-12-06 19:21:22] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:21:22.693141099 [2023-12-06 19:21:22] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:21:22.693567812 [2023-12-06 19:21:22] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:21:22.708795584 [2023-12-06 19:21:22] ffmpeg.HWR_Cam.record ERROR : rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc: Invalid data found when processing input
2023-12-06 18:21:22.709226903 [2023-12-06 19:21:22] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:21:22.709537386 [2023-12-06 19:21:22] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:21:27.821577339 [2023-12-06 19:21:27] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:21:27.821818808 [2023-12-06 19:21:27] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:21:32.719789794 [2023-12-06 19:21:32] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:21:32.720156083 [2023-12-06 19:21:32] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:21:32.720836159 [2023-12-06 19:21:32] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:21:32.737184151 [2023-12-06 19:21:32] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 18:21:32.737423459 [2023-12-06 19:21:32] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:21:32.737574289 [2023-12-06 19:21:32] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:21:37.850831721 [2023-12-06 19:21:37] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:21:37.851043684 [2023-12-06 19:21:37] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:21:42.748915446 [2023-12-06 19:21:42] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:21:42.749336110 [2023-12-06 19:21:42] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:21:42.749818074 [2023-12-06 19:21:42] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:21:42.769700455 [2023-12-06 19:21:42] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 18:21:42.775382417 [2023-12-06 19:21:42] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:21:42.775837842 [2023-12-06 19:21:42] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:21:47.881963565 [2023-12-06 19:21:47] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:21:47.882109619 [2023-12-06 19:21:47] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:21:52.782104053 [2023-12-06 19:21:52] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:21:52.793200845 [2023-12-06 19:21:52] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:21:52.793207501 [2023-12-06 19:21:52] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:21:52.802053060 [2023-12-06 19:21:52] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 18:21:52.802059669 [2023-12-06 19:21:52] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:21:52.802063042 [2023-12-06 19:21:52] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:21:57.789046787 [2023-12-06 19:21:57] frigate.record.maintainer WARNING : Unable to keep up with recording segments in cache for HWR_Cam. Keeping the 6 most recent segments out of 7 and discarding the rest...
2023-12-06 18:21:57.789795583 [mov,mp4,m4a,3gp,3g2,mj2 @ 0x7f9cfc120940] moov atom not found
2023-12-06 18:21:57.789898071 [ERROR:0@43207.387] global cap.cpp:164 open VIDEOIO(CV_IMAGES): raised OpenCV exception:
2023-12-06 18:21:57.789900876
2023-12-06 18:21:57.789903851 OpenCV(4.7.0) /io/opencv/modules/videoio/src/cap_images.cpp:267: error: (-215:Assertion failed) number < max_number in function 'icvExtractPattern'
2023-12-06 18:21:57.789905658
2023-12-06 18:21:57.789907646
2023-12-06 18:21:57.805001252 [2023-12-06 19:21:57] frigate.record.maintainer WARNING : Failed to probe corrupt segment /tmp/cache/HWR_Cam@20231206192152+0100.mp4
2023-12-06 18:21:57.805877632 [2023-12-06 19:21:57] frigate.record.maintainer WARNING : Discarding a corrupt recording segment: /tmp/cache/HWR_Cam@20231206192152+0100.mp4
2023-12-06 18:21:57.916090993 [2023-12-06 19:21:57] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:21:57.916591563 [2023-12-06 19:21:57] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:22:02.819678127 [2023-12-06 19:22:02] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:22:02.820344531 [2023-12-06 19:22:02] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:22:02.820753794 [2023-12-06 19:22:02] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:22:02.837898301 [2023-12-06 19:22:02] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 18:22:02.846296583 [2023-12-06 19:22:02] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:22:02.846302675 [2023-12-06 19:22:02] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:22:07.951184553 [2023-12-06 19:22:07] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:22:07.952190165 [2023-12-06 19:22:07] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:22:12.852985147 [2023-12-06 19:22:12] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:22:12.853170727 [2023-12-06 19:22:12] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:22:12.853365293 [2023-12-06 19:22:12] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:22:12.864082816 [2023-12-06 19:22:12] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 18:22:12.864779502 [2023-12-06 19:22:12] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:22:12.865123543 [2023-12-06 19:22:12] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:22:17.976486345 [2023-12-06 19:22:17] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:22:17.976746763 [2023-12-06 19:22:17] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:22:22.874024414 [2023-12-06 19:22:22] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:22:22.874230526 [2023-12-06 19:22:22] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:22:22.874475001 [2023-12-06 19:22:22] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:22:22.884652188 [2023-12-06 19:22:22] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 18:22:22.885052275 [2023-12-06 19:22:22] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:22:22.885058499 [2023-12-06 19:22:22] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
2023-12-06 18:22:27.997188206 [2023-12-06 19:22:27] frigate.video ERROR : HWR_Cam: Unable to read frames from ffmpeg process.
2023-12-06 18:22:27.997401370 [2023-12-06 19:22:27] frigate.video ERROR : HWR_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 18:22:32.894668649 [2023-12-06 19:22:32] watchdog.HWR_Cam ERROR : Ffmpeg process crashed unexpectedly for HWR_Cam.
2023-12-06 18:22:32.894973357 [2023-12-06 19:22:32] watchdog.HWR_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 18:22:32.895344528 [2023-12-06 19:22:32] ffmpeg.HWR_Cam.detect ERROR : rtsp://127.0.0.1:8554/HWR_sub?video=copy: Invalid data found when processing input
2023-12-06 18:22:32.908543931 [2023-12-06 19:22:32] watchdog.HWR_Cam ERROR : No new recording segments were created for HWR_Cam in the last 120s. restarting the ffmpeg record process...
2023-12-06 18:22:32.908839482 [2023-12-06 19:22:32] watchdog.HWR_Cam INFO : Terminating the existing ffmpeg process...
2023-12-06 18:22:32.908844578 [2023-12-06 19:22:32] watchdog.HWR_Cam INFO : Waiting for ffmpeg to exit gracefully...
Nachstehend die dazugehörige Config:
mqtt:
host: 192.168.178.100
user: user
password: pw
detectors:
coral:
type: edgetpu
device: usb
record:
enabled: True
retain:
days: 7
mode: active_objects
events:
retain:
default: 14
snapshots:
enabled: true
timestamp: false
bounding_box: true
retain:
default: 20
objects:
track:
- person
- cat
- dog
go2rtc:
streams:
Hof:
- "ffmpeg:http://192.xxx.xxx.xx/flv?port=1935&app=bcs&stream=channel0_main.bcs&user=usr&password=pw#video=copy#audio=copy#audio=opus"
Hof_sub:
- "ffmpeg:http://192.xxx.xxx.xx/flv?port=1935&app=bcs&stream=channel0_ext.bcs&user=usr&password=pw"
HWR:
HWR_sub:
cameras:
Hof_Cam:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/Hof?video=copy&audio=acc
input_args: preset-rtsp-restream
roles:
- record
- path: rtsp://127.0.0.1:8554/Hof_sub?video=copy
roles:
- detect
hwaccel_args: preset-vaapi
detect:
enabled: true
width: 640
height: 480
motion:
mask:
- 0,80,634,85,662,152,695,155,760,229,896,383,896,0,0,0
HWR_Cam:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/HWR?video=copy&audio=acc
roles:
- record
- path: rtsp://127.0.0.1:8554/HWR_sub?video=copy
roles:
- detect
detect:
enabled: true
width: 640
height: 360
motion:
mask:
- 173,335,522,39,565,0,0,0,0,456
Ich habe sämtliche Methoden ausprobiert, die Kameras einzubinden. Mit dieser funktioniert es, aber eben mehr schlecht als recht.
Siehe auch:
Wenn irgendjemand noch einen Tipp für mich hat würde ich mich freuen.
Vg Mirko
Nachtrag:
habe eben noch etwas herausgefunden. Ich hatte noch die Reolink Integration im HA eingerichtet. Die beiden Systeme haben sich offensichtlich gestört. Aber einige Fehlermeldungen bleiben trotzdem:
2023-12-06 19:21:29.645632097 [2023-12-06 20:21:29] frigate.app INFO : Creating directory: /tmp/cache
2023-12-06 19:21:29.694354781 [2023-12-06 20:21:29] peewee_migrate.logs INFO : Starting migrations
2023-12-06 19:21:29.700877933 [2023-12-06 20:21:29] peewee_migrate.logs INFO : There is nothing to migrate
2023-12-06 19:21:29.715108415 [2023-12-06 20:21:29] frigate.app INFO : Recording process started: 306
2023-12-06 19:21:29.719640418 [2023-12-06 20:21:29] frigate.app INFO : go2rtc process pid: 89
2023-12-06 19:21:29.751251254 [2023-12-06 20:21:29] frigate.app INFO : Output process started: 318
2023-12-06 19:21:29.787449478 [2023-12-06 20:21:29] frigate.app INFO : Camera processor started for Hof_Cam: 327
2023-12-06 19:21:29.794472325 [2023-12-06 20:21:29] frigate.app INFO : Camera processor started for HWR_Cam: 329
2023-12-06 19:21:29.802246970 [2023-12-06 20:21:29] frigate.app INFO : Capture process started for Hof_Cam: 330
2023-12-06 19:21:29.809909257 [2023-12-06 20:21:29] frigate.app INFO : Capture process started for HWR_Cam: 332
2023-12-06 19:21:32.359925281 [2023-12-06 20:21:29] detector.coral INFO : Starting detection process: 316
2023-12-06 19:21:32.364995909 [2023-12-06 20:21:29] frigate.detectors.plugins.edgetpu_tfl INFO : Attempting to load TPU as usb
2023-12-06 19:21:32.365217423 [2023-12-06 20:21:32] frigate.detectors.plugins.edgetpu_tfl INFO : TPU found
2023-12-06 19:21:34.956349927 [2023-12-06 20:21:34] frigate.video ERROR : Hof_Cam: Unable to read frames from ffmpeg process.
2023-12-06 19:21:34.956652218 [2023-12-06 20:21:34] frigate.video ERROR : Hof_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 19:21:49.872213424 [2023-12-06 20:21:49] watchdog.Hof_Cam ERROR : Ffmpeg process crashed unexpectedly for Hof_Cam.
2023-12-06 19:21:49.876903939 [2023-12-06 20:21:49] watchdog.Hof_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 19:21:49.877411954 [2023-12-06 20:21:49] ffmpeg.Hof_Cam.detect ERROR : rtsp://127.0.0.1:8554/Hof_sub?video=copy: Invalid data found when processing input
2023-12-06 19:21:54.998219664 [2023-12-06 20:21:54] frigate.video ERROR : Hof_Cam: Unable to read frames from ffmpeg process.
2023-12-06 19:21:54.999156984 [2023-12-06 20:21:54] frigate.video ERROR : Hof_Cam: ffmpeg process is not running. exiting capture thread...
2023-12-06 19:21:59.886575343 [2023-12-06 20:21:59] watchdog.Hof_Cam ERROR : Ffmpeg process crashed unexpectedly for Hof_Cam.
2023-12-06 19:21:59.894034863 [2023-12-06 20:21:59] watchdog.Hof_Cam ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-12-06 19:21:59.894822086 [2023-12-06 20:21:59] ffmpeg.Hof_Cam.detect ERROR : rtsp://127.0.0.1:8554/Hof_sub?video=copy: Invalid data found when processing input
by HarryP: Zusammenführung Doppelpost
