ich versuche seit Tagen meine POE Cam (Anpviz IPC-D260W-S) in Frigate zu konfigurieren.
Heute ist ein neues Frigate Video von Simon online gekommen und ich hab mich wieder mit neuer Motivation an den PC gesetzt - leider wieder das gleiche Ergebnis wie seit Tagen.
Protokoll in HA:
2025-07-30 19:29:35.874189859 [INFO] Preparing Frigate...
2025-07-30 19:29:35.879794326 [INFO] Starting NGINX...
2025-07-30 19:29:35.898960742 [INFO] No TLS certificate found. Generating a self signed certificate...
2025-07-30 19:29:35.922208551 [INFO] Got IP address from supervisor: 192.168.178.150
2025-07-30 19:29:35.961753347 [INFO] Got WebRTC port from supervisor: 8555
2025-07-30 19:29:36.008764462 [INFO] Starting Frigate...
2025-07-30 19:29:36.746865106 [INFO] Starting go2rtc...
2025-07-30 19:29:36.943481625 21:29:36.943 INF go2rtc platform=linux/amd64 revision=b2399f3 version=1.9.2
2025-07-30 19:29:36.943598945 21:29:36.943 INF config path=/dev/shm/go2rtc.yaml
2025-07-30 19:29:36.944454687 21:29:36.944 INF [api] listen addr=:1984
2025-07-30 19:29:36.944922107 21:29:36.944 INF [rtsp] listen addr=:8554
2025-07-30 19:29:36.945317707 21:29:36.945 INF [webrtc] listen addr=:8555/tcp
2025-07-30 19:29:38.868343251 [2025-07-30 21:29:38] frigate.util.config INFO : Checking if frigate config needs migration...
2025-07-30 19:29:38.887673518 [2025-07-30 21:29:38] frigate.util.config INFO : frigate config does not need migration...
2025-07-30 19:29:38.910224674 [2025-07-30 21:29:38] frigate.app INFO : Starting Frigate (0.15.2-3bda638)
2025-07-30 19:29:38.910677925 [2025-07-30 21:29:38] frigate.app INFO : Creating directory: /tmp/cache
2025-07-30 19:29:38.914086971 [2025-07-30 21:29:38] frigate.util.services INFO : Current file limits - Soft: 1024, Hard: 524288
2025-07-30 19:29:38.914347569 [2025-07-30 21:29:38] frigate.util.services INFO : File limit set. New soft limit: 65536, Hard limit remains: 524288
2025-07-30 19:29:38.917589241 [2025-07-30 21:29:38] peewee_migrate.logs INFO : Starting migrations
2025-07-30 19:29:38.918210390 [2025-07-30 21:29:38] peewee_migrate.logs INFO : There is nothing to migrate
2025-07-30 19:29:38.924960664 [2025-07-30 21:29:38] frigate.app INFO : Recording process started: 252
2025-07-30 19:29:38.930914722 [2025-07-30 21:29:38] frigate.app INFO : Review process started: 261
2025-07-30 19:29:38.934275454 [2025-07-30 21:29:38] frigate.app INFO : go2rtc process pid: 95
2025-07-30 19:29:38.944192971 [2025-07-30 21:29:38] detector.detector_name INFO : Starting detection process: 268
2025-07-30 19:29:38.946398569 [2025-07-30 21:29:38] frigate.detectors WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
s6-rc: info: service nginx successfully started
s6-rc: info: service certsync: starting
s6-rc: info: service certsync successfully started
s6-rc: info: service legacy-services: starting
2025-07-30 19:29:38.956143431 [2025-07-30 21:29:38] frigate.app INFO : Output process started: 288
2025-07-30 19:29:38.959764861 [INFO] Starting certsync...
s6-rc: info: service legacy-services successfully started
2025-07-30 19:29:38.991164365 [2025-07-30 21:29:38] frigate.app INFO : Camera processor started for Eingang: 327
2025-07-30 19:29:39.012528493 [2025-07-30 21:29:39] frigate.app INFO : Capture process started for Eingang: 335
2025-07-30 19:29:39.084015292 127.0.0.1 - - [30/Jul/2025:21:29:39 +0200] "" 400 0 "-" "-" "-"
2025-07-30 19:29:39.160381424 [2025-07-30 21:29:39] frigate.api.fastapi_app INFO : Starting FastAPI app
2025-07-30 19:29:39.293348835 [2025-07-30 21:29:39] frigate.api.fastapi_app INFO : FastAPI started
2025-07-30 19:29:44.171799921 [2025-07-30 21:29:44] frigate.video ERROR : Eingang: Unable to read frames from ffmpeg process.
2025-07-30 19:29:44.173003463 [2025-07-30 21:29:44] frigate.video ERROR : Eingang: ffmpeg process is not running. exiting capture thread...
2025-07-30 19:29:45.872091311 [INFO] Starting go2rtc healthcheck service...
2025-07-30 19:29:59.072917304 [2025-07-30 21:29:59] watchdog.Eingang ERROR : Ffmpeg process crashed unexpectedly for Eingang.
2025-07-30 19:29:59.072921396 [2025-07-30 21:29:59] watchdog.Eingang ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2025-07-30 19:29:59.072925394 [2025-07-30 21:29:59] ffmpeg.Eingang.detect ERROR : [in#0 @ 0x55b656bb4d80] Error opening input: Invalid data found when processing input
2025-07-30 19:29:59.072927574 [2025-07-30 21:29:59] ffmpeg.Eingang.detect ERROR : Error opening input file rtsp://127.0.0.1:8554/Eingang_sub.
2025-07-30 19:29:59.072941417 [2025-07-30 21:29:59] ffmpeg.Eingang.detect ERROR : Error opening input files: Invalid data found when processing input
Immer Unable to read frames from ffmpeg process. und ffmpeg process is not running. exiting capture thread…
Meine konfig:
mqtt:
enabled: true
host: 192.168.178.100
user: xxxx
password: xxxx
topic_prefix: frigate
client_id: frigate
stats_interval: 15
# https://docs.frigate.video/configuration/hardware_acceleration
ffmpeg:
hwaccel_args: preset-vaapi
input_args: preset-rtsp-restream
output_args:
record: preset-record-generic-audio-copy
#Standard
detectors:
detector_name:
type: cpu
#detectors:
# coral:
# type: edgetpu
# device: usb
birdseye:
enabled: true
restream: true
mode: objects
objects:
track:
- person
- car
filters:
person:
min_area: 5000
max_area: 100000
go2rtc:
streams:
Eingang:
- ffmpeg:rtsp://test:abcd1234!@192.168.178.60/stream0/ #POE IP Cam: Anpviz IPC-D260W-S Main
- rtsp://test:abcd1234!@192.168.178.60/stream0/
Eingang_sub:
- ffmpeg:rtsp://test:abcd1234!@192.168.178.60/stream1/ #POE IP Cam: Anpviz IPC-D260W-S Sub
cameras:
Eingang:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/Eingang # Stream you use for record
roles:
- record
- path: rtsp://127.0.0.1:8554/Eingang_sub # Stream you use for detection
roles:
- detect
detect:
width: 1280
height: 720
fps: 5
snapshots:
enabled: true
record:
enabled: true
retain:
days: 7
alerts:
retain:
days: 14
detections:
retain:
days: 14
Hat jenmand eine Idee was ich seit Tagen falsch mache?
