Relais 240V schalten
@Gurumir @rev.antun @LutzHB @Frank501 @noschvie @phettsack
Hallo, hier eine kleine Rückmeldung zu meinem Projekt,
Schalten des Conson CP24 Relais Moduls mit Status Rückmeldung
Aktuel hängt am ESP8266 ein MCP23017 GPIO-Expander , somit können 8 Relais geschaltet werden und 8 Status ausgewertet werden, dies genügt also um 2 CP24 Module zu bedienen.
Die ESP-Home Yaml für den ESP8266 lautet nun wie folgt:
esphome:
  friendly_name: NodeMCU-Conson
esp8266:
  board: nodemcuv2
logger:
web_server:
api:
  encryption:
    key: "fa3pXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
ota:
  - platform: esphome
    password: "aa9YYYYYYYYYYYYYYYYYYYYYYYYYYYYYY"
wifi:
  networks:
    - ssid: !secret wifi_ssid
    - ssid: !secret wifi_ssid2
      password: !secret wifi_password2
  ap:
    ssid: "Nodemcu Fallback Hotspot"
    password: "PytZZZZZZZZZZZZZZ"
captive_portal:
# I2C & MCP
i2c:
  sda: GPIO04
  scl: GPIO05
  frequency: 400kHz
  scan: false
mcp23017:
  - id: mcp23017_01
    address: 0x20
# 8 Relais (B0..B7) – intern, kein HA-Icon
switch:
  - platform: gpio
    internal: true
    pin: { mcp23xxx: mcp23017_01, number: 8,  mode: { output: true }, inverted: false }
  - platform: gpio
    internal: true
    pin: { mcp23xxx: mcp23017_01, number: 9,  mode: { output: true }, inverted: false }
  - platform: gpio
    internal: true
    pin: { mcp23xxx: mcp23017_01, number: 10, mode: { output: true }, inverted: false }
  - platform: gpio
    internal: true
    pin: { mcp23xxx: mcp23017_01, number: 11, mode: { output: true }, inverted: false }
  - platform: gpio
    internal: true
    pin: { mcp23xxx: mcp23017_01, number: 12, mode: { output: true }, inverted: false }
  - platform: gpio
    internal: true
    pin: { mcp23xxx: mcp23017_01, number: 13, mode: { output: true }, inverted: false }
  - platform: gpio
    internal: true
    pin: { mcp23xxx: mcp23017_01, number: 14, mode: { output: true }, inverted: false }
  - platform: gpio
    internal: true
    pin: { mcp23xxx: mcp23017_01, number: 15, mode: { output: true }, inverted: false }
# 8 Buttons (Taster-Impulse, 100 ms)
button:
  - platform: template
    name: "Taster Licht 1"
    on_press:
      - switch.turn_on: rl_1
      - delay: 100ms
      - switch.turn_off: rl_1
    name: "Taster Licht 2"
    on_press:
      - switch.turn_on: rl_2
      - delay: 100ms
      - switch.turn_off: rl_2
    name: "Taster Licht 3"
    on_press:
      - switch.turn_on: rl_3
      - delay: 100ms
      - switch.turn_off: rl_3
    name: "Taster Licht 4"
    on_press:
      - switch.turn_on: rl_4
      - delay: 100ms
      - switch.turn_off: rl_4
    name: "Taster Licht 5"
    on_press:
      - switch.turn_on: rl_5
      - delay: 100ms
      - switch.turn_off: rl_5
    name: "Taster Licht 6"
    on_press:
      - switch.turn_on: rl_6
      - delay: 100ms
      - switch.turn_off: rl_6
    name: "Taster Licht 7"
    on_press:
      - switch.turn_on: rl_7
      - delay: 100ms
      - switch.turn_off: rl_7
    name: "Taster Licht 8"
    on_press:
      - switch.turn_on: rl_8
      - delay: 100ms
      - switch.turn_off: rl_8
# 8 Rückmelder (A0..A7) – Status für das Färben der Buttons
binary_sensor:
  - platform: gpio
    name: "Status Licht 1"
    pin: { mcp23xxx: mcp23017_01, number: 0, mode: { input: true, pullup: true }, inverted: true }
    filters: [ delayed_on: 20ms, delayed_off: 20ms ]
  - platform: gpio
    name: "Status Licht 2"
    pin: { mcp23xxx: mcp23017_01, number: 1, mode: { input: true, pullup: true }, inverted: true }
  - platform: gpio
    name: "Status Licht 3"
    pin: { mcp23xxx: mcp23017_01, number: 2, mode: { input: true, pullup: true }, inverted: true }
  - platform: gpio
    name: "Status Licht 4"
    pin: { mcp23xxx: mcp23017_01, number: 3, mode: { input: true, pullup: true }, inverted: true }
  - platform: gpio
    name: "Status Licht 5"
    pin: { mcp23xxx: mcp23017_01, number: 4, mode: { input: true, pullup: true }, inverted: true }
  - platform: gpio
    name: "Status Licht 6"
    pin: { mcp23xxx: mcp23017_01, number: 5, mode: { input: true, pullup: true }, inverted: true }
  - platform: gpio
    name: "Status Licht 7"
    pin: { mcp23xxx: mcp23017_01, number: 6, mode: { input: true, pullup: true }, inverted: true }
  - platform: gpio
    name: "Status Licht 8"
    pin: { mcp23xxx: mcp23017_01, number: 7, mode: { input: true, pullup: true }, inverted: true }
In HA habe ich folgendes DashBoard (falls man das so nennt) per Yaml erstellt. Es zeigt 8 Glühbirnen-Buttons welche bei ausgeschaltetem Relais des CP24 grau sind , bei geschaltetem Relais den Button dann orange färben:
  - title: Lichter
    path: lichter
    icon: mdi:lightbulb-group
    type: panel
    cards:
      - type: grid
        columns: 4
        square: false
        cards:
          - type: button
            icon: mdi:lightbulb
            entity: binary_sensor.nodemcu_conson_status_licht_1
            state_color: true
            show_state: false
            tap_action:
              action: call-service
              service: button.press
                entity_id: button.nodemcu_conson_taster_licht_1
          - type: button
            icon: mdi:lightbulb
            entity: binary_sensor.nodemcu_conson_status_licht_2
            state_color: true
            show_state: false
            tap_action:
                entity_id: button.nodemcu_conson_taster_licht_2
          - type: button
            icon: mdi:lightbulb
            entity: binary_sensor.nodemcu_conson_status_licht_3
            state_color: true
            show_state: false
            tap_action:
                entity_id: button.nodemcu_conson_taster_licht_3
          - type: button
            icon: mdi:lightbulb
            entity: binary_sensor.nodemcu_conson_status_licht_4
            state_color: true
            show_state: false
            tap_action:
                entity_id: button.nodemcu_conson_taster_licht_4
          - type: button
            icon: mdi:lightbulb
            entity: binary_sensor.nodemcu_conson_status_licht_5
            state_color: true
            show_state: false
            tap_action:
                entity_id: button.nodemcu_conson_taster_licht_5
          - type: button
            icon: mdi:lightbulb
            entity: binary_sensor.nodemcu_conson_status_licht_6
            state_color: true
            show_state: false
            tap_action:
                entity_id: button.nodemcu_conson_taster_licht_6
          - type: button
            icon: mdi:lightbulb
            entity: binary_sensor.nodemcu_conson_status_licht_7
            state_color: true
            show_state: false
            tap_action:
                entity_id: button.nodemcu_conson_taster_licht_7
          - type: button
            icon: mdi:lightbulb
            entity: binary_sensor.nodemcu_conson_status_licht_8
            state_color: true
            show_state: false
            tap_action:
                entity_id: button.nodemcu_conson_taster_licht_8
