Moin Bernd,
es geht ja ums ausschalten daher habe ich mal mit einer current state node eine Abfrage davor gesetzt die jeweils den Status ob LAN bzw. WLAN off ist mit einer Zeitverzögerung von 10 Sek. abfragt bevor ausgeschaltet wird.
[{"id":"e4919acee59feec0","type":"tab","label":"Flow 2","disabled":false,"info":"","env":[]},{"id":"44a8a584207d189f","type":"api-call-service","z":"e4919acee59feec0","name":"ST-Computer an","server":"b0a07238.89f4b","version":5,"debugenabled":false,"domain":"homeassistant","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.st_computer"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":510,"y":120,"wires":[[]]},{"id":"1b5410dd82ed7152","type":"api-call-service","z":"e4919acee59feec0","name":"ST-Computer aus","server":"b0a07238.89f4b","version":5,"debugenabled":false,"domain":"homeassistant","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.st_computer"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":670,"y":260,"wires":[[]]},{"id":"0304650f28574a61","type":"comment","z":"e4919acee59feec0","name":"Steckdose \"Laptop Vater LAN\"","info":"","x":210,"y":60,"wires":[]},{"id":"96eced56eb03e7d5","type":"server-state-changed","z":"e4919acee59feec0","name":"Laptop Vater LAN","server":"b0a07238.89f4b","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"device_tracker.laptop_vater","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":270,"y":180,"wires":[["44a8a584207d189f"],["2fd41e268d97fca2"]]},{"id":"35bb03d6a4126418","type":"api-call-service","z":"e4919acee59feec0","name":"ST-Computer an","server":"b0a07238.89f4b","version":5,"debugenabled":false,"domain":"homeassistant","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.st_computer"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":510,"y":380,"wires":[[]]},{"id":"914edb48cc086f74","type":"api-call-service","z":"e4919acee59feec0","name":"ST-Computer","server":"b0a07238.89f4b","version":5,"debugenabled":false,"domain":"homeassistant","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.st_computer"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":640,"y":500,"wires":[[]]},{"id":"6d65682fac682ad8","type":"comment","z":"e4919acee59feec0","name":"Steckdose \"Laptop Vater WLAN\"","info":"","x":190,"y":300,"wires":[]},{"id":"645c333cd8b95d4b","type":"server-state-changed","z":"e4919acee59feec0","name":"Laptop Vater WLAN","server":"b0a07238.89f4b","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"device_tracker.laptop_vater_2","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":270,"y":380,"wires":[["35bb03d6a4126418"],["624b5cc4f53b56df"]]},{"id":"2fd41e268d97fca2","type":"api-current-state","z":"e4919acee59feec0","name":"Prüfung WLAN","server":"cf06b6ae.a4f438","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"device_tracker.laptop_vater_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"10","forType":"num","forUnits":"seconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":440,"y":240,"wires":[["1b5410dd82ed7152"],[]]},{"id":"624b5cc4f53b56df","type":"api-current-state","z":"e4919acee59feec0","name":"Prüfung LAN","server":"cf06b6ae.a4f438","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"device_tracker.laptop_vater","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"10","forType":"num","forUnits":"seconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":410,"y":460,"wires":[["914edb48cc086f74"],[]]},{"id":"b0a07238.89f4b","type":"server","name":"Home Assistant","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"","statusSeparator":"","enableGlobalContextStore":false},{"id":"cf06b6ae.a4f438","type":"server","name":"Home Assistant","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"","statusSeparator":"","enableGlobalContextStore":false}]
Schau mal ob das funktioniert.
Grüße
LL
