Fehler bei fastled_clockless
Hilfe,
kann mir jemand weiterhelfen bekomme immer einen Fehler und
weis nicht woher er kommt…
Neopixel
light:
  • platform: fastled_clockless
    chipset: WS2812B
    pin: GPIO15
    num_leds: 12
    rgb_order: GRB
und zwar: - platform:
vielen Dank
MfG Udo
Probiere mal bitte (ungetestet):
light:
  - platform: neopixelbus
    type: GRB
    variant: WS2812B
    pin: GPIO15
    num_leds: 12
Leider die gleiche Fehlermeldung
nochmal das ganze PRG
esphome:
friendly_name: esp-home
esp8266:
board: esp01_1m
Enable logging
logger:
Enable Home Assistant API
api:
encryption:
key: “z48Nphm2nME42QWVDa2aozzoYqqnwItaS3/+05MEW/8=”
ota:
password: “7dcf7f78d80811ed148e633bc929d981”
wifi:
ssid: !secret wifi_ssid
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Esp-Home Fallback Hotspot”
password: “RpinR963l715”
captive_portal:
switch:
  • name: blau_light
    platform: gpio
    pin: GPIO12
binary_sensor:
  • platform: gpio
    pin: GPIO02
    device_class: motion
    filters:
    • delayed_on: 15s
-licht Sensor D1
  • platform: gpio
    pin: GPIO05
    device_class: light
    filters:
    • invert:
- Themperatur und Feuchte
sensor:
  • platform: dht
    pin: GPIO13
    model: dht11
    temperature:
    name: “Senser Feuchte+Temp” #name: “SenseNode Temp”
    humidity:
    name: “SenseNode Humidity”
    update_interval: 30s
Neopixel
light:
  • platform: neopixelbus
    type: GRB
    variant: WS2812B
    pin: GPIO15
    num_leds: 12
    • random:
      name: “My Fast Random Effect”
      transition_length: 4s
      update_interval: 5s
    • strobe:
      • strobe:
        name: Strobe Effect With Custom Values
        colors:
        - state: true
        brightness: 100%
        red: 100%
        green: 90%
        blue: 0%
        duration: 500ms
        - state: false
        duration: 250ms
        - state: true
        brightness: 100%
        red: 0%
        green: 100%
        blue: 0%
        duration: 500ms
    • addressable_rainbow:
        name: Rainbow Effect With Custom Values
        speed: 10
        width: 50
  • addressable_color_wipe:
      name: Color Wipe Effect With Custom Values
      colors:
      - red: 100%
      green: 100%
      blue: 100%
      num_leds: 1
      - red: 0%
      green: 0%
      blue: 0%
      num_leds: 1
      add_led_interval: 100ms
      reverse: false
Die Fehlermeldung:
ERROR Error while reading config: Invalid YAML syntax:
while parsing a block mapping
in “/config/esphome/esp-home.yaml”, line 66, column 5:
expected , but found ‘-’
in “/config/esphome/esp-home.yaml”, line 73, column 5:
- random:
Danke Udo
@Udo-1955
Bearbeite bitte deinen Beitrag nochmal und setze deinen Code in den </> Tag des Editors…so wie jetzt ist er echt schwer zu lesen. :wink:
Vielen Dank
Habe den Fehler gefunden.
es lag an den zusätzlichen Einträgen…
Sorry
nochmals vielen DANK
MfG Udo
Schön, dass du es hinbekommen hast. :+1:
leider gab es hier kein feedback, wie @Udo-1955 es hinbekommen hat.
Quäle mich auch gerade mit Neopixelbus ab weil offensichtlich dies:
light:
  - platform: fastled_clockless
    chipset: WS2812
    pin: GPIO16
    num_leds: 145
    rgb_order: GRB
mit einem ESP-WROOM-32U nicht richtig funktioniert.
also dann 2. Versuch mit Neopixelbus
light:
    type: GRB
    variant: WS2812
    pin: GPIO16
    num_leds: 145
    default_transition_length: 2s
2 Fragen bitte:
1.) ist der GPIO egal (hier GPIO16)
2.) gibt es bei Neopixel auch Effekte zB Rainbow
