Hi zusammen,
Ich hatte im Keller einen D1 mini und einen Fingerprint Sensor liegen.
Nach etwas googeln fand ich folgende Anleitung den Sensor in meinen HA zu integrieren.
Leider bekomme ich im seriellen Monitor folgende Fehlermeldung:
Welcome to the MQTT Fingerprint Sensor program!
Found fingerprint sensor!
Connecting..........
Connected, IP address: 192.168.178.68
Attempting MQTT connection...connected
Image taken
Could not find fingerprint features
Communication error
Communication error
Communication error
Communication error
im Protokoll von Mosquitto broker in HA steht folgendes:
2026-05-05 21:49:51: New connection from 192.168.178.68:53844 on port 1883.
2026-05-05 21:49:51: Client fingerprint-sensor [192.168.178.68:63527] disconnected: session taken over.
2026-05-05 21:49:51: New client connected from 192.168.178.68:53844 as fingerprint-sensor (p4, c1, k15, u'finger').
2026-05-05 21:50:29: New connection from 172.30.32.2:39424 on port 1883.
2026-05-05 21:50:29: Client 172.30.32.2 [172.30.32.2:39424] disconnected: connection closed by client.
Der Sketch sieht wie folgt aus:
* https://everythingsmarthome.co.uk
* This is an MQTT connected fingerprint sensor which can
* used to connect to your home automation software of choice.
* You can add and remove fingerprints using MQTT topics by
* sending the ID through the topic.
* Simply configure the Wifi and MQTT parameters below to get
* started!
#include <ArduinoJson.h>
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#include <Adafruit_Fingerprint.h>
// Wifi Settings
#define SSID "*******"
#define PASSWORD "*******"
// MQTT Settings
#define HOSTNAME "fingerprint-sensor"
#define MQTT_SERVER "192.168.178.***"
#define STATE_TOPIC "/fingerprint/mode/status"
#define MODE_LEARNING "/fingerprint/mode/learning"
#define MODE_READING "/fingerprint/mode/reading"
#define MODE_DELETE "/fingerprint/mode/delete"
#define AVAILABILITY_TOPIC "/fingerprint/available"
#define mqtt_username "*****"
#define mqtt_password "******"
#define MQTT_INTERVAL 5000 //MQTT rate limiting when no finger present, in ms
#define SENSOR_TX 12 //GPIO Pin for RX
#define SENSOR_RX 14 //GPIO Pin for TX
SoftwareSerial mySerial(SENSOR_TX, SENSOR_RX);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
WiFiClient wifiClient; // Initiate WiFi library
PubSubClient client(wifiClient); // Initiate PubSubClient library
uint8_t id = 0; //Stores the current fingerprint ID
uint8_t lastID = 0; //Stores the last matched ID
uint8_t lastConfidenceScore = 0; //Stores the last matched confidence score
boolean modeLearning = false;
boolean modeReading = true;
boolean modeDelete = false;
unsigned long lastMQTTmsg = 0; //Stores millis since last MQTT message
//Declare JSON variables
DynamicJsonDocument mqttMessage(100);
char mqttBuffer[100];
void setup()
Serial.begin(57600);
while (!Serial);
delay(100);
Serial.println("\n\nWelcome to the MQTT Fingerprint Sensor program!");
// set the data rate for the sensor serial port
finger.begin(57600);
delay(5);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
} else {
Serial.println("Did not find fingerprint sensor :(");
while (1) {
delay(1);
WiFi.mode(WIFI_STA);
WiFi.begin(SSID, PASSWORD);
Serial.print("Connecting...");
while (WiFi.status() != WL_CONNECTED) { // Wait till Wifi connected
delay(500);
Serial.print(".");
Serial.println();
Serial.print("Connected, IP address: ");
Serial.println(WiFi.localIP()); // Print IP address
client.setServer(MQTT_SERVER, 1883); // Set MQTT server and port number
client.setCallback(callback);
void loop() {
if (!client.connected()) {
reconnect(); //Just incase we get disconnected from MQTT server
if (modeReading == true && modeLearning == false) {
uint8_t result = getFingerprintID();
if (result == FINGERPRINT_OK) {
mqttMessage["mode"] = "reading";
mqttMessage["id"] = lastID;
mqttMessage["state"] = "Matched";
mqttMessage["confidence"] = lastConfidenceScore;
size_t mqttMessageSize = serializeJson(mqttMessage, mqttBuffer);
client.publish(STATE_TOPIC, mqttBuffer, mqttMessageSize);
lastMQTTmsg = millis();
delay(500);
} else if (result == FINGERPRINT_NOTFOUND) {
mqttMessage["match"] = false;
mqttMessage["id"] = id;
mqttMessage["state"] = "Not matched";
delay(500);
} else if (result == FINGERPRINT_NOFINGER) {
if ((millis() - lastMQTTmsg) > MQTT_INTERVAL){
mqttMessage["state"] = "Waiting";
if ((millis() - lastMQTTmsg) < 0){
lastMQTTmsg = millis(); //Just in case millis ever rolls over
} else {
client.loop();
delay(100); //don't need to run this at full speed.
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
break;
case FINGERPRINT_NOFINGER:
//Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
break;
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
lastID = finger.fingerID;
lastConfidenceScore = finger.confidence;
return p;
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
return p;
} else {
return p;
// found a match!
Serial.print("Found ID #"); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
return finger.fingerID;
uint8_t getFingerprintEnroll() {
int p = -1;
mqttMessage["mode"] = "learning";
mqttMessage["state"] = "Place finger..";
Serial.print("Waiting for valid finger to enroll as #"); Serial.println(id);
while (p != FINGERPRINT_OK) {
switch (p) {
break;
Serial.print(".");
break;
break;
break;
default:
break;
// OK success!
p = finger.image2Tz(1);
switch (p) {
break;
return p;
return p;
return p;
return p;
default:
return p;
mqttMessage["state"] = "Remove finger..";
Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
Serial.print("ID "); Serial.println(id);
p = -1;
mqttMessage["state"] = "Place same finger..";
Serial.println("Place same finger again");
switch (p) {
break;
Serial.print(".");
break;
break;
break;
default:
break;
// OK success!
p = finger.image2Tz(2);
switch (p) {
break;
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
Serial.print("Creating model for #"); Serial.println(id);
p = finger.createModel();
Serial.println("Prints matched!");
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
} else {
return p;
p = finger.storeModel(id);
mqttMessage["state"] = "Success, stored!";
Serial.println("Stored!");
return true;
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
return p;
} else {
return p;
uint8_t deleteFingerprint() {
uint8_t p = -1;
p = finger.deleteModel(id);
Serial.println("Deleted!");
mqttMessage["mode"] = "deleting";
mqttMessage["state"] = "Deleted!";
return true;
return p;
Serial.println("Could not delete in that location");
return p;
return p;
} else {
Serial.print("Unknown error: 0x"); Serial.println(p, HEX);
return p;
void reconnect() {
while (!client.connected()) { // Loop until connected to MQTT server
Serial.print("Attempting MQTT connection...");
if (client.connect(HOSTNAME, mqtt_username, mqtt_password, AVAILABILITY_TOPIC, 1, true, "offline")) { //Connect to MQTT server
Serial.println("connected");
client.publish(AVAILABILITY_TOPIC, "online"); // Once connected, publish online to the availability topic
client.subscribe(MODE_LEARNING); //Subscribe to Learning Mode Topic
client.subscribe(MODE_READING);
client.subscribe(MODE_DELETE);
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
delay(5000); // Will attempt connection again in 5 seconds
void callback(char* topic, byte* payload, unsigned int length) { //The MQTT callback which listens for incoming messages on the subscribed topics
if (strcmp(topic, MODE_LEARNING) == 0) {
char charArray[3];
for (int i = 0; i < length; i++) {
//Serial.print((char)payload[i]);
charArray[i] = payload[i];
id = atoi(charArray);
if (id > 0 && id < 128) {
Serial.println("Entering Learning mode");
while (!getFingerprintEnroll());
Serial.println("Exiting Learning mode");
modeReading = true;
modeDelete = false;
id = 0;
} else {
Serial.println("No");
Serial.println();
if (strcmp(topic, MODE_DELETE) == 0) {
char charArray[3];
Serial.println("Entering delete mode");
while (! deleteFingerprint());
Serial.println("Exiting delete mode");
delay(2000); //Make the mqttMessage readable in HA
modeReading = true;
modeDelete = false;
id = 0;
Serial.println();
Ich bin leider mit meinem Wissen am Ende, vielleicht kennt sich jemand aus und könnte mir einen Tipp geben?
Viele Grüße!!
