OK, die integration von DWD verwende ich auch. Allerdings hast Du wahrscheinlich die verkehrte, denn ich hab die die auch Deutsch kann. Es ist die Integration wo man die Wetterdaten von einer in der Nähe befindlichen Wetterstation geliefert bekommt. Die sind dann alle in Deutsch und man kann die in node-red ohne Probleme integrieren. Wenn Du das verwenden willst musst Du aber ein paar Einträge ändern. Das ist für unsere Esszimmer die Verschattung.
Bei mir sieht der Flow so aus:
[{"id":"ce83c7be0ecb0f8a","type":"tab","label":"Verschattung EZ Winter","disabled":false,"info":"","env":[]},{"id":"07baf7cbe476cfd3","type":"comment","z":"ce83c7be0ecb0f8a","name":"Verschattung Esszimmer Winter","info":"","x":190,"y":140,"wires":[]},{"id":"809acc0b431d667e","type":"server-state-changed","z":"ce83c7be0ecb0f8a","name":"Azimuth > 250 Grad","server":"49761872cda20bfb","version":6,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["sensor.sun_azimuth"],"substring":[],"regex":[]},"outputInitially":false,"stateType":"num","ifState":"250","ifStateType":"num","ifStateOperator":"gte","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":150,"y":400,"wires":[["3b5ab5df2735735d"],[]]},{"id":"ebabd26bd24d784a","type":"api-call-service","z":"ce83c7be0ecb0f8a","name":"Rollo EZ auf","server":"49761872cda20bfb","version":7,"debugenabled":false,"action":"cover.open_cover","floorId":[],"areaId":[],"deviceId":[],"entityId":["cover.plus2pm"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"cover","service":"open_cover","x":690,"y":400,"wires":[[]]},{"id":"b42a4a886c353ef9","type":"function","z":"ce83c7be0ecb0f8a","name":"Verschattung aktiv setzen","func":"var speicher = flow.get('verschattung_aktiv_ez') || \"Nein\";\nif (speicher===\"Nein\")\n{\n flow.set('verschattung_aktiv_ez',\"Ja\");\n msg.payload=\"Ja\";\n return msg;\n}","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":910,"y":220,"wires":[["9bd9a2d5c17c6d67"]]},{"id":"b3b62cb248c9f8bb","type":"trigger-state","z":"ce83c7be0ecb0f8a","name":"Azimuth zw. 180-250","server":"49761872cda20bfb","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["sensor.sun_azimuth"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":">=","comparatorValueDatatype":"num","comparatorValue":"180"},{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"<=","comparatorValueDatatype":"str","comparatorValue":"250"}],"customOutputs":[],"outputInitially":false,"stateType":"num","enableInput":false,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"x":150,"y":220,"wires":[["7b29807ef6045e4f"],[]]},{"id":"7b29807ef6045e4f","type":"api-current-state","z":"ce83c7be0ecb0f8a","name":"Erw. Temperatur über 10","server":"49761872cda20bfb","version":3,"outputs":2,"halt_if":"10","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.gruenberg_temperatur","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":390,"y":220,"wires":[["fb420cf4eb4a127d","bb2bb7279885498a"],[]]},{"id":"fb420cf4eb4a127d","type":"api-current-state","z":"ce83c7be0ecb0f8a","name":"Wird es Sonnig?","server":"49761872cda20bfb","version":3,"outputs":2,"halt_if":"sunny","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.gruenberg_wetterzustand","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":630,"y":200,"wires":[["b42a4a886c353ef9"],[]]},{"id":"bb2bb7279885498a","type":"api-current-state","z":"ce83c7be0ecb0f8a","name":"Wird es teilweise bedeckt?","server":"49761872cda20bfb","version":3,"outputs":2,"halt_if":"partlycloudy","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.gruenberg_wetterzustand","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","x":660,"y":260,"wires":[["b42a4a886c353ef9"],[]]},{"id":"3b5ab5df2735735d","type":"function","z":"ce83c7be0ecb0f8a","name":"Verschattung deaktiv setzen","func":"var speicher = flow.get('verschattung_aktiv_ez') || \"Nein\";\nif (speicher===\"Ja\")\n{\n flow.set('verschattung_aktiv_ez',\"Nein\");\n msg.payload=\"Nein\";\n return msg;\n}","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":400,"y":400,"wires":[["ebabd26bd24d784a"]]},{"id":"9bd9a2d5c17c6d67","type":"api-call-service","z":"ce83c7be0ecb0f8a","name":"Rollo EZ 75%","server":"49761872cda20bfb","version":7,"debugenabled":false,"action":"cover.set_cover_position","floorId":[],"areaId":[],"deviceId":[],"entityId":["cover.plus2pm"],"labelId":[],"data":"{\t\"position\":25\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"cover","service":"set_cover_position","x":1280,"y":220,"wires":[[]]},{"id":"49761872cda20bfb","type":"server","name":"Hometomanik","version":5,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"id","deviceSelector":"id","entitySelector":"id","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
