Einrichtung EVCC zur PV Überschussladung startet nicht. ANWÄRTER
Hallo liebe Community,
ich freue mich in dieser Community zu sein und lese hier total fleißig mit. Total spannend was ich mit dem HA alles machen kann.
Als ANWÄRTER habe ich mir gleich mal die Erstellung der PV Überschussladung mit mit EVCC vorgenommen.
Anfängerglück hatte ich nicht - eher Verzweifelung.
Wallbox: go-e charger V4
Wechselrichter & PV: SMA
Grid: SMA Homemanager
Batterie über Wechselrichter
Fahrzeug: VW
Sponsortoken ebenso wie alles IPs gelöscht.
Was habe ich bloß nicht geschnallt???
network:
  # schema is the HTTP schema
  # setting to `https` does not enable https, it only changes the way URLs are generated
  schema: http
  # host is the hostname or IP address
  # if the host name contains a `.local` suffix, the name will be announced on MDNS
  # docker: MDNS announcements don't work. host must be set to the docker host's name.
  host: 192.
  # port is the listening port for UI and api
  # evcc will listen on all available interfaces
  port: 7070
interval: 30s # control cycle interval. Interval <30s can lead to unexpected behavior, see https://docs.evcc.io/docs/reference/configuration/interval
# database configuration for persisting charge sessions and settings
# database:
#   type: sqlite
#   dsn: <path-to-db-file>
# sponsor token enables optional features (request at https://sponsor.evcc.io)
# sponsortoken: ey
# telemetry enables aggregated statistics
# Telemetry allows collecting usage data (grid and green energy, charge power).
# Data is aggregated, no individual charging sessions are tracked. The collected,
# anonymous data can be retrieved using https://api.evcc.io.
# See https://github.com/evcc-io/evcc/pull/4343 or details.
# For time being, this is only available to sponsors, hence data is associated with
# the sponsor token's identity.
# telemetry: true
# log settings
log: info
levels:
  site: debug
  lp-1: debug
  lp-2: debug
  cache: error
  db: error
# modbus proxy for allowing external programs to reuse the evcc modbus connection
# each entry will start a proxy instance at the given port speaking Modbus TCP and
# relaying to the given modbus downstream device (either TCP or RTU, RS485 or TCP)
modbusproxy:
  #  - port: 5200
  #    uri: solar-edge:502
  #    # rtu: true
  #    # readonly: true # use `deny` to raise modbus errors
# meter definitions
# name can be freely chosen and is used as reference when assigning meters to site and loadpoints
# for documentation see https://docs.evcc.io/docs/devices/meters
meters:
  - name: my_grid
    type: template
    template: sma-home-manager
    usage: grid
    host: 192
    port: 502
    timeout: 10s
  - name: my_pv
    type: template
    template: sma-hybrid
    usage: pv
    # Modbus TCP
    modbus: tcpip
    host: 192.
    port: 502 # Port
    timeout: 10s
    meters:
  - name: my_battery
    type: template
    usage: battery
    # Modbus TCP
    modbus: tcpip
    host: 192.xxx.xxx.xx # Hostname
    port: 502 # Port
# charger definitions
# name can be freely chosen and is used as reference when assigning charger to vehicle
# for documentation see https://docs.evcc.io/docs/devices/chargers
chargers:
  - name: my_charger
    type: template
    template: go-e-v3
    host: 192.0.0.0. # IP-Adresse oder Hostname
# vehicle definitions
# name can be freely chosen and is used as reference when assigning vehicle to loadpoint
# for documentation see https://docs.evcc.io/docs/devices/vehicles
vehicles:
  - name: my_car
    type: template
    template: vw
    user: # Benutzerkonto (bspw. E-Mail Adresse, User Id, etc.)
    password:# Passwort des Benutzerkontos (bei führenden Nullen bitte in einfache Hochkommata setzen)
    vin:  # Erforderlich, wenn mehrere Fahrzeuge des Herstellers vorhanden sind (optional)
    title: # Wird in der Benutzeroberfläche angezeigt (optional)
    capacity: 58 # Akkukapazität in kWh (optional)
    timeout: 10s # optional
    onIdentify: # set defaults when vehicle is identified
      mode: pv # enable PV-charging when vehicle is identified
# site describes the EVU connection, PV and home battery
site:
  title: Home # display name for UI
  meters:
    grid: my_grid # grid meter
    pv:
      - my_pv # list of pv inverters/ meters
    battery:
      - my_battery # list of battery meters
  residualPower: 100 # additional household usage margin
# loadpoint describes the charger, charge meter and connected vehicle
loadpoints:
  - title: Stellplatz # display name for UI
    charger: my_charger # charger
    meter: charge # external charge meter (if charger has no meter included). NOT grid or pv meter.
    mode: "off" # default charge mode to apply when vehicle is disconnected; use "off" to disable by default if charger is publicly available
    # remaining settings are experts-only and best left at default values
    priority: 0 # relative priority for concurrent charging in PV mode with multiple loadpoints (higher values have higher priority)
    soc:
      # polling defines usage of the vehicle APIs
      # Modifying the default settings it NOT recommended. It MAY deplete your vehicle's battery
      # or lead to vehicle manufacturer banning you from API use. USE AT YOUR OWN RISK.
      poll:
        # poll mode defines under which condition the vehicle API is called:
        #   charging: update vehicle ONLY when charging (this is the recommended default)
        #   connected: update vehicle when connected (not only charging), interval defines how often
        #   always: always update vehicle regardless of connection state, interval defines how often (only supported for single vehicle)
        mode: charging
        # poll interval defines how often the vehicle API may be polled if NOT charging
        interval: 60m
      estimate: true # set false to disable interpolating between api updates (not recommended)
    enable: # pv mode enable behavior
      delay: 1m # threshold must be exceeded for this long
      threshold: 0 # grid power threshold (in Watts, negative=export). If zero, export must exceed minimum charge power to enable
    disable: # pv mode disable behavior
      delay: 3m # threshold must be exceeded for this long
      threshold: 0 # maximum import power (W)
# tariffs are the fixed or variable tariffs
tariffs:
  currency: EUR # three letter ISO-4217 currency code (default EUR)
  grid:
    # either static grid price (or price zones)
    type: fixed
    price: 0.2758 # EUR/kWh
    # see: https://docs.evcc.io/en/docs/devices/tariffs
  feedin:
    # rate for feeding excess (pv) energy to the grid
    type: fixed
    price: 0.08 # EUR/kWh
  co2:
    # co2 tariff provides co2 intensity forecast and is for co2-optimized target charging if no variable grid tariff is specified
    # type: template
    # template: grünstromindex # GrünStromIndex (Germany only)
    # zip: <zip>
    # see: https://docs.evcc.io/en/docs/tariffs#co-forecast
  solar:
    # solar "tariff" provides pv generation forecast
    # - type: template
    #   template: solcast
    #   site: <site>
    #   see: https://docs.evcc.io/en/docs/tariffs#pv-forecast
# mqtt message broker
mqtt:
  # broker: localhost:1883
  # topic: evcc # root topic for publishing, set empty to disable
  # user:
  # password:
# influx database
influx:
  # url: http://localhost:8086
  # database: evcc
  # user:
  # password:
# eebus credentials
eebus:
  # uri: # :4712
  # interfaces: # limit eebus to specific network interfaces
  # - en0
  # certificate: # local signed certificate, required, can be generated via `evcc eebus-cert`
  #   public: # public key
  #   private: # private key
# push messages
messaging:
  events:
    start: # charge start event
      title: Charge started
      msg: Started charging in "${mode}" mode
    stop: # charge stop event
      title: Charge finished
      msg: Finished charging ${chargedEnergy:%.1fk}kWh in ${chargeDuration}.
    connect: # vehicle connect event
      title: Car connected
      msg: "Car connected at ${pvPower:%.1fk}kW PV"
    disconnect: # vehicle connected event
      title: Car disconnected
      msg: Car disconnected after ${connectedDuration}
    soc: # vehicle soc update event
      title: Soc updated
      msg: Battery charged to ${vehicleSoc:%.0f}%
    guest: # vehicle could not be identified
      title: Unknown vehicle
      msg: Unknown vehicle, guest connected?
  services:
  # - type: pushover
  #   app: # app id
  #   recipients:
  #   - # list of recipient ids
  # - type: telegram
  #   token: # bot id
  #   chats:
  #   - # list of chat ids
  # - type: email
  #   uri: smtp://<user>:<password>@<host>:<port>/?fromAddress=<from>&toAddresses=<to>
  # - type: ntfy
  #   uri: https://<host>/<topics>
  #   priority: <priority>
  #   tags: <tags>
SCHON JETZT - Tausend Dank für Eure Hilfe!!!
