Hier der Code von dem Current State mit der Entity:
[{"id":"128a14280e37f7d9","type":"api-current-state","z":"d1e8871f9ceb5888","name":"Sonnenschutz aktivieren","server":"1bd45d83.e2bb52","version":3,"outputs":2,"halt_if":"input_number.grenzwerthelligkeit","halt_if_type":"entity","halt_if_compare":"gte","entity_id":"sensor.helligkeitssensorwg_lux","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":510,"y":340,"wires":[[],[]]},{"id":"1bd45d83.e2bb52","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
Wenn ich das so mache, dann geht er, aber ich kann den Wert dann natürlich nicht mehr anpassen:
[{"id":"128a14280e37f7d9","type":"api-current-state","z":"d1e8871f9ceb5888","name":"Sonnenschutz aktivieren","server":"1bd45d83.e2bb52","version":3,"outputs":2,"halt_if":"1500","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.helligkeitssensorwg_lux","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":510,"y":340,"wires":[[],[]]},{"id":"1bd45d83.e2bb52","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
