Core 2025.12.0 - Die Entität hat keine Zustandsklasse mehr
@petrel Blos gut, das du geschrieben hast, dass auch ein Rollback bei dem Ecowitt-Problem nicht hilft. Hätte ich sonst auch probiert.
@Osorkon Bei mir der gleiche Fehler, und das bei der offiziellen Integration.
We have generated statistics for 'Ereignis-Regenmenge' (sensor.gw1100a_event_rain_rate) in the past, but it no longer has a state class, therefore, we cannot track long term statistics for it anymore.
Statistics cannot be generated until this entity has a supported state class.
    If the state class was previously provided by an integration, this might be a bug. Please report an issue.
    If you previously set the state class yourself, please correct it. The different state classes and when to use which can be found in the developer documentation.
    If the state class has permanently been removed, you may want to delete the long term statistics of it from your database.
Do you want to permanently delete the long term statistics of sensor.gw1100a_event_rain_rate from your database?
Noch habe ich keine Idee, wie man die Statistik behalten kann.
Anderes Thema
Ausserdem wird mein Template für die Fensterstatus-Überwachung angemeckert.
Die alte platform: template-Syntax für sensor wird entfernt. Bitte migriere offene_fenster auf die moderne Template-Syntax.
template:
- sensor:
  - default_entity_id: sensor.offene_fenster
    state: "{% set ns = namespace(count = 0) %} {% for entity_id in [ 'binary_sensor.fenster_bad_contact',
      'binary_sensor.kuchenfenster_door', 'binary_sensor.fenster_waschraum_contact',
      'binary_sensor.fenster_flur_oben_contact', 'binary_sensor.fenster_philipp_contact',
      'binary_sensor.fenster_leon_contact', 'binary_sensor.tur_waschkuche_contact',
      'binary_sensor.fenster_schlafzimmer_contact'] %}\n  {% if is_state(entity_id,
      'on') %}\n    {% set ns.count = ns.count + 1 %}\n  {% endif %}\n{% endfor %}
      {{ ns.count }}"
Was war nioch mal der modern Template-Syntax? Ein Link würde mir schon reichen.
