Brauche Hilfe bei der Suche nach einem Log Eintrag
Bekomme in der Log einen Fehler angezeigt der in einer YAML passiert.
Ich kann diesen YAML Eintrag aber nicht finden.
Kann mir jemand einen Tip geben wo ich Suchen soll?
Logger: homeassistant.helpers.event
Quelle: helpers/template/**init**.py:407
Erstmals aufgetreten: 17:14:30 (1 Vorkommnis)
Zuletzt protokolliert: 17:14:30
Error while processing template: Template<template=({% set x = states(Batterie Ladung Total)|int(0) %} {{ ‘Akku wird geladen’ if x > 0 }} {{ ‘Kein Laden/Entladen’ if x == 0 }} {{ ‘Akku wird entladen’ if x < 0 }}) renders=174>
File “/usr/src/homeassistant/homeassistant/helpers/template/**init**.py”, line 405, in ensure_valid
self.\_compiled_code = self.\_env.compile(self.template)
File “/usr/src/homeassistant/homeassistant/helpers/template/**init**.py”, line 2111, in compile
compiled = super().compile(source)
File “/usr/local/lib/python3.13/site-packages/jinja2/environment.py”, line 771, in compile
self.handle_exception(source=source_hint)
File “/usr/local/lib/python3.13/site-packages/jinja2/environment.py”, line 942, in handle_exception
raise rewrite_traceback_stack(source=source)
File “”, line 1, in template
jinja2.exceptions.TemplateSyntaxError: expected token ‘,’, got ‘Ladung’
The above exception was the direct cause of the following exception:
File “/usr/src/homeassistant/homeassistant/helpers/template/**init**.py”, line 579, in async_render_to_info
render_info.\_result = self.async_render( # noqa: SLF001
variables, strict=strict, log_fn=log_fn, \*\*kwargs
File “/usr/src/homeassistant/homeassistant/helpers/template/**init**.py”, line 455, in async_render
compiled = self.\_compiled or self.\_ensure_compiled(limited, strict, log_fn)
File “/usr/src/homeassistant/homeassistant/helpers/template/**init**.py”, line 660, in \_ensure_compiled
self.ensure_valid()
File “/usr/src/homeassistant/homeassistant/helpers/template/**init**.py”, line 407, in ensure_valid
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: TemplateSyntaxError: expected token ‘,’, got ‘Ladung’
