### System Health details
## System Information
version | core-2025.9.1
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
container_arch | amd64
user | root
virtualenv | false
python_version | 3.13.7
os_name | Linux
os_version | 6.12.43-haos
arch | x86_64
timezone | Europe/Berlin
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
HACS Data | ok
GitHub API Calls Remaining | 5000
Installed Version | 2.0.5
Stage | running
Available Repositories | 2194
Downloaded Repositories | 41
</details>
<details><summary>Solcast Solar</summary>
can_reach_server | ok
</details>
<details><summary>AccuWeather</summary>
error | failed to load: unknown
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | true
subscription_expiration | 24. Oktober 2025 um 02:00
relayer_connected | true
relayer_region | ap-southeast-1
remote_enabled | true
remote_connected | true
alexa_enabled | true
google_enabled | false
cloud_ice_servers_enabled | true
remote_server | eu-central-1-31.ui.nabu.casa
certificate_status | ready
instance_id | 3c12e0fdde554c498b3f74d518a48560
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 16.2
update_channel | stable
supervisor_version | supervisor-2025.09.0
agent_version | 1.7.2
docker_version | 28.3.3
disk_total | 228.5 GB
disk_used | 57.6 GB
nameservers | fd00::9e66:dfcf:73ef:e6bd, 192.168.0.12
healthy | true
supported | true
host_connectivity | true
supervisor_connectivity | true
ntp_synchronized | true
virtualization |
board | generic-x86-64
supervisor_api | ok
version_api | ok
installed_addons | Matter Server (8.1.0), Zigbee2MQTT (2.6.1-1), Mosquitto broker (6.5.2), Samba share (12.5.2), ESPHome Device Builder (2025.8.3), Paperless-ngx (3.0.4), Bambu Lab P1 - Spaghetti Detection Server (1.0.0), Advanced SSH & Web Terminal (21.0.3), SQLite Web (4.4.0), File editor (5.8.0), RaspberryMatic CCU (3.83.6.20250824), Frigate (Full Access) (0.16.1), FTP (5.3.2), ZigStar TI CC2652P/P7 FW Flasher (0.4.1), Home-Assistant-Matter-Hub (3.0.0-alpha.87), MariaDB (2.7.2)
</details>
<details><summary>Dashboards</summary>
dashboards | 6
resources | 27
views | 25
mode | storage
</details>
<details><summary>Network Configuration</summary>
adapters | lo (disabled), eno1 (enabled, default, auto), docker0 (disabled), hassio (disabled), veth999a93c (disabled), vethba1776e (disabled), veth7bf24e1 (disabled), veth14393f6 (disabled), veth104b47d (disabled), vethf57b4a4 (disabled), veth371da02 (disabled), vethbd9d5cb (disabled), veth9647afc (disabled), veth3c087f4 (disabled), veth68b9f3d (disabled), veth5d62134 (disabled), vethff72ea7 (disabled)
ipv4_addresses | lo (127.0.0.1/8), eno1 (192.168.0.4/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), veth999a93c (), vethba1776e (), veth7bf24e1 (), veth14393f6 (), veth104b47d (), vethf57b4a4 (), veth371da02 (), vethbd9d5cb (), veth9647afc (), veth3c087f4 (), veth68b9f3d (), veth5d62134 (), vethff72ea7 ()
ipv6_addresses | lo (::1/128), eno1 (2003:ed:f708:f200:9806:3174:b62e:5a7c/64, fd00::7dac:eb19:7fc:ae67/64, fe80::cb94:6767:91e6:bf53/64), docker0 (fe80::e8f1:d5ff:fed7:abd6/64), hassio (fe80::487e:55ff:fe43:5589/64), veth999a93c (fe80::7840:cff:fea6:8311/64), vethba1776e (fe80::843c:19ff:fe23:7675/64), veth7bf24e1 (fe80::a40b:5cff:febc:1b5d/64), veth14393f6 (fe80::6427:2dff:fea6:ec28/64), veth104b47d (fe80::942a:4fff:fe88:c63a/64), vethf57b4a4 (fe80::8da:e2ff:fe63:9ec0/64), veth371da02 (fe80::bcaa:72ff:fee2:d8eb/64), vethbd9d5cb (fe80::74ca:74ff:fe23:e9a3/64), veth9647afc (fe80::6c02:32ff:fe89:bccb/64), veth3c087f4 (fe80::4e9:59ff:fef1:14cc/64), veth68b9f3d (fe80::58e3:afff:fe36:2609/64), veth5d62134 (fe80::2895:eeff:fe91:fb21/64), vethff72ea7 (fe80::8018:5aff:fe88:8e16/64)
announce_addresses | 192.168.0.4, 2003:ed:f708:f200:9806:3174:b62e:5a7c, fd00::7dac:eb19:7fc:ae67, fe80::cb94:6767:91e6:bf53
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | 27. August 2025 um 08:59
current_recorder_run | 9. September 2025 um 14:08
estimated_db_size | 2753.33 MiB
database_engine | mysql
database_version | 10.11.6
</details>
### Integration version
Version 3.2.3
### Checklist
- [x] I have enabled debug logging for my installation.
- [x] I have filled out the issue template to the best of my ability.
- [x] This issue only contains 1 issue (if you have multiple issues, open one issue for each issue).
- [x] This issue is not a duplicate issue of any [previous issues](https://github.com/ludeeus/integration_blueprint/issues?q=is%3Aissue+label%3A%22Bug%22+)..
### Describe the issue
Since a few weeks the enitities from Anker Solix Integration went to "not available" from time to time.
Error Log:
Dieser Fehler stammt von einer benutzerdefinierten Integration
Logger: custom_components.anker_solix
Quelle: helpers/update_coordinator.py:424
Integration: Anker Solix (Dokumentation, Probleme)
Erstmals aufgetreten: 9. September 2025 um 14:39:53 (35 Vorkommnisse)
Zuletzt protokolliert: 09:51:52
Error fetching anker_solix_luk*** data: Timeout error fetching information:
Error fetching anker_solix_luk*** data: Api Connection Error: Cannot connect to host ankerpower-api-eu.anker.com:443 ssl:default [Timeout while contacting DNS servers]
Meanwhile I know that other users (german forum) have the same problem since a few weeks.
I have already tried to remove the integration from my HA and reload it.
I used different users just to be sure it's not a problem with multiple use of API.
I'm using AdGuard DNS blocker. But I already deactivated it for the HA Client. AdGuard log doesn't show any issues.
I don't know if it's a problem with my setup, a problem with the integration or a problem on Anker side.
BR
Benjamin
### Reproduction steps
Error appears 2-3 times per hour
### Debug logs
```text
2025-09-10 10:07:04.057 DEBUG (MainThread) [custom_components.anker_solix] Api Coordinator luk*** is updating sites
2025-09-10 10:07:04.057 DEBUG (MainThread) [custom_components.anker_solix] Updating api luk*** sites data
2025-09-10 10:07:04.057 DEBUG (MainThread) [custom_components.anker_solix] Getting api luk*** site list
2025-09-10 10:07:04.058 DEBUG (MainThread) [custom_components.anker_solix] Request Url: POST https://ankerpower-api-eu.anker.com/power_service/v1/site/get_site_list
2025-09-10 10:07:04.058 DEBUG (MainThread) [custom_components.anker_solix] Request Headers: {'content-type': 'application/json', 'model-type': 'DESKTOP', 'app-name': 'anker_power', 'os-type': 'android', 'country': 'DE', 'timezone': 'GMT+02:00', 'gtoken': 'cb###masked###f620###masked###ff', 'x-auth-token': 'a7###masked###9fcd###masked###b643###masked###e2'}
2025-09-10 10:07:04.058 DEBUG (MainThread) [custom_components.anker_solix] Request Body: {}
2025-09-10 10:07:05.362 ERROR (MainThread) [custom_components.anker_solix] Error fetching anker_solix_luk*** data: Api Connection Error: Cannot connect to host ankerpower-api-eu.anker.com:443 ssl:default [Timeout while contacting DNS servers]
2025-09-10 10:07:05.362 DEBUG (MainThread) [custom_components.anker_solix] Finished fetching anker_solix_luk*** data in 1.306 seconds (success: False)
2025-09-10 10:08:05.056 DEBUG (MainThread) [custom_components.anker_solix] Api Coordinator luk*** is updating sites
2025-09-10 10:08:05.057 DEBUG (MainThread) [custom_components.anker_solix] Updating api luk*** sites data
2025-09-10 10:08:05.057 DEBUG (MainThread) [custom_components.anker_solix] Getting api luk*** site list
2025-09-10 10:08:05.057 DEBUG (MainThread) [custom_components.anker_solix] Request Url: POST https://ankerpower-api-eu.anker.com/power_service/v1/site/get_site_list
2025-09-10 10:08:05.057 DEBUG (MainThread) [custom_components.anker_solix] Request Headers: {'content-type': 'application/json', 'model-type': 'DESKTOP', 'app-name': 'anker_power', 'os-type': 'android', 'country': 'DE', 'timezone': 'GMT+02:00', 'gtoken': 'cb###masked###f620###masked###ff', 'x-auth-token': 'a7###masked###9fcd###masked###b643###masked###e2'}
2025-09-10 10:08:05.057 DEBUG (MainThread) [custom_components.anker_solix] Request Body: {}
2025-09-10 10:08:05.160 DEBUG (MainThread) [custom_components.anker_solix] Api luk*** request post https://ankerpower-api-eu.anker.com/power_service/v1/site/get_site_list response received
2025-09-10 10:08:05.160 DEBUG (MainThread) [custom_components.anker_solix] Response Headers: <CIMultiDictProxy('Date': 'Wed, 10 Sep 2025 08:08:05 GMT', 'Content-Type': 'application/json; charset=utf-8', 'Content-Length': '403', 'Connection': 'keep-alive', 'Bizcode': '0', 'Trace': 'a4206b263f12d2eda06803d8364dac89', 'Traceparent': '00-a4206b263f12d2eda06803d8364dac89-e599f474e37e7988-00', 'Server': 'APISIX')>
2025-09-10 10:08:05.160 DEBUG (MainThread) [custom_components.anker_solix] Response Data: {'code': 0, 'msg': 'success!', 'data': {'site_list': [{'site_id': '6f9ad912-7473-4d19-a60b-94b467c1c058', 'site_name': 'Solarbank Garage', 'site_img': '', 'device_type_list': [3, 6], 'ms_type': 2, 'power_site_type': 12, 'is_allow_delete': True, 'support_device_models': ['A17C5', 'A17X7', 'SHEM3', 'SHEMP3', 'A17X8', 'SHPPS', 'AE1R0'], 'current_site_device_models': ['SHEM3', 'A17C5']}]}, 'trace_id': 'a4206b263f12d2eda06803d8364dac89'}
2025-09-10 10:08:05.160 DEBUG (MainThread) [custom_components.anker_solix] Getting api luk*** scene info for site
2025-09-10 10:08:05.161 DEBUG (MainThread) [custom_components.anker_solix] Request Url: POST https://ankerpower-api-eu.anker.com/power_service/v1/site/get_scen_info
2025-09-10 10:08:05.161 DEBUG (MainThread) [custom_components.anker_solix] Request Headers: {'content-type': 'application/json', 'model-type': 'DESKTOP', 'app-name': 'anker_power', 'os-type': 'android', 'country': 'DE', 'timezone': 'GMT+02:00', 'gtoken': 'cb###masked###f620###masked###ff', 'x-auth-token': 'a7###masked###9fcd###masked###b643###masked###e2'}
2025-09-10 10:08:05.161 DEBUG (MainThread) [custom_components.anker_solix] Request Body: {'site_id': '6f9ad912-7473-4d19-a60b-94b467c1c058'}
2025-09-10 10:08:05.531 DEBUG (MainThread) [custom_components.anker_solix] Api luk*** request post https://ankerpower-api-eu.anker.com/power_service/v1/site/get_scen_info response received
2025-09-10 10:08:05.531 DEBUG (MainThread) [custom_components.anker_solix] Response Headers: <CIMultiDictProxy('Date': 'Wed, 10 Sep 2025 08:08:05 GMT', 'Content-Type': 'application/json; charset=utf-8', 'Transfer-Encoding': 'chunked', 'Connection': 'keep-alive', 'Bizcode': '0', 'Trace': 'a066b193a80f563d558811cfae0fc0f3', 'Traceparent': '00-a066b193a80f563d558811cfae0fc0f3-c8a4becbc9edd42f-00', 'Server': 'APISIX')>
2025-09-10 10:08:05.532 DEBUG (MainThread) [custom_components.anker_solix] Response Data: {'code': 0, 'msg': 'success!', 'data': {'home_info': {'home_name': 'Home', 'home_img': '', 'charging_power': '0.00', 'power_unit': 'W'}, 'solar_list': [], 'pps_info': {'pps_list': [], 'total_charging_power': '0.00', 'power_unit': 'W', 'total_battery_power': '0.00', 'updated_time': '', 'pps_status': 0}, 'statistics': [{'type': '1', 'total': '689.04', 'unit': 'kWh'}, {'type': '2', 'total': '598.74', 'unit': 'kg'}, {'type': '3', 'total': '158.97', 'unit': '€'}], 'topology_type': '1', 'solarbank_info': {'solarbank_list': [{'device_pn': 'A17C5', 'device_sn': 'APCDJES0F15300019', 'device_name': 'Solarbank 3 E2700 Pro', 'device_img': 'https://public-aiot-fra-prod.s3.dualstack.eu-central-1.amazonaws.com/anker-power/public/product/2025/04/15/iot-admin/6SO8wjMetOwT8PaH/picl_A17C5_normal.png', 'battery_power': '10', 'bind_site_status': '', 'charging_power': '301', 'power_unit': 'W', 'charging_status': '0', 'status': '1', 'wireless_type': '1', 'main_version': '', 'photovoltaic_power': '301', 'output_power': '301', 'create_time': 1749118644, 'set_load_power': '', 'sub_package_num': 0, 'output_cutoff_data': 0, 'is_display': True, 'bat_charge_power': '0', 'pv_name': {'micro_inverter_name': '', 'pv1_name': 'PV1', 'pv2_name': 'PV2', 'pv3_name': 'PV3', 'pv4_name': 'PV4'}, 'pv_power': None, 'feature_switch': {'0w_feed_v2': True, 'enable_parallel': True, 'enable_timeslot': True, 'exceed_power': False, 'heating': False, 'plug_switch_report': True, 'show_third_party_pv_panel': False, 'support_p1_meter': True}, 'heating_power': '0', 'bat_discharge_power': '0', 'err_code': 0}], 'total_charging_power': '0', 'power_unit': 'W', 'charging_status': '0', 'total_battery_power': '0.10', 'updated_time': '2025-09-10 10:07:54', 'total_photovoltaic_power': '301', 'total_output_power': '301.00', 'display_set_power': False, 'battery_discharge_power': '0', 'ac_power': '0', 'to_home_load': '0', 'is_display_data': True, 'solar_power_1': '69', 'solar_power_2': '66', 'solar_power_3': '85', 'solar_power_4': '81', 'other_input_power': '0', 'micro_inverter_power': '166', 'micro_inverter_power_limit': '0', 'micro_inverter_low_power_limit': '0', 'grid_to_battery_power': '0', 'pei_heating_power': '0', 'backup_info': {'start_time': 0, 'end_time': 0, 'full_time': 0}, 'use_time_excute_info': {'current_band': '0'}}, 'retain_load': '200W', 'scene_mode': 1, 'home_load_power': '424', 'updated_time': '01-01-0001 00:00:00', 'power_site_type': 12, 'site_id': '6f9ad912-7473-4d19-a60b-94b467c1c058', 'powerpanel_list': [], 'grid_info': {'grid_list': [{'device_pn': 'SHEM3', 'device_sn': '79530342957156', 'device_name': 'Stromzähler', 'device_img': '', 'create_time': 1749119605, 'status': '1', 'bind_site_status': '', 'wireless_type': ''}], 'photovoltaic_to_grid_power': '0', 'grid_to_home_power': '123', 'grid_status': 0, 'has_history_data': True}, 'is_downgrade': False, 'error_code': 0, 'smart_plug_info': None, 'feature_switch': {'0w_feed_v2': True, 'enable_parallel': True, 'enable_timeslot': True, 'exceed_power': False, 'heating': False, 'plug_switch_report': True, 'show_third_party_pv_panel': False, 'support_p1_meter': True}, 'other_loads_power': '424', 'priority_discharge_switch': 0, 'display_priority_discharge_tips': 0, 'priority_discharge_upgrade_devices': '', 'style_id': 0, 'is_show_priority_discharge': 0, 'solarbank_pps_info': {'pps_list': None, 'total_charging_power': '', 'total_output_power': '', 'total_battery_power': '', 'total_pv_input_power': '', 'total_home_load_power': '', 'total_grid_to_battery': '', 'home': None, 'grid': None, 'system': None}, 'user_scene_mode': 1, 'is_dynamic_price_down_grade': False, 'aiems_profit': {'unit': '€', 'aiems_profit_total': '0.00', 'percentage': '0', 'show_percentage': False, 'aiems_self_use_diff': '0'}, 'switch_0w': 0, 'err_msg': '', 'third_party_pv': '0'}, 'trace_id': 'a066b193a80f563d558811cfae0fc0f3'}
2025-09-10 10:08:05.537 DEBUG (MainThread) [custom_components.anker_solix] Api Coordinator luk*** request statistics: 141 last hour, 2 last minute
2025-09-10 10:08:05.540 DEBUG (MainThread) [custom_components.anker_solix] Coordinator luk*** data: {'6f9ad912-7473-4d19-a60b-94b467c1c058': {'type': 'system', 'site_info': {'site_id': '6f9ad912-7473-4d19-a60b-94b467c1c058', 'site_name': 'Solarbank Garage', 'site_img': '', 'device_type_list': [3, 6], 'ms_type': 2, 'power_site_type': 12, 'is_allow_delete': True, 'support_device_models': ['A17C5', 'A17X7', 'SHEM3', 'SHEMP3', 'A17X8', 'SHPPS', 'AE1R0'], 'current_site_device_models': ['SHEM3', 'A17C5']}, 'site_type': 'solarbank', 'site_admin': False, 'data_valid': True, 'requeries': 0, 'energy_offset_seconds': -425, 'energy_offset_check': '2025-09-10 10:08:05', 'energy_offset_tz': 0, 'home_info': {'home_name': 'Home', 'home_img': '', 'charging_power': '0.00', 'power_unit': 'W'}, 'solar_list': [], 'pps_info': {'pps_list': [], 'total_charging_power': '0.00', 'power_unit': 'W', 'total_battery_power': '0.00', 'updated_time': '', 'pps_status': 0}, 'statistics': [{'type': '1', 'total': '689.04', 'unit': 'kWh'}, {'type': '2', 'total': '598.74', 'unit': 'kg'}, {'type': '3', 'total': '158.97', 'unit': '€'}], 'topology_type': '1', 'solarbank_info': {'solarbank_list': [{'device_pn': 'A17C5', 'device_sn': 'APCDJES0F15300019', 'device_img': 'https://public-aiot-fra-prod.s3.dualstack.eu-central-1.amazonaws.com/anker-power/public/product/2025/04/15/iot-admin/6SO8wjMetOwT8PaH/picl_A17C5_normal.png', 'battery_power': '10', 'bind_site_status': '', 'charging_power': '0', 'power_unit': 'W', 'charging_status': '0', 'status': '1', 'wireless_type': '1', 'main_version': '', 'photovoltaic_power': '301', 'output_power': '301', 'create_time': 1749118644, 'set_load_power': '', 'sub_package_num': 0, 'output_cutoff_data': 0, 'is_display': True, 'bat_charge_power': '0', 'pv_name': {'micro_inverter_name': '', 'pv1_name': 'PV1', 'pv2_name': 'PV2', 'pv3_name': 'PV3', 'pv4_name': 'PV4'}, 'pv_power': None, 'feature_switch': {'0w_feed_v2': True, 'enable_parallel': True, 'enable_timeslot': True, 'exceed_power': False, 'heating': False, 'plug_switch_report': True, 'show_third_party_pv_panel': False, 'support_p1_meter': True}, 'heating_power': '0', 'bat_discharge_power': '0', 'err_code': 0, 'alias_name': 'Solarbank 3 E2700 Pro', 'parallel_home_load': '200', 'current_home_load': '200'}], 'total_charging_power': '0', 'power_unit': 'W', 'charging_status': '0', 'total_battery_power': '0.10', 'updated_time': '2025-09-10 10:07:54', 'total_photovoltaic_power': '301', 'total_output_power': '301.00', 'display_set_power': False, 'battery_discharge_power': '0', 'ac_power': '0', 'to_home_load': '301', 'is_display_data': True, 'solar_power_1': '69', 'solar_power_2': '66', 'solar_power_3': '85', 'solar_power_4': '81', 'other_input_power': '0', 'micro_inverter_power': '166', 'micro_inverter_power_limit': '0', 'micro_inverter_low_power_limit': '0', 'grid_to_battery_power': '0', 'pei_heating_power': '0', 'backup_info': {'start_time': 0, 'end_time': 0, 'full_time': 0}, 'use_time_excute_info': {'current_band': '0'}}, 'retain_load': '200W', 'scene_mode': 1, 'home_load_power': '424', 'updated_time': '01-01-0001 00:00:00', 'power_site_type': 12, 'site_id': '6f9ad912-7473-4d19-a60b-94b467c1c058', 'powerpanel_list': [], 'grid_info': {'grid_list': [{'device_pn': 'SHEM3', 'device_sn': '79530342957156', 'device_name': 'Stromzähler', 'device_img': '', 'create_time': 1749119605, 'status': '1', 'bind_site_status': '', 'wireless_type': ''}], 'photovoltaic_to_grid_power': '0', 'grid_to_home_power': '123', 'grid_status': 0, 'has_history_data': True}, 'is_downgrade': False, 'error_code': 0, 'smart_plug_info': None, 'feature_switch': {'0w_feed_v2': True, 'enable_parallel': True, 'enable_timeslot': True, 'exceed_power': False, 'heating': False, 'plug_switch_report': True, 'show_third_party_pv_panel': False, 'support_p1_meter': True}, 'other_loads_power': '424', 'priority_discharge_switch': 0, 'display_priority_discharge_tips': 0, 'priority_discharge_upgrade_devices': '', 'style_id': 0, 'is_show_priority_discharge': 0, 'solarbank_pps_info': {'pps_list': None, 'total_charging_power': '', 'total_output_power': '', 'total_battery_power': '', 'total_pv_input_power': '', 'total_home_load_power': '', 'total_grid_to_battery': '', 'home': None, 'grid': None, 'system': None}, 'user_scene_mode': 1, 'is_dynamic_price_down_grade': False, 'aiems_profit': {'unit': '€', 'aiems_profit_total': '0.00', 'percentage': '0', 'show_percentage': False, 'aiems_self_use_diff': '0'}, 'switch_0w': 0, 'err_msg': '', 'third_party_pv': '0', 'site_details': {'co2_ranking': {'ranking': '999+', 'co2': '598.73', 'tree': '28.5', 'content': 'Not to be underestimated', 'level': {'tree': 7, 'bubble': 1}}, 'ai_ems_runtime': {'status': 1, 'result': 'fail', 'left_time': -4154727, 'status_desc': 'running'}, 'dynamic_price_details': {'dynamic_price_provider': '-/-/-', 'dynamic_price_fee': '0.17895', 'dynamic_price_vat': '19', 'dynamic_price_total': ''}}, 'energy_details': {'today': {'date': '2025-09-10', 'battery_discharge': '0.00', 'ac_socket': '0.00', 'battery_to_home': '0.00', 'grid_to_battery': '0.00', 'home_usage': '3.30', 'grid_to_home': '2.96', 'smartplugs_total': '0.00', 'solar_production_pv1': '0.07', 'solar_production_pv2': '0.05', 'solar_production_pv3': '0.10', 'solar_production_pv4': '0.06', 'solar_production': '0.35', 'battery_charge': '0.01', 'solar_to_grid': '0.00', 'solar_to_battery': '0.01', 'solar_to_home': '0.34', 'battery_percentage': '0.03', 'solar_percentage': '0.97', 'other_percentage': '0'}, 'last_period': {'date': '2025-09-09', 'battery_discharge': '0.40', 'ac_socket': '0.00', 'battery_to_home': '0.38', 'grid_to_battery': '0.00', 'home_usage': '11.26', 'grid_to_home': '8.30', 'smartplugs_total': '0.00', 'solar_production_pv1': '0.60', 'solar_production_pv2': '0.76', 'solar_production_pv3': '0.78', 'solar_production_pv4': '0.73', 'solar_production': '3.06', 'battery_charge': '0.44', 'solar_to_grid': '0.04', 'solar_to_battery': '0.44', 'solar_to_home': '2.58', 'battery_percentage': '0.14', 'solar_percentage': '0.86', 'other_percentage': '0'}, 'pv_forecast_details': {'trend': [], 'remaining_today': '', 'produced_hourly': [], 'produced_today': '0.35', 'produced_initially': '0.00', 'forecast_today': '', 'forecast_tomorrow': '', 'time_this_hour': '', 'trend_this_hour': '', 'time_next_hour': '', 'trend_next_hour': ''}}}, 'APCDJES0F15300019': {'device_sn': 'APCDJES0F15300019', 'type': 'solarbank', 'site_id': '6f9ad912-7473-4d19-a60b-94b467c1c058', 'is_admin': False, 'device_pn': 'A17C5', 'battery_capacity': '2688', 'generation': 3, 'battery_energy': '268', 'battery_soc': '10', 'charging_power': '0', 'power_unit': 'W', 'charging_status': '0', 'charging_status_desc': 'bypass', 'status': '1', 'status_desc': 'online', 'wireless_type': '1', 'input_power': '301', 'output_power': '301', 'sub_package_num': 0, 'output_cutoff_data': 0, 'bat_charge_power': '0', 'pv_name': {'micro_inverter_name': '', 'pv1_name': 'PV1', 'pv2_name': 'PV2', 'pv3_name': 'PV3', 'pv4_name': 'PV4'}, 'pv_power': None, 'feature_switch': {'0w_feed_v2': True, 'enable_parallel': True, 'enable_timeslot': True, 'exceed_power': False, 'heating': False, 'plug_switch_report': True, 'show_third_party_pv_panel': False, 'support_p1_meter': True}, 'bat_discharge_power': '0', 'err_code': 0, 'alias': 'Solarbank 3 E2700 Pro', 'name': 'Solarbank 3 E2700 Pro', 'set_output_power': '200', 'set_system_output_power': '200', 'data_valid': True, 'solarbank_count': 1, 'solar_power_1': '69', 'solar_power_2': '66', 'solar_power_3': '85', 'solar_power_4': '81', 'ac_power': '0', 'other_input_power': '0', 'grid_to_battery_power': '0', 'pei_heating_power': '0', 'to_home_load': '301'}, '79530342957156': {'device_sn': '79530342957156', 'type': 'smartmeter', 'site_id': '6f9ad912-7473-4d19-a60b-94b467c1c058', 'is_admin': False, 'device_pn': 'SHEM3', 'status': '1', 'status_desc': 'online', 'wireless_type': '', 'alias': 'Stromzähler', 'name': 'Shelly 3EM', 'data_valid': True, 'photovoltaic_to_grid_power': '0', 'grid_to_home_power': '123', 'grid_status': '0', 'grid_status_desc': 'ok'}, 'luka.pischel@gmail.com': {'type': 'account', 'email': 'luka.pischel@gmail.com', 'nickname': 'luk***', 'country': 'DE', 'server': 'https://ankerpower-api-eu.anker.com', 'currency_list': [{'symbol': '$', 'name': 'AUD, CAD, USD'}, {'symbol': 'лв', 'name': 'BGN'}, {'symbol': 'CHF', 'name': 'CHF'}, {'symbol': 'Kč', 'name': 'CZK'}, {'symbol': '€', 'name': 'EUR'}, {'symbol': '£', 'name': 'GBP'}, {'symbol': 'Ft', 'name': 'HUF'}, {'symbol': 'kr', 'name': 'ISK, NOK, SEK'}, {'symbol': '¥', 'name': 'JPY'}, {'symbol': 'zł', 'name': 'PLN'}, {'symbol': 'Lei', 'name': 'RON'}], 'default_currency': {'symbol': '€', 'name': 'EUR'}, 'requests_last_min': 2, 'requests_last_hour': 141, 'products': {'A1780': {'name': '767 PowerHouse (SOLIX F2000)', 'platform': 'Portable Power Station'}, 'A1770': {'name': 'F1200 (Bluetooth)', 'platform': 'Portable Power Station'}, 'A1771': {'name': 'F1200 (Bluetooth and WLAN)', 'platform': 'Portable Power Station'}, 'A1781': {'name': 'SOLIX F2600', 'platform': 'Portable Power Station'}, 'A1772': {'name': 'SOLIX F1500', 'platform': 'Portable Power Station'}, 'A1753': {'name': 'SOLIX C800', 'platform': 'Portable Power Station'}, 'A1790': {'name': 'SOLIX F3800', 'platform': 'Portable Power Station'}, 'A1754': {'name': 'SOLIX C800 Plus', 'platform': 'Portable Power Station'}, 'A1761': {'name': 'SOLIX C1000(X)', 'platform': 'Portable Power Station'}, 'A1722': {'name': 'SOLIX C300', 'platform': 'Portable Power Station'}, 'A1726': {'name': 'SOLIX C300 DC', 'platform': 'Portable Power Station'}, 'A1755': {'name': 'SOLIX C800X', 'platform': 'Portable Power Station'}, 'A1723': {'name': 'SOLIX C300X', 'platform': 'Portable Power Station'}, 'A1729': {'name': 'SOLIX C200X DC', 'platform': 'Portable Power Station'}, 'A1728': {'name': 'SOLIX C300X DC', 'platform': 'Portable Power Station'}, 'A1780P': {'name': '767 Power House (SOLIX F2000) with WLAN', 'platform': 'Portable Power Station'}, 'A1725': {'name': 'SOLIX C200(X)', 'platform': 'Portable Power Station'}, 'A1727': {'name': 'SOLIX C200 DC', 'platform': 'Portable Power Station'}, 'A1790P': {'name': 'SOLIX F3800 Plus', 'platform': 'Portable Power Station'}, 'A1762': {'name': 'Portable Power Station 1000', 'platform': 'Portable Power Station'}, 'A5140': {'name': 'MI60 Microinverter', 'platform': 'Balcony Solar Power System'}, 'A17C1': {'name': 'Solarbank 2 E1600 Pro', 'platform': 'Balcony Solar Power System'}, 'A5143': {'name': 'MI80 Microinverter(BLE)', 'platform': 'Balcony Solar Power System'}, 'A17C0': {'name': 'Solarbank E1600', 'platform': 'Balcony Solar Power System'}, 'A17C5': {'name': 'Solarbank 3 E2700 Pro', 'platform': 'Balcony Solar Power System'}, 'A17C2': {'name': 'Solarbank 2 E1600 AC', 'platform': 'Balcony Solar Power System'}, 'A17C3': {'name': 'Solarbank 2 E1600 Plus', 'platform': 'Balcony Solar Power System'}, 'A17A0': {'name': 'Powered Cooler 30', 'platform': 'Powered Cooler'}, 'A17A1': {'name': 'Powered Cooler 40', 'platform': 'Powered Cooler'}, 'A17A2': {'name': 'Powered Cooler 50', 'platform': 'Powered Cooler'}, 'A17A4': {'name': 'SOLIX Everfrost 2 40L', 'platform': 'Powered Cooler'}, 'A17A5': {'name': 'SOLIX Everfrost 2 58L', 'platform': 'Powered Cooler'}, 'A17A3': {'name': 'SOLIX Everfrost 2 23L', 'platform': 'Powered Cooler'}, 'A5191': {'name': 'V1 Smart EV Charger', 'platform': 'Smart EV Charger'}, 'AE1R0': {'name': 'Anker SOLIX P1 Meter', 'platform': 'Accessory'}, 'A17X7': {'name': 'Smart Meter', 'platform': 'Accessory'}, 'A17X8': {'name': 'Smart Plug', 'platform': 'Accessory'}, 'A2345': {'name': '250W Prime Charger', 'platform': 'Charging Station'}, 'A91B2': {'name': '240W Charging Station', 'platform': 'Charging Station'}, 'A5101': {'name': 'X1-P6K-US/S', 'platform': 'Residential Storage System'}, 'A5341': {'name': 'Backup Controller', 'platform': 'Residential Storage System'}, 'A5150': {'name': 'Microinverter', 'platform': 'Residential Storage System'}, 'A5102': {'name': 'X1-H(3.68~6)K-S', 'platform': 'Residential Storage System'}, 'A5450': {'name': 'Zigbee Dongle', 'platform': 'Residential Storage System'}, 'A5103': {'name': 'X1-H (5~12)K-T', 'platform': 'Residential Storage System'}, 'A5220': {'name': 'Battery Module', 'platform': 'Residential Storage System'}}, 'use_files': False, 'sites_poll_time': '2025-09-10 10:08:05', 'sites_poll_seconds': 0.477, 'vehicle_brands': {'Abarth': {}, 'Aiways': {}, 'Alfa Romeo': {}, 'Alpine': {}, 'Audi': {}, 'BMW': {}, 'BYD': {}, 'Cadillac': {}, 'Citroen': {}, 'CUPRA': {}, 'Dacia': {}, 'Dongfeng': {}, 'DS': {}, 'e.Go': {}, 'Elaris': {}, 'Fiat': {}, 'Firefly': {}, 'Fisker': {}, 'Ford': {}, 'Genesis': {}, 'GWM': {}, 'Honda': {}, 'Hongqi': {}, 'Hyundai': {}, 'JAC': {}, 'Jaguar': {}, 'Jeep': {}, 'KGM': {}, 'Kia': {}, 'Lancia': {}, 'Leapmotor': {}, 'Lexus': {}, 'Lightyear': {}, 'Lotus': {}, 'Lucid': {}, 'Lynk&Co': {}, 'Maserati': {}, 'Maxus': {}, 'Mazda': {}, 'Mercedes-Benz': {}, 'MG': {}, 'Mini': {}, 'Mitsubishi': {}, 'NIO': {}, 'Nissan': {}, 'Omoda': {}, 'Opel': {}, 'Ora': {}, 'Peugeot': {}, 'Polestar': {}, 'Porsche': {}, 'Renault': {}, 'Rolls-Royce': {}, 'SEAT': {}, 'Seres': {}, 'Skoda': {}, 'Skywell': {}, 'Smart': {}, 'Sono': {}, 'Subaru': {}, 'Tesla': {}, 'Toyota': {}, 'VinFast': {}, 'Volkswagen': {}, 'Volvo': {}, 'Voyah': {}, 'XPENG': {}, 'Zeekr': {}, 'cached': True}, 'vehicles_registered': [], 'vehicles': {}, 'details_poll_time': '2025-09-10 10:02:59', 'details_poll_seconds': 0.984, 'has_unread_msg': True, 'system_msg': True, 'device_msg': False, 'price_providers_A17C5': {'date': '2025-09-10', 'country_info': [{'country': 'DE', 'company_info': [{'company': 'Nordpool', 'area_info': [{'area': 'GER', 'area_name': 'GER'}]}]}]}, 'energy_poll_time': '2025-09-10 10:03:02', 'energy_poll_seconds': 2.354}}
2025-09-10 10:08:05.542 INFO (MainThread) [custom_components.anker_solix] Fetching anker_solix_luk*** data recovered
2025-09-10 10:08:05.542 DEBUG (MainThread) [custom_components.anker_solix] Finished fetching anker_solix_luk*** data in 0.486 seconds (success: True)
### Diagnostics dump
_No response_
