[{"id":"6757043e04a06fba","type":"tab","label":"BKW drosseln","disabled":false,"info":"","env":[]},{"id":"8e68eb81f24ac7e0","type":"function","z":"6757043e04a06fba","name":"BKW auf 120W","func":"// MAX generation of the inverter Watts\nvar maxPower = 20;\nvar minPower = 10;\n\n\n// Get current power limit or default\n//var power = minPower;\n//power += msg.payload;\n\n// clamp power between 0 and max\n//if (power > maxPower) power = maxPower;\n//if (power < 0) power = 1;\n\n\n// store current powerlimit and update message\n//context.set('power', power);\nmsg.payload = minPower;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":640,"y":120,"wires":[["b95e0e5a2f3c8cb2","2f95c2a85be3bb83"]]},{"id":"b95e0e5a2f3c8cb2","type":"mqtt out","z":"6757043e04a06fba","name":"WR MQTT","topic":"ahoy-dtu/system/ctrl/limit/0","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"87b2d138566ff5cc","x":890,"y":160,"wires":[]},{"id":"f829f80ffc5ff6c8","type":"function","z":"6757043e04a06fba","name":"BKW auf 600W","func":"// MAX generation of the inverter Watts\nvar maxPower = 20;\nvar minPower = 10;\n\n\n// Get current power limit or default\n//var power = minPower;\n//power += msg.payload;\n\n// clamp power between 0 and max\n//if (power > maxPower) power = maxPower;\n//if (power < 0) power = 1;\n\n\n// store current powerlimit and update message\n//context.set('power', power);\nmsg.payload = maxPower;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":640,"y":180,"wires":[["b95e0e5a2f3c8cb2","2f95c2a85be3bb83"]]},{"id":"2f95c2a85be3bb83","type":"debug","z":"6757043e04a06fba","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":920,"y":280,"wires":[]},{"id":"1de11edbc6a09133","type":"server-state-changed","z":"6757043e04a06fba","name":"Switch Drossel BKW","server":"","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.drossel_bkw","entityidfiltertype":"exact","outputinitially":false,"state_type":"habool","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":160,"y":160,"wires":[["f901c56573a56a6a"]]},{"id":"f901c56573a56a6a","type":"switch","z":"6757043e04a06fba","name":"","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":160,"wires":[["8e68eb81f24ac7e0"],["f829f80ffc5ff6c8"]]},{"id":"6f4b6c2363afbcc8","type":"comment","z":"6757043e04a06fba","name":"","info":"","x":120,"y":60,"wires":[]},{"id":"87b2d138566ff5cc","type":"mqtt-broker","name":"","broker":"192.168.16.254","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
Nachtrag1:
danke dir habs mal versucht
Nachtrag2:
ich hab jetz mal inject nodes drann gehangen am mqqt out doch leider auch dies ohne Erfolg wenn man sie betätigt.
by HarryP: Zusammenführung Mehrfachposting
