Zusammenfassung
{“adapter_concurrent”:null,“adapter_delay”:null,“availability_blacklist”:,“availability_blocklist”:,“availability_passlist”:,“availability_whitelist”:,“cache_state”:true,“cache_state_persistent”:true,“cache_state_send_on_startup”:true,“channel”:11,“elapsed”:false,“ext_pan_id”:[221,221,221,221,221,221,221,221],“last_seen”:“disable”,“legacy_api”:true,“legacy_availability_payload”:true,“log_directory”:“/config/zigbee2mqtt/log/%TIMESTAMP%”,“log_file”:“log.txt”,“log_level”:“debug”,“log_output”:[“console”,“file”],“log_rotation”:true,“log_symlink_current”:false,“log_syslog”:{},“output”:“json”,“pan_id”:6754,“report”:false,“soft_reset_timeout”:0,“timestamp_format”:“YYYY-MM-DD HH:mm:ss”},“availability”:false,“blocklist”:,“device_options”:{},“devices”:{“0x000b57fffef4ad6e”:{“friendly_name”:“Terrassenlicht”},“0x00124b0024fc2ee4”:{“friendly_name”:“Thermometer Wohnzimmer”,“humidity_precision”:1,“temperature_precision”:1},“0x00124b0025103e17”:{“friendly_name”:“Thermometer Schlafzimmer”,“humidity_precision”:1,“temperature_precision”:1},“0x00124b0025133f4e”:{“friendly_name”:“Thermometer Küche”,“humidity_precision”:1,“temperature_precision”:1},“0x00124b002513a031”:{“friendly_name”:“Thermometer Keller”},“0x00124b002514ac1c”:{“friendly_name”:“Kontakt_Terrasse”},“0x00124b002518f1be”:{“friendly_name”:“Kontakt Schlafzimmer”},“0x00124b0025190fb9”:{“friendly_name”:“kontakt”},“0x00124b0025191497”:{“friendly_name”:“Kontakt_Arbeitszimmer”},“0x00124b00251c24f6”:{“friendly_name”:“0x00124b00251c24f6”},“0x00124b00289273e6”:{“friendly_name”:“Bewegungsmelder Schlafzimmer”},“0x00124b002919cce4”:{“friendly_name”:“Bewegungsmelder Keller”},“0x00158d000543b347”:{“friendly_name”:“Thermometer Bad”,“humidity_precision”:1,“optimistic”:true,“pressure_precision”:1,“qos”:0,“temperature_calibration”:0,“temperature_precision”:1},“0x00158d000543fbea”:{“friendly_name”:“Thermometer Außen”},“0x00158d0007e95d23”:{“friendly_name”:“Bewegungsmelder Bad”},“0x00158d0007e968ae”:{“friendly_name”:“Bewegungsmelder Terrasse”,“no_occupancy_since”:,“occupancy_timeout”:90},“0x00158d0007ebb26c”:{“friendly_name”:“Bewegungsmelder Flur”},“0x00158d000804a0a6”:{“friendly_name”:“Thermometer Arbeitszimmer”,“humidity_calibration”:“”,“humidity_precision”:1,“temperature_calibration”:-0.2,“temperature_precision”:1},“0x00158d0008544035”:{“friendly_name”:“Kontakt_Haustür”},“0x00158d0008545788”:{“friendly_name”:“Kontakt_Küche”},“0x04cd15fffedb919e”:{“friendly_name”:“Lampe Flur neu”},“0x2c1165fffe30c5e7”:{“friendly_name”:“Lidl Schalter”},“0x2c1165fffe5146c6”:{“friendly_name”:“Thermostat Arbeitszimmer”},“0x5c0272fffe7f9da3”:{“friendly_name”:“Lidl Steckdose”},“0x7cb03eaa00a9d69d”:{“friendly_name”:“Deckenlampe Bad 1”},“0x7cb03eaa00a9d734”:{“friendly_name”:“Lampe Schlafzimmer”},“0x7cb03eaa00a9d7d9”:{“friendly_name”:“Deckenlampe Bad 2”},“0x8cf681fffe08e0e0”:{“friendly_name”:“Thermostat Badezimmer”},“0x8cf681fffe08e228”:{“friendly_name”:“Thermostat Wohnzimmer”},“0x8cf681fffe08ea6e”:{“friendly_name”:“Thermostat Schlafzimmer”},“0x8cf681fffea88e0a”:{“friendly_name”:“Thermostat Küche”},“0xa4c13847cdd7068c”:{“friendly_name”:“Neue Steckdose 2”,“measurement_poll_interval”:0},“0xa4c1386b85635b4a”:{“friendly_name”:“Licht Bad Spiegel”},“0xa4c138712eb1643b”:{“friendly_name”:“Trockner”},“0xa4c13887a1ad0014”:{“friendly_name”:“Unterschrankbeleuchtung”},“0xa4c138a738ae78cf”:{“friendly_name”:“Waschmaschine_”,“homeassistant”:{},“optimistic”:true,“qos”:1},“0xa4c138c6868da2ca”:{“friendly_name”:“Boiler Küche”,“measurement_poll_interval”:0,“power_calibration”:0,“voltage_calibration”:0},“0xa4c138cf431e59cf”:{“friendly_name”:“Geschirrspüler”},“0xcc86ecfffea0c8bf”:{“friendly_name”:“Lampe Küche neu”},“0xec1bbdfffeb4da7b”:{“friendly_name”:“Bewegungsmelder Wohnzimmer”},“0xec1bbdfffec73f4b”:{“friendly_name”:“Bewegungsmelder Küche”},“0xf0d1b800001884f2”:{“friendly_name”:“Deckenlampe Wohnzimmer 2”},“0xf0d1b8000018e543”:{“friendly_name”:“Lampe Arbeitszimmer”},“0xf0d1b8000018facd”:{“friendly_name”:“Lampe Bett”},“0xf0d1b80000191787”:{“friendly_name”:“Schreibtischlampe”},“0xf0d1b800001917ca”:{“friendly_name”:“Esstisch”},“0xf0d1b80000191d27”:{“friendly_name”:“Beleuchtung Fernseher”},“0xf0d1b80000191f0a”:{“friendly_name”:“Deckenlampe Wohnzimmer 1”}},“experimental”:{},“external_converters”:,“frontend”:{“host”:“0.0.0.0”,“port”:8099},“groups”:{},“homeassistant”:{“discovery_topic”:“homeassistant”,“legacy_entity_attributes”:true,“legacy_triggers”:true,“status_topic”:“hass/status”},“map_options”:{“graphviz”:{“colors”:{“fill”:{“coordinator”:“#e04e5d”,“enddevice”:“#fff8ce”,“router”:“#4ea3e0”},“font”:{“coordinator”:“#ffffff”,“enddevice”:“#000000”,“router”:“#ffffff”},“line”:{“active”:“#009900”,“inactive”:“#994444”}}}},“mqtt”:{“base_topic”:“zigbee2mqtt”,“force_disable_retain”:false,“include_device_information”:false,“server”:“mqtt://core-mosquitto:1883”,“user”:“mqtt-user”},“ota”:{“disable_automatic_update_check”:false,“ikea_ota_use_test_url”:true,“update_check_interval”:1440,“zigbee_ota_override_index_location”:“my_index.json”},“passlist”:,“permit_join”:false,“queue”:{},“serial”:{“disable_led”:false,“port”:“/dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0”}},“config_schema”:{“definitions”:{“device”:{“properties”:{“debounce”:{“description”:“Debounces messages of this device”,“title”:“Debounce”,“type”:“number”},“debounce_ignore”:{“description”:“Protects unique payload values of specified payload properties from overriding within debounce time”,“examples”:[“action”],“items”:{“type”:“string”},“title”:“Ignore debounce”,“type”:“array”},“disabled”:{“description”:“Disables the device (excludes device from network scans, availability and group state updates)”,“requiresRestart”:true,“title”:“Disabled”,“type”:“boolean”},“filtered_attributes”:{“description”:“Filter attributes with regex from published payload.”,“examples”:[“^temperature$”,“^battery$”,“^action$”],“items”:{“type”:“string”},“title”:“Filtered publish attributes”,“type”:“array”},“filtered_cache”:{“description”:“Filter attributes with regex from being added to the cache, this prevents the attribute from being in the published payload when the value didn’t change.”,“examples”:[“^input_actions$”],“items”:{“type”:“string”},“title”:“Filtered attributes from cache”,“type”:“array”},“filtered_optimistic”:{“description”:“Filter attributes with regex from optimistic publish payload when calling /set. (This has no effect if optimistic is set to false).”,“examples”:[“^color_(mode|temp)$”,“color”],“items”:{“type”:“string”},“title”:“Filtered optimistic attributes”,“type”:“array”},“friendly_name”:{“description”:“Used in the MQTT topic of a device. By default this is the device ID”,“readOnly”:true,“title”:“Friendly name”,“type”:“string”},“homeassistant”:{“properties”:{“name”:{“description”:“Name of the device in Home Assistant”,“title”:“Home Assistant name”,“type”:“string”}},“title”:“Home Assistant”,“type”:[“object”,“null”]},“icon”:{“description”:“The user-defined device icon for the frontend. It can be a full URL link to an image (e.g. https://SOME.SITE/MODEL123.jpg) (you cannot use a path to a local file) or base64 encoded data URL (e.g. image/svg+xml;base64,PHN2ZyB3aW…R0aD)”,“title”:“Icon”,“type”:“string”},“optimistic”:{“default”:true,“description”:“Publish optimistic state after set”,“title”:“Optimistic”,“type”:“boolean”},“qos”:{“description”:“QoS level for MQTT messages of this device”,“title”:“QoS”,“type”:“number”},“retain”:{“description”:“Retain MQTT messages of this device”,“title”:“Retain”,“type”:“boolean”},“retention”:{“description”:“Sets the MQTT Message Expiry in seconds, Make sure to set mqtt.version to 5”,“title”:“Retention”,“type”:“number”}},“required”:[“friendly_name”],“type”:“object”},“group”:{“properties”:{“devices”:{“items”:{“type”:“string”},“type”:“array”},“filtered_attributes”:{“items”:{“type”:“string”},“type”:“array”},“friendly_name”:{“type”:“string”},“off_state”:{“default”:“auto”,“description”:“Control when to publish state OFF for a group. ‘all_members_off’: only publish state OFF when all group memebers are in state OFF, ‘last_member_state’: publish state OFF whenever one of its members changes to OFF”,“enum”:[“all_members_off”,“last_member_state”],“requiresRestart”:true,“title”:“Group off state”,“type”:[“string”]},“optimistic”:{“type”:“boolean”},“qos”:{“type”:“number”},“retain”:{“type”:“boolean”}},“required”:[“friendly_name”],“type”:“object”}},“properties”:{“advanced”:{“properties”:{“adapter_concurrent”:{“description”:“Adapter concurrency (e.g. 2 for CC2531 or 16 for CC26X2R1) (default: null, uses recommended value)”,“requiresRestart”:true,“title”:“Adapter concurrency”,“type”:[“number”,“null”]},“adapter_delay”:{“description”:“Adapter delay”,“requiresRestart”:true,“title”:“Adapter delay”,“type”:[“number”,“null”]},“cache_state”:{“default”:true,“description”:“MQTT message payload will contain all attributes, not only changed ones. Has to be true when integrating via Home Assistant”,“title”:“Cache state”,“type”:“boolean”},“cache_state_persistent”:{“default”:true,“description”:“Persist cached state, only used when cache_state: true”,“title”:“Persist cache state”,“type”:“boolean”},“cache_state_send_on_startup”:{“default”:true,“description”:“Send cached state on startup, only used when cache_state: true”,“title”:“Send cached state on startup”,“type”:“boolean”},“channel”:{“default”:11,“description”:“Zigbee channel, changing requires repairing all devices! (Note: use a ZLL channel: 11, 15, 20, or 25 to avoid Problems)”,“examples”:[15,20,25],“maximum”:26,“minimum”:11,“requiresRestart”:true,“title”:“ZigBee channel”,“type”:“number”},“elapsed”:{“default”:false,“description”:“Add an elapsed attribute to MQTT messages, contains milliseconds since the previous msg”,“title”:“Elapsed”,“type”:“boolean”},“ext_pan_id”:{“description”:“Zigbee extended pan ID, changing requires repairing all devices!”,“items”:{“type”:“number”},“requiresRestart”:true,“title”:“Ext Pan ID”,“type”:“array”},“last_seen”:{“default”:“disable”,“description”:“Add a last_seen attribute to MQTT messages, contains date/time of last Zigbee message”,“enum”:[“disable”,“ISO_8601”,“ISO_8601_local”,“epoch”],“title”:“Last seen”,“type”:“string”},“legacy_api”:{“default”:true,“description”:“Disables the legacy api (false = disable)”,“requiresRestart”:true,“title”:“Legacy API”,“type”:“boolean”},“legacy_availability_payload”:{“default”:true,“description”:“Payload to be used for device availabilty and bridge/state topics. true = text, false = JSON”,“requiresRestart”:true,“title”:“Legacy availability payload”,“type”:“boolean”},“log_directory”:{“description”:“Location of log directory”,“examples”:[“data/log/%TIMESTAMP%”],“requiresRestart”:true,“title”:“Log directory”,“type”:“string”},“log_file”:{“default”:“log.txt”,“description”:“Log file name, can also contain timestamp”,“examples”:[“zigbee2mqtt_%TIMESTAMP%.log”],“requiresRestart”:true,“title”:“Log file”,“type”:“string”},“log_level”:{“default”:“info”,“description”:“Logging level”,“enum”:[“info”,“warn”,“error”,“debug”],“title”:“Log level”,“type”:“string”},“log_output”:{“description”:“Output location of the log, leave empty to suppress logging”,“items”:{“enum”:[“console”,“file”,“syslog”],“type”:“string”},“requiresRestart”:true,“title”:“Log output”,“type”:“array”},“log_rotation”:{“default”:true,“description”:“Log rotation”,“requiresRestart”:true,“title”:“Log rotation”,“type”:“boolean”},“log_symlink_current”:{“default”:false,“description”:“Create symlink to current logs in the log directory”,“requiresRestart”:true,“title”:“Log symlink current”,“type”:“boolean”},“log_syslog”:{“properties”:{“app_name”:{“default”:“Zigbee2MQTT”,“description”:“The name of the application (Default: Zigbee2MQTT).”,“title”:“Localhost”,“type”:“string”},“eol”:{“default”:“/n”,“description”:“The end of line character to be added to the end of the message (Default: Message without modifications).”,“title”:“eol”,“type”:“string”},“host”:{“default”:“localhost”,“description”:“The host running syslogd, defaults to localhost.”,“title”:“Host”,“type”:“string”},“localhost”:{“default”:“localhost”,“description”:“Host to indicate that log messages are coming from (Default: localhost).”,“title”:“Localhost”,“type”:“string”},“path”:{“default”:“/dev/log”,“description”:“The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).”,“examples”:[“/var/run/syslog”],“title”:“Path”,“type”:“string”},“pid”:{“default”:“process.pid”,“description”:“PID of the process that log messages are coming from (Default process.pid).”,“title”:“PID”,“type”:“string”},“port”:{“default”:514,“description”:“The port on the host that syslog is running on, defaults to syslogd’s default port.”,“title”:“Port”,“type”:“number”},“protocol”:{“default”:“udp4”,“description”:“The network protocol to log over (e.g. tcp4, udp4, tls4, unix, unix-connect, etc).”,“examples”:[“udp4”,“tls4”,“unix”,“unix-connect”],“title”:“Protocol”,“type”:“string”},“type”:{“default”:“5424”,“description”:“The type of the syslog protocol to use (Default: BSD, also valid: 5424).”,“title”:“Type”,“type”:“string”}},“title”:“syslog”,“type”:“object”},“network_key”:{“description”:“Network encryption key, changing requires repairing all devices!”,“oneOf”:[{“title”:“Network key(string)”,“type”:“string”},{“items”:{“type”:“number”},“title”:“Network key(array)”,“type”:“array”}],“requiresRestart”:true,“title”:“Network key”},“output”:{“description”:“Examples when ‘state’ of a device is published json: topic: ‘zigbee2mqtt/my_bulb’ payload ‘{"state": "ON"}’ attribute: topic ‘zigbee2mqtt/my_bulb/state’ payload ‘ON’ attribute_and_json: both json and attribute (see above)”,“enum”:[“attribute_and_json”,“attribute”,“json”],“title”:“MQTT output type”,“type”:“string”},“pan_id”:{“description”:“ZigBee pan ID, changing requires repairing all devices!”,“oneOf”:[{“title”:“Pan ID (string)”,“type”:“string”},{“title”:“Pan ID (number)”,“type”:“number”}],“requiresRestart”:true,“title”:“Pan ID”},“timestamp_format”:{“description”:“Log timestamp format”,“examples”:[“YYYY-MM-DD HH:mm:ss”],“requiresRestart”:true,“title”:“Timestamp format”,“type”:“string”},“transmit_power”:{“description”:“Transmit power of adapter, only available for Z-Stack (CC253*/CC2652/CC1352) adapters, CC2652 = 5dbm, CC1352 max is = 20dbm (5dbm default)”,“requiresRestart”:true,“title”:“Transmit power”,“type”:[“number”,“null”]}},“title”:“Advanced”,“type”:“object”},“availability”:{“description”:“Checks whether devices are online/offline”,“oneOf”:[{“title”:“Availability (simple)”,“type”:“boolean”},{“properties”:{“active”:{“description”:“Options for active devices (routers/mains powered)”,“properties”:{“timeout”:{“default”:10,“description”:“Time after which an active device will be marked as offline in minutes”,“requiresRestart”:true,“title”:“Timeout”,“type”:“number”}},“requiresRestart”:true,“title”:“Active”,“type”:“object”},“passive”:{“description”:“Options for passive devices (mostly battery powered)”,“properties”:{“timeout”:{“default”:1500,“description”:“Time after which an passive device will be marked as offline in minutes”,“requiresRestart”:true,“title”:“Timeout”,“type”:“number”}},“requiresRestart”:true,“title”:“Passive”,“type”:“object”}},“title”:“Availability (advanced)”,“type”:“object”}],“requiresRestart”:true,“title”:“Availability”},“ban”:{“items”:{“type”:“string”},“readOnly”:true,“requiresRestart”:true,“title”:“Ban (deprecated, use blocklist)”,“type”:“array”},“blocklist”:{“description”:“Block devices from the network (by ieeeAddr)”,“items”:{“type”:“string”},“requiresRestart”:true,“title”:“Blocklist”,“type”:“array”},“device_options”:{“title”:“Options that are applied to all devices”,“type”:“object”},“devices”:{“patternProperties”:{“^.$“:{”$ref":“#/definitions/device”}},“propertyNames”:{“pattern”:“^0x[\d\w]{16}$”},“type”:“object”},“external_converters”:{“description”:“You can define external converters to e.g. add support for a DiY device”,“examples”:[“DIYRuZ_FreePad.js”],“items”:{“type”:“string”},“requiresRestart”:true,“title”:“External converters”,“type”:“array”},“frontend”:{“oneOf”:[{“title”:“Frontend (simple)”,“type”:“boolean”},{“properties”:{“auth_token”:{“description”:“Enables authentication, disabled by default”,“requiresRestart”:true,“title”:“Auth token”,“type”:[“string”,“null”]},“host”:{“default”:“0.0.0.0”,“description”:“Frontend binding host”,“requiresRestart”:true,“title”:“Bind host”,“type”:“string”},“port”:{“default”:8080,“description”:“Frontend binding port”,“requiresRestart”:true,“title”:“Port”,“type”:“number”},“ssl_cert”:{“description”:“SSL Certificate file path for exposing HTTPS. The sibling property ‘ssl_key’ must be set for HTTPS to be activated.”,“requiresRestart”:true,“title”:“Certificate file path”,“type”:[“string”,“null”]},“ssl_key”:{“description”:“SSL key file path for exposing HTTPS. The sibling property ‘ssl_cert’ must be set for HTTPS to be activated.”,“requiresRestart”:true,“title”:“key file path”,“type”:[“string”,“null”]},“url”:{“description”:“URL on which the frontend can be reached, currently only used for the Home Assistant device configuration page”,“requiresRestart”:true,“title”:“URL”,“type”:[“string”,“null”]}},“title”:“Frontend (advanced)”,“type”:“object”}],“requiresRestart”:true,“title”:“Frontend”},“groups”:{“patternProperties”:{"^.$”:{“$ref”:“#/definitions/group”}},“propertyNames”:{“pattern”:“.*$”},“type”:“object”},“homeassistant”:{“default”:false,“description”:“Home Assistant integration (MQTT discovery)”,“oneOf”:[{“title”:“Home Assistant (simple)”,“type”:“boolean”},{“properties”:{“discovery_topic”:{“description”:“Home Assistant discovery topic”,“examples”:[“homeassistant”],“requiresRestart”:true,“title”:“Homeassistant discovery topic”,“type”:“string”},“legacy_entity_attributes”:{“default”:true,“description”:“Home Assistant legacy entity attributes, when enabled Zigbee2MQTT will add state attributes to each entity, additional to the separate entities and devices it already creates”,“title”:“Home Assistant legacy entity attributes”,“type”:“boolean”},“legacy_triggers”:{“default”:true,“description”:“Home Assistant legacy triggers, when enabled Zigbee2mqt will send an empty ‘action’ or ‘click’ after one has been send. A ‘sensor_action’ and ‘sensor_click’ will be discoverd”,“title”:“Home Assistant legacy triggers”,“type”:“boolean”},“status_topic”:{“description”:“Home Assistant status topic”,“examples”:[“homeassistant/status”],“requiresRestart”:true,“title”:“Home Assistant status topic”,“type”:“string”}},“title”:“Home Assistant (advanced)”,“type”:“object”}],“requiresRestart”:true,“title”:“Home Assistant integration”},“map_options”:{“properties”:{“graphviz”:{“properties”:{“colors”:{“properties”:{“fill”:{“properties”:{“coordinator”:{“type”:“string”},“enddevice”:{“type”:“string”},“router”:{“type”:“string”}},“type”:“object”},“font”:{“properties”:{“coordinator”:{“type”:“string”},“enddevice”:{“type”:“string”},“router”:{“type”:“string”}},“type”:“object”},“line”:{“properties”:{“active”:{“type”:“string”},“inactive”:{“type”:“string”}},“type”:“object”}},“type”:“object”}},“type”:“object”}},“title”:“Networkmap”,“type”:“object”},“mqtt”:{“properties”:{“base_topic”:{“default”:“zigbee2mqtt”,“description”:“MQTT base topic for Zigbee2MQTT MQTT messages”,“examples”:[“zigbee2mqtt”],“requiresRestart”:true,“title”:“Base topic”,“type”:“string”},“ca”:{“description”:“Absolute path to SSL/TLS certificate of CA used to sign server and client certificates”,“examples”:[“/etc/ssl/mqtt-ca.crt”],“requiresRestart”:true,“title”:“Certificate authority”,“type”:“string”},“cert”:{“description”:“Absolute path to SSL/TLS certificate for client-authentication”,“examples”:[“/etc/ssl/mqtt-client.crt”],“requiresRestart”:true,“title”:“SSL/TLS certificate”,“type”:“string”},“client_id”:{“description”:“MQTT client ID”,“examples”:[“MY_CLIENT_ID”],“requiresRestart”:true,“title”:“Client ID”,“type”:“string”},“force_disable_retain”:{“default”:false,“description”:"Disable retain for all send messages. ONLY enable if you MQTT broker doesn’t support retained message
History1
Publish
Topic
rawxmljson
PUBLISH
