Hallo zusammen
ich finde keinen call service oder anderes
Domain
Service
Area
Device
bleibt leer
was ist hier los
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 17.0.6
You are running the latest version of this add-on.
System: Home Assistant OS 11.5 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2024.2.1
Home Assistant Supervisor: 2024.01.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
s6-rc: info: service init-nginx successfully started
up to date, audited 141 packages in 10s
36 packages are looking for funding
run `npm fund` for details
13 vulnerabilities (2 low, 6 high, 5 critical)
To address all issues possible (including breaking changes), run:
npm audit fix --force
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
npm notice
npm notice New minor version of npm available! 10.2.3 -> 10.4.0
npm notice Changelog: <https://github.com/npm/cli/releases/tag/v10.4.0>
npm notice Run `npm install -g npm@10.4.0` to update!
npm notice
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[13:31:30] INFO: Starting Node-RED...
> start
> node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
11 Feb 13:31:35 - [info]
Welcome to Node-RED
11 Feb 13:31:35 - [info] Node-RED version: v3.1.5
11 Feb 13:31:35 - [info] Node.js version: v18.19.0
11 Feb 13:31:35 - [info] Linux 6.1.63-haos-raspi arm64 LE
11 Feb 13:31:36 - [info] Loading palette nodes
11 Feb 13:31:38 - [info] Node-RED Contrib Theme Collection version: v3.1.9
11 Feb 13:31:43 - [info] Dashboard version 3.6.2 started at /endpoint/ui
11 Feb 13:31:45 - [info] Settings file : /etc/node-red/config.js
11 Feb 13:31:45 - [info] Context store : 'default' [module=memory]
11 Feb 13:31:45 - [info] User directory : /config/
11 Feb 13:31:45 - [warn] Projects disabled : editorTheme.projects.enabled=false
11 Feb 13:31:45 - [info] Flows file : /config/flows.json
Your flow credentials file is encrypted using a system-generated key.
If the system-generated key is lost for any reason, your credentials
file will not be recoverable, you will have to delete it and re-enter
your credentials.
You should set your own key using the 'credentialSecret' option in
your settings file. Node-RED will then re-encrypt your credentials
file using your chosen key the next time you deploy a change.
11 Feb 13:31:45 - [warn] Encrypted credentials not found
11 Feb 13:31:45 - [info] Server now running at http://127.0.0.1:46836/
11 Feb 13:31:45 - [info] Starting flows
11 Feb 13:31:45 - [info] Started flows
[13:31:45] INFO: Starting NGinx...
11 Feb 13:31:50 - [info] [server:Home Assistant] Connecting to http://supervisor/core
11 Feb 13:31:50 - [info] [server:Home Assistant] Connected to http://supervisor/core
