Node-red Startet ohne internet nicht
mal eine blöde frage,
Habe auf dem HA auch Node-Red am laufen.
Was mir da auffällt ist das Node nicht startet wenn kein internet vorhanden ist.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
 Add-on: Node-RED
 Flow-based programming for the Internet of Things
 Add-on version: 17.0.6
 You are running the latest version of this add-on.
 System: Home Assistant OS 11.5  (amd64 / generic-x86-64)
 Home Assistant Core: 2024.2.1
 Home Assistant Supervisor: 2024.01.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
fetch https://dl-cdn.alpinelinux.org/alpine/v3.19/main/x86_64/APKINDEX.tar.gz
s6-rc: info: service init-nginx successfully started
WARNING: updating and opening https://dl-cdn.alpinelinux.org/alpine/v3.19/main: temporary error (try again later)
fetch https://dl-cdn.alpinelinux.org/alpine/v3.19/community/x86_64/APKINDEX.tar.gz
WARNING: updating and opening https://dl-cdn.alpinelinux.org/alpine/v3.19/community: temporary error (try again later)
4 unavailable, 0 stale; 44 distinct packages available
[17:43:13] FATAL: Failed updating Alpine packages repository indexes
s6-rc: warning: unable to start service init-customizations: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service init-nginx: stopping
s6-rc: info: service init-nginx successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
gibt es dazu irgendwelche infos?
Lg Mike
