Matter Hub Bad Gateway 502
Hallo Zusammen,
ich habe den Matter Hub installiert. Das Add-on lässt sich auch starten.
Sobald ich die Web-Oberfläche aufrufe stoppt Matter hub und auf meinem Display ist ein schwarzer Bildschirm mit Bad Gateway 502.
Hab auch Matter Hub auch schon deinstalliert und neu installiert. Neustarts hab ich auch schon gemacht.
Protokoll sieht so aus.
Add-on: Home-Assistant-Matter-Hub
Publish your entities from Home Assistant to any Matter-compatible controller like Alexa, Apple Home or Google Home.
Add-on version: 3.0.0-alpha.87
You are running the latest version of this add-on.
System: Home Assistant OS 16.0 (aarch64 / raspberrypi5-64)
Home Assistant Core: 2025.7.1
Home Assistant Supervisor: 2025.07.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
# Fatal error in , line 0
# Check failed: VerifyChecksum(blob).
#FailureMessage Object: 0x7ffe3c0ee8
Trace/breakpoint trap (core dumped)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Habe das gleiche Problem.
Trotz seit dem letzten HA OS Update auf.
Habe aber leider auch keine Lösung dafür
