Ich kriegs nicht hin.
Gibt es irgendwo eine Anleitung für den totalen DAU?
Ich denke, ich mache alles nach den readmes auf github.
Ich habe einen venus e 2 und einen b2500 wlan mäßig umgestellt.
marsrelay zeigt auch
[MQTT:079]
Received control message: marstek_energy/HMG-50/App/009b0878xxxx/ctrl
05:13:07
[D]
[MQTT:079]
Received control message: marstek_energy/HMJ-3/App/7f2f979ff3cf70034ac98a1c6f2fxxxx/ctrl
05:13:07
Nachrichten.
Die Werte (beim 2500 die mac) trage ich in die hm2mqtt config ein.
Diese startet auch, connectet zum Broker, erkennt die Devices, legt die Topics und Entitäten an,
published die Discoverys, zeigt dann aber:
[03:22:20] DEBUG: Published discovery config to homeassistant/sensor/HMJ-3_18cedfd2xxxx/calibration_discharge/config
[03:22:20] DEBUG: Published to hame_energy/HMG-50/App/009b0878xxxx/ctrl: cd=14
[03:22:20] DEBUG: Published to marstek_energy/HMG-50/App/009b0878xxxx/ctrl: cd=14
[03:22:20] DEBUG: Published to hame_energy/HMJ-3/App/18cedfd2xxxx/ctrl: cd=16
[03:22:20] DEBUG: Published to marstek_energy/HMJ-3/App/7f2f979ff3cf70034ac98a1c6f2fxxxx/ctrl: cd=16
[03:22:21] DEBUG: Published to hame_energy/HMJ-3/App/18cedfd2xxxx/ctrl: cd=13
[03:22:21] DEBUG: Published to marstek_energy/HMJ-3/App/7f2f979ff3cf70034ac98a1c6f2fxxxx/ctrl: cd=13
[03:22:21] DEBUG: Published to hame_energy/HMJ-3/App/18cedfd2xxxx/ctrl: cd=21
[03:22:21] DEBUG: Published to marstek_energy/HMJ-3/App/7f2f979ff3cf70034ac98a1c6f2fxxxx/ctrl: cd=21
[03:22:50] WARN: No response received from 009b0878xxxx within timeout period
[03:22:50] WARN: No response received from 18cedfd2xxxx within timeout period
[03:23:20] DEBUG: Published to hame_energy/HMG-50/App/009b0878xxxx/ctrl: cd=1
[03:23:20] DEBUG: Published to marstek_energy/HMG-50/App/009b0878xxxx/ctrl: cd=1
[03:23:20] DEBUG: Published to hame_energy/HMJ-3/App/18cedfd2xxxx/ctrl: cd=1
[03:23:20] DEBUG: Published to marstek_energy/HMJ-3/App/7f2f979ff3cf70034ac98a1c6f2fxxxx/ctrl: cd=1
[03:23:20] DEBUG: Published to hame_energy/HMG-50/App/009b0878xxxx/ctrl: cd=14
Was zum Geier mach ich falsch?
Ich hab auch schon den Proxy angeschaltet, keine Änderung.
Firmwares sind 116.6 beim b2500 und 153 beim venus.
Kann mir jemand zumindest bestätigen, dass es nicht an meinen Firmwareversionen liegt?
Zumindest im Hinblick auf hm2mqtt, denn das hat auch mit hame-relay schon nicht funktioniert.
Laut Marstek sind meine Firmwares die Neuesten.
