Habe heute das aktuellste Core-Update installiert und nun läuft Homeamatic-IP nicht mehr. Bei allen Sensoren steht nicht Verfügbar. Bei der Integration: nicht gestartet. Im Protokoll steht:
Logger: homeassistant.util.loop Quelle: util/loop.py:77 Erstmals aufgetreten: 16:27:34 (1 Vorkommnis) Zuletzt protokolliert: 16:27:34 Detected blocking call to import_module with args ('custom_components.homematicip_local',) in /usr/src/homeassistant/homeassistant/loader.py, line 1078: ComponentProtocol, importlib.import_module(self.pkg_path) inside the event loop; This is causing stability issues. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#import_module Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 229, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 215, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 289, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.13/asyncio/base_events.py", line 712, in run_until_complete self.run_forever() File "/usr/local/lib/python3.13/asyncio/base_events.py", line 683, in run_forever self._run_once() File "/usr/local/lib/python3.13/asyncio/base_events.py", line 2050, in _run_once handle._run() File "/usr/local/lib/python3.13/asyncio/events.py", line 89, in _run self._context.run(self._callback, *self._args) File "/usr/src/homeassistant/homeassistant/setup.py", line 170, in async_setup_component result = await _async_setup_component(hass, domain, config) File "/usr/src/homeassistant/homeassistant/setup.py", line 343, in _async_setup_component component = await integration.async_get_component() File "/usr/src/homeassistant/homeassistant/loader.py", line 1030, in async_get_component comp = self._get_component() File "/usr/src/homeassistant/homeassistant/loader.py", line 1078, in _get_component ComponentProtocol, importlib.import_module(self.pkg_path)
Habe open Chu neu gestartet und auch versucht die Integration neu zu starten, konnte aber nichts finden. Habe HA komplett neu gestartet. Also nicht nur HA Neustart sondern kompletten Systemneustart. Hat nichts geändert. Ich weiß nicht was mir der Logeintrag sagen möchte? Liegt das evtl. am Cor-Update?
