ESPHome 3x 18s20 keine Entitäten zu finden?
Mein ESPHome Script funktioniert (siehe log) aber ich finde die Entitäten nicht im HA??
Was habe ich übersehen?
captive_portal:
# Example configuration entry
dallas:
  - pin: 12
sensor:
  - platform: dallas
    address: 0xab03213152da4228
    unit_of_measurement: °C
    accuracy_decimals: 1
  - platform: dallas
    address: 0x80012062ea515a28
  - platform: dallas
    address: 0xc103213189901528
LOG
[19:37:34][D][dallas.sensor:082]:   Found sensors:
[19:37:34][D][dallas.sensor:084]:     0xab03213152da4228
[19:37:34][D][dallas.sensor:084]:     0x80012062ea515a28
[19:37:34][D][dallas.sensor:084]:     0xc103213189901528
[19:37:34][C][dallas.sensor:089]:   Device 'Vorlauf HK'
[19:37:34][C][dallas.sensor:089]:     Device Class: 'temperature'
[19:37:34][C][dallas.sensor:089]:     State Class: 'measurement'
[19:37:34][C][dallas.sensor:089]:     Unit of Measurement: '°C'
[19:37:34][C][dallas.sensor:089]:     Accuracy Decimals: 1
[19:37:34][C][dallas.sensor:097]:     Address: 0xab03213152da4228
[19:37:34][C][dallas.sensor:098]:     Resolution: 12
[19:37:34][C][dallas.sensor:089]:   Device 'Boiler'
[19:37:34][C][dallas.sensor:097]:     Address: 0x80012062ea515a28
[19:37:34][C][dallas.sensor:089]:   Device 'Rücklauf HK'
[19:37:34][C][dallas.sensor:097]:     Address: 0xc103213189901528
[19:37:34][C][captive_portal:088]: Captive Portal:
[19:37:34][C][mdns:115]: mDNS:
[19:37:34][C][mdns:116]:   Hostname: heizkeller
[19:37:34][C][ota:096]: Over-The-Air Updates:
[19:37:34][C][ota:097]:   Address: heizkeller.local:8266
[19:37:34][C][ota:100]:   Using Password.
[19:37:34][C][ota:103]:   OTA version: 2.
[19:37:34][C][api:139]: API Server:
[19:37:34][C][api:140]:   Address: heizkeller.local:6053
[19:37:34][C][api:142]:   Using noise encryption: YES
[19:37:34][D][dallas.sensor:143]: 'Vorlauf HK': Got Temperature=34.6°C
[19:37:34][D][sensor:093]: 'Vorlauf HK': Sending state 34.56250 °C with 1 decimals of accuracy
[19:37:34][D][dallas.sensor:143]: 'Boiler': Got Temperature=57.1°C
[19:37:34][D][sensor:093]: 'Boiler': Sending state 57.06250 °C with 1 decimals of accuracy
[19:37:34][D][dallas.sensor:143]: 'Rücklauf HK': Got Temperature=34.2°C
[19:37:34][D][sensor:093]: 'Rücklauf HK': Sending state 34.18750 °C with 1 decimals of accuracy
Hat HA das geraet schon gefunden? Muss wahrscheinlich noch integriert werden…
