Error nach neu Connecten
Ich habe mein Sonoff Präsenssensor mit dem Zigbee Netzwerk neu verbinden lassen. Nun spukt er alle paar minuten einen Error raus.
error 2024-11-14 20:12:55z2m: Failed to configure 'Präsensmelder Küche OG', attempt 3 (Error: ZCL command 0x0ceff6fffe173f95/1 msOccupancySensing.configReport([{"minimumReportInterval":10,"maximumReportInterval":60,"reportableChange":0,"attribute":"occupancy"}], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 87 - 1 - 79 - 1030 - 7 after 10000ms) at Object.start (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:59:23) at ZStackAdapter.sendZclFrameToEndpointInternal (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:640:47) at processTicksAndRejections (node:internal/process/task_queues:95:5) at ZStackAdapter.sendZclFrameToEndpointInternal (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:672:28) at /app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:422:20 at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20) at ZStackAdapter.sendZclFrameToEndpoint (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:420:16) at Request.send (/app/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:82:20) at Endpoint.sendRequest (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:325:20) at Endpoint.zclCommand (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:951:28))
error 2024-11-14 20:23:35zhc: Failed to apply calibration to 'temperature': 'temperature_calibration' is not a number, got string ()
