ich habe das Problem, wenn ich die Automation manuel trigger, das die Triggervariablen nicht funktionieren. Das setzen der Variable trigger funktioniert nicht. Was mache ich falsch?
Vielen Dank
Klaus
Code
alias: Soil Moisture Level
description: "reports the moisture status of the pot flora"
trigger:
- platform: numeric_state
- sensor.esp32_flora_soil_moisture_level
- sensor.esp32_outside_soil_moisture_level
- sensor.ble_kitchen_soil_moisture_level
- sensor.ble_fitnessroom_soil_moisture_level
- sensor.ble_bedroom_soil_moisture_level
- sensor.air_adq_livingroom_soil_moisture_level
below: input_number.soil_low
above: input_number.soil_normal
below: input_number.soil_hight
above: input_number.soil_hight
condition: []
action:
- if:
- condition: template
value_template: "{% if trigger.platform == '' %}true{% endif %}"
enabled: true
then:
- variables:
trigger:
entity_id: manuel
- service: notify.persistent_notification
message: "{{ trigger }}"
enabled: false
else:
enabled: false
enabled: true
- service: persistent_notification.create
title: Soil Moisture Level
notification_id: soil_moisture_level
message: >
**{{ trigger.id }} {{ trigger.entity_id }}={{ states(trigger.entity_id)
}}**<br>{{ states('sensor.esp32_flora_soil_moisture_level') }} / {{
states('sensor.esp32_outside_soil_moisture_level') }} / {{
states('sensor.ble_kitchen_soil_moisture_level') }} / {{
states('sensor.ble_bedroom_soil_moisture_level') }} / {{
states('sensor.ble_fitnessroom_soil_moisture_level') }} / {{
states('sensor.air_adq_livingroom_soil_moisture_level') }}
- if:
value_template: "{% if trigger.id == 'soil_moisture_level_low' %}true{% endif %}"
then:
- service: switch.turn_on
data: {}
- switch.ble_kitchen_blue_led
- switch.ble_fitnessroom_blue_led
- switch.air_adq_livingroom_blue_led
- switch.ble_bedroom_blue_led
else:
- if:
value_template: "{% if trigger.id == 'soil_moisture_level_normal' %}true{% endif %}"
then:
- condition: and
conditions:
- condition: numeric_state
entity_id: sensor.esp32_flora_soil_moisture_level
entity_id: sensor.esp32_outside_soil_moisture_level
entity_id: sensor.ble_kitchen_soil_moisture_level
entity_id: sensor.ble_fitnessroom_soil_moisture_level
entity_id: sensor.ble_bedroom_soil_moisture_level
entity_id: sensor.air_adq_livingroom_soil_moisture_level
- service: switch.turn_off
data: {}
- switch.ble_fitnessroom_blue_led_fast
- switch.ble_kitchen_blue_led_fast
- switch.air_adq_livingroom_blue_led_fast
- switch.ble_bedroom_blue_led_fast
else:
- if:
value_template: >-
{% if trigger.id == 'soil_moisture_level_hight' %}true{% endif
then:
device_id: []
area_id: []
data: {}
by HeikoBauer: Codezeilen formatiert. Bitte mit </> einfügen.
