Open thread Border Router startet nicht
Ich habe eben ein update des Border Routers gemacht danach das komplette System neu gestartet.
Der Border Router startet nicht. nach einen manuellen Neustart stoppt dieser Automatisch .Woran kann das liegen.
  File "/usr/local/lib/python3.13/dist-packages/universal_silabs_flasher/spinel.py", line 292, in send_command
    return await self.send_frame(frame, **kwargs)
  File "/usr/local/lib/python3.13/dist-packages/universal_silabs_flasher/spinel.py", line 259, in send_frame
    async with asyncio_timeout(timeout):
  File "/usr/lib/python3.13/asyncio/timeouts.py", line 116, in __aexit__
    raise TimeoutError from exc_val
TimeoutError
[20:06:58] WARNING: otbr-agent exited with code 1 (by signal 0).
Chain OTBR_FORWARD_INGRESS (0 references)
target     prot opt source               destination
DROP       all  --  anywhere             anywhere             PKTTYPE = unicast
DROP       all  --  anywhere             anywhere             match-set otbr-ingress-deny-src src
ACCEPT     all  --  anywhere             anywhere             match-set otbr-ingress-allow-dst dst
otbr-ingress-deny-src-swap
otbr-ingress-allow-dst-swap
Chain OTBR_FORWARD_EGRESS (0 references)
[20:06:58] INFO: OTBR firewall/NAT64 rules teardown completed.
s6-svlisten: fatal: some services reported permanent failure or their supervisor died
s6-rc: warning: unable to start service otbr-agent: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service banner: stopping
s6-rc: info: service socat-otbr-tcp: stopping
s6-rc: info: service mdns: stopping
Default: mDNSResponder (Engineering Build) (Apr 10 2026 12:15:27) stopping
s6-rc: info: service banner successfully stopped
2026/04/10 20:06:58 socat[90] W exiting on signal 15
s6-rc: info: service socat-otbr-tcp successfully stopped
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: warning: service s6rc-oneshot-runner is marked as essential, not stopping it
[20:06:58] INFO: mDNS ended with exit code 4 (signal 0)...
s6-rc: info: service mdns successfully stopped
Gruß OSR
Gelöst einfach mal den Router (Stick) von Strom genommen.
