Node Red startet nicht mehr
Hallo
jetzt lief Monatelange node-RED problemlos auf meinem HA und von einem Tag auf den anderen startet es nicht mehr.
Leider kenne ich mich nicht wirklich gut damit aus, kann mich bitte jemand bei der Fehlersuche unterstützen?
6 Oct 08:53:51 - [info] Linux 6.1.73-haos-raspi arm64 LE
6 Oct 08:53:51 - [info] Loading palette nodes
6 Oct 08:53:52 - [info] Node-RED Contrib Theme Collection version: v4.0.10
6 Oct 08:53:55 - [info] Dashboard version 3.6.5 started at /endpoint/ui
6 Oct 08:53:56 - [info] node-red-contrib-home-assistant-websocket v0.73.0 nodes initialized
6 Oct 08:53:57 - [info] Settings file  : /etc/node-red/config.js
6 Oct 08:53:57 - [info] Context store  : 'default' [module=memory]
6 Oct 08:53:57 - [info] User directory : /config/
6 Oct 08:53:57 - [warn] Projects disabled : editorTheme.projects.enabled=false
6 Oct 08:53:57 - [info] Flows file     : /config/flows.json
6 Oct 08:53:57 - [info] Server now running at http://127.0.0.1:46836/
6 Oct 08:53:57 - [info] Starting flows
[08:53:57] INFO: Starting NGinx...
6 Oct 08:53:58 - [info] Started flows
6 Oct 08:53:58 - [error] [api-current-state:aktuelle produktion] InputError: Entity could not be found in cache for entityId: sensor.pv_total
6 Oct 08:53:58 - [error] [api-current-state:Tagesproduktion] InputError: Entity could not be found in cache for entityId: sensor.pvtag_fur_awtrix
6 Oct 08:53:58 - [error] [api-current-state:5e8f76611d0aba1a] InputError: Entity could not be found in cache for entityId: sensor.heatpump_heatpower
6 Oct 08:53:58 - [error] [api-current-state:Speicher voll?] InputError: Entity could not be found in cache for entityId: sensor.vartaladestand
6 Oct 08:53:58 - [error] [api-current-state:Leistungsmessung @ Varta] InputError: Entity could not be found in cache for entityId: sensor.shellypro3em_e05a1b334e70_total_active_power
6 Oct 08:53:58 - [error] [api-current-state:Außentemperatur] InputError: Entity could not be found in cache for entityId: sensor.temperatur_fur_awtrix
6 Oct 08:53:58 - [error] [api-current-state:7acd495e3ffaa127] InputError: Entity could not be found in cache for entityId: sensor.rain_rate_2
6 Oct 08:53:58 - [error] [api-current-state:aa96af9db6ee4091] InputError: Entity could not be found in cache for entityId: sensor.wind_gust_2
6 Oct 08:53:58 - [error] [api-current-state:abc1fda731f9429f] InputError: Entity could not be found in cache for entityId: sensor.heatpump_heatpower
6 Oct 08:53:58 - [error] [api-current-state:1aa5476e22e09377] InputError: Entity could not be found in cache for entityId: sensor.rain_rate_2
6 Oct 08:53:58 - [error] [api-current-state:ad4b2681dd427f07] InputError: Entity could not be found in cache for entityId: sensor.wind_gust_2
6 Oct 08:53:58 - [info] [mqtt-broker:346df2a95aac5785] Connected to broker: mqtt://10.0.0.30:1883
6 Oct 08:53:59 - [error] [api-current-state:aktuelle produktion] InputError: Entity could not be found in cache for entityId: sensor.pv_total
6 Oct 08:53:59 - [error] [api-current-state:Tagesproduktion] InputError: Entity could not be found in cache for entityId: sensor.pvtag_fur_awtrix
6 Oct 08:53:59 - [error] [api-current-state:Speicher voll?] InputError: Entity could not be found in cache for entityId: sensor.vartaladestand
6 Oct 08:53:59 - [error] [api-current-state:Leistungsmessung @ Varta] InputError: Entity could not be found in cache for entityId: sensor.shellypro3em_e05a1b334e70_total_active_power
6 Oct 08:53:59 - [error] [api-current-state:Außentemperatur] InputError: Entity could not be found in cache for entityId: sensor.temperatur_fur_awtrix
6 Oct 08:54:00 - [error] [api-current-state:aktuelle produktion] InputError: Entity could not be found in cache for entityId: sensor.pv_total
6 Oct 08:54:00 - [error] [api-current-state:Tagesproduktion] InputError: Entity could not be found in cache for entityId: sensor.pvtag_fur_awtrix
6 Oct 08:54:00 - [error] [api-current-state:Speicher voll?] InputError: Entity could not be found in cache for entityId: sensor.vartaladestand
6 Oct 08:54:00 - [error] [api-current-state:Leistungsmessung @ Varta] InputError: Entity could not be found in cache for entityId: sensor.shellypro3em_e05a1b334e70_total_active_power
6 Oct 08:54:00 - [error] [api-current-state:Außentemperatur] InputError: Entity could not be found in cache for entityId: sensor.temperatur_fur_awtrix
6 Oct 08:54:01 - [error] [api-current-state:aktuelle produktion] InputError: Entity could not be found in cache for entityId: sensor.pv_total
6 Oct 08:54:01 - [error] [api-current-state:Tagesproduktion] InputError: Entity could not be found in cache for entityId: sensor.pvtag_fur_awtrix
6 Oct 08:54:01 - [error] [api-current-state:Speicher voll?] InputError: Entity could not be found in cache for entityId: sensor.vartaladestand
6 Oct 08:54:01 - [error] [api-current-state:Leistungsmessung @ Varta] InputError: Entity could not be found in cache for entityId: sensor.shellypro3em_e05a1b334e70_total_active_power
6 Oct 08:54:01 - [error] [api-current-state:Außentemperatur] InputError: Entity could not be found in cache for entityId: sensor.temperatur_fur_awtrix
6 Oct 08:54:02 - [error] [api-current-state:aktuelle produktion] InputError: Entity could not be found in cache for entityId: sensor.pv_total
6 Oct 08:54:02 - [error] [api-current-state:Tagesproduktion] InputError: Entity could not be found in cache for entityId: sensor.pvtag_fur_awtrix
6 Oct 08:54:02 - [error] [api-current-state:Speicher voll?] InputError: Entity could not be found in cache for entityId: sensor.vartaladestand
6 Oct 08:54:02 - [error] [api-current-state:Leistungsmessung @ Varta] InputError: Entity could not be found in cache for entityId: sensor.shellypro3em_e05a1b334e70_total_active_power
6 Oct 08:54:02 - [error] [api-current-state:Außentemperatur] InputError: Entity could not be found in cache for entityId: sensor.temperatur_fur_awtrix
6 Oct 08:54:02 - [info] [server:Home Assistant] Connecting to http://supervisor/core
6 Oct 08:54:02 - [info] [server:Home Assistant] Connected to http://supervisor/core
6 Oct 08:54:02 - [red] Uncaught Exception:
6 Oct 08:54:02 - [error] UnhandledPromiseRejection: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason "#<Object>".
[08:54:03] INFO: Service Node-RED exited with code 1 (by signal 0)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
[08:54:03] INFO: Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service nodered: stopping
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nginx successfully stopped
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Vielen Dank im Voraus!
Schöne Grüße
Raffi
Hast Du irgendwelche Updates eingespielt oder neue Nodes in NR installiert?
Schon mal HA komplett incl. Hardware neu gestartet?
Hast Du ein Backup von der Zeit, wo NR noch lief und das schon mal probiert einzuspielen?
zumindest habe ich bewusst keine Updates installiert, vielleicht ist mal was automatisch geupdatet worden.
Ja HA schon mehrmals neu gestartet, auch im abgesicherten Modus.
Danke ich probiere mal eine alte Sicherung zu installieren.
