Guten Tag, seit Node Red auf V19.0 ist geht der Smartmeter nicht mehr. Ich kann auch über Paletten verwalten nichts neues hinzufügen. Hat jemand eine Idee?
kommt immer Installation fehlgeschlagen mit folgendem Log
2025-01-08T11:59:50.476Z Installieren : node-red-contrib-smartmeter 0.6.3
2025-01-08T11:59:50.378Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --omit=dev --engine-strict node-red-contrib-smartmeter@0.6.3
2025-01-08T11:59:54.383Z [err] npm warn skipping integrity check for git dependency ssh://git@github.com/mwittig/node-http-digest-client.git
2025-01-08T12:00:01.352Z [err] npm warn deprecated har-validator@5.1.5: this library is no longer supported
2025-01-08T12:00:01.644Z [err] npm warn deprecated cryptiles@0.2.2: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
2025-01-08T12:00:01.892Z [err] npm warn deprecated boom@0.4.2: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
2025-01-08T12:00:01.912Z [err] npm warn deprecated sntp@0.2.4: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
2025-01-08T12:00:02.044Z [err] npm warn deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
2025-01-08T12:00:02.264Z [err] npm warn deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
2025-01-08T12:00:02.291Z [err] npm warn deprecated hoek@0.9.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
2025-01-08T12:00:02.317Z [err] npm warn deprecated node-uuid@1.4.8: Use uuid module instead
2025-01-08T12:00:02.624Z [err] npm warn deprecated request@2.40.0: request has been deprecated, see https://github.com/request/request/issues/3142
2025-01-08T12:00:02.624Z [err] npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
2025-01-08T12:00:02.997Z [err] npm warn deprecated hawk@1.1.1: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
2025-01-08T12:00:07.722Z [err] npm warn deprecated core-js@2.6.12: core-js@<3.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Please, upgrade your dependencies to the actual version of core-js.
2025-01-08T12:00:10.574Z [err] npm error code E404
2025-01-08T12:00:10.574Z [err] npm error 404 Not Found - GET https://registry.npmjs.org/@alpine-code/node-red-contrib-minio/-/node-red-contrib-minio-0.0.12.tgz - Not found
2025-01-08T12:00:10.574Z [err] npm error 404 '@alpine-code/node-red-contrib-minio@https://registry.npmjs.org/@alpine-code/node-red-contrib-minio/-/node-red-contrib-minio-0.0.12.tgz' is not in this registry.
2025-01-08T12:00:10.575Z [err] npm error 404
2025-01-08T12:00:10.575Z [err] npm error 404 Note that you can also install from a
2025-01-08T12:00:10.575Z [err] npm error 404 tarball, folder, http url, or git url.
2025-01-08T12:00:10.580Z [err] npm error A complete log of this run can be found in: /root/.npm/_logs/2025-01-08T11_59_50_575Z-debug-0.log
2025-01-08T12:00:10.775Z rc=1
