Ich kopiere mal den einen Flow als Beispiel:
"id": "2a5ebdaf.63b2ba",
"type": "light-scheduler",
"z": "531329de.63e52",
"settings": "6c8fbe70.2540b8",
"events": "[{\"start\":{\"dow\":1,\"mod\":790},\"end\":{\"dow\":1,\"mod\":1290}},{\"start\":{\"dow\":3,\"mod\":790},\"end\":{\"dow\":3,\"mod\":1290}},{\"start\":{\"dow\":0,\"mod\":600},\"end\":{\"dow\":0,\"mod\":1290}},{\"start\":{\"dow\":4,\"mod\":790},\"end\":{\"dow\":4,\"mod\":1290}},{\"start\":{\"dow\":5,\"mod\":790},\"end\":{\"dow\":5,\"mod\":1290}},{\"start\":{\"dow\":6,\"mod\":600},\"end\":{\"dow\":6,\"mod\":1290}},{\"start\":{\"dow\":2,\"mod\":790},\"end\":{\"dow\":2,\"mod\":1290}}]",
"topic": "",
"name": "Heizung Wohnzimmer",
"onPayload": "ON",
"onPayloadType": "str",
"offPayload": "OFF",
"offPayloadType": "str",
"onlyWhenDark": false,
"scheduleRndMax": 0,
"sunElevationThreshold": "0",
"sunShowElevationInStatus": false,
"outputfreq": "output.statechange.startup",
"x": 160,
"y": 1720,
"wires": [
"15baf22a.3ceeee"
"id": "15baf22a.3ceeee",
"type": "switch",
"name": "",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "ON",
"vt": "str"
"t": "eq",
"v": "OFF",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 330,
"y": 1720,
"wires": [
"b3f7cca3aab357a5"
"c7ecff30c7d86ff3"
"id": "7dfdb31272e16765",
"type": "api-current-state",
"name": "Comf lesen",
"server": "3ee43a18.3e87e6",
"version": 3,
"outputs": 1,
"halt_if": "",
"halt_if_type": "str",
"halt_if_compare": "is",
"entity_id": "input_number.hz_wohnzimmer_high",
"state_type": "str",
"blockInputOverrides": false,
"outputProperties": [
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "entity"
"for": "0",
"forType": "num",
"forUnits": "minutes",
"override_topic": false,
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"x": 1270,
"y": 1720,
"wires": [
"10fdd7baf95e49f8"
"id": "4debfbeb1df21185",
"name": "ECO lesen",
"version": 3,
"outputs": 1,
"halt_if": "",
"entity_id": "input_number.hz_wohnzimmer_low",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 1270,
"y": 1760,
"wires": [
"10fdd7baf95e49f8"
"id": "10fdd7baf95e49f8",
"type": "api-call-service",
"name": "Set Temparature Wohnzimmer",
"version": 5,
"debugenabled": false,
"domain": "climate",
"service": "set_temperature",
"areaId": [],
"deviceId": [],
"entityId": [
"climate.wohnzimmer"
"data": "{\"temperature\":msg.payload}",
"dataType": "jsonata",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"x": 1590,
"y": 1740,
"wires": [
"id": "2bc77485ef7cce46",
"type": "link in",
"name": "link in 3",
"links": [
"4b2cce688d03fa83"
"x": 75,
"y": 1680,
"wires": [
"2a5ebdaf.63b2ba"
"id": "4a46bba31baf0cd9",
"type": "switch",
"name": "Urlaub?",
"property": "urlaub",
"propertyType": "global",
"rules": [
"t": "eq",
"v": "on",
"vt": "str"
"t": "eq",
"v": "off",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 780,
"y": 1720,
"wires": [
"f301f0df9f2d8376"
"id": "b3f7cca3aab357a5",
"type": "switch",
"name": "Heizsaison?",
"property": "heizsaison",
"rules": [
"t": "eq",
"v": "on",
"vt": "str"
"t": "eq",
"v": "off",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 550,
"y": 1720,
"wires": [
"4a46bba31baf0cd9"
"id": "843f2fe3db27bfdb",
"type": "switch",
"name": "Urlaub?",
"rules": [
"t": "eq",
"v": "on",
"vt": "str"
"t": "eq",
"v": "off",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 780,
"y": 1760,
"wires": [
"e5cf60694e3b68d2"
"id": "c7ecff30c7d86ff3",
"type": "switch",
"rules": [
"t": "eq",
"v": "on",
"vt": "str"
"t": "eq",
"v": "off",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 550,
"y": 1760,
"wires": [
"843f2fe3db27bfdb"
"id": "f301f0df9f2d8376",
"name": "Fenster geschlossen?",
"version": 3,
"outputs": 2,
"halt_if": "off",
"entity_id": "binary_sensor.lumi_lumi_sensor_magnet_aq2_opening",
"value": "",
"property": "data",
"value": "",
"for": 0,
"forType": "num",
"x": 1060,
"y": 1720,
"wires": [
"7dfdb31272e16765"
"id": "e5cf60694e3b68d2",
"version": 3,
"outputs": 2,
"halt_if": "off",
"value": "",
"property": "data",
"value": "",
"for": 0,
"forType": "num",
"x": 1060,
"y": 1760,
"wires": [
"4debfbeb1df21185"
"id": "6c8fbe70.2540b8",
"type": "light-scheduler-settings",
"name": "Liebigstraße",
"latitude": "51.27149093442626",
"longitude": "6.557010412107048"
"id": "3ee43a18.3e87e6",
"type": "server",
"name": "Home Assistant",
"version": 5,
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": "30",
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "friendlyName",
"statusSeparator": "at: ",
"statusYear": "hidden",
"statusMonth": "short",
"statusDay": "numeric",
"statusHourCycle": "h23",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": true
Das müsstest du eigentlich importieren können.
