Es ist vielleicht so, dass das Interface mit HA nicht schnell genug ist. Ich würde Dir als Umgehung empfehlen, den Status der Heizsaison einmal im Flowkontext zu speichern, dann kannst du mit diesem beliebig filtern.
Wenn Du den Urlaubsstatus global speicherst - kannst Du diesem überall in NodeRed verwenden:
[{"id":"64338a7ae61824b7","type":"server-state-changed","z":"a25f8a10e201ae6f","name":"Urlaub","server":"bfe57e2a35b419a4","version":5,"outputs":1,"exposeAsEntityConfig":"","entityId":"sensor.hacs","entityIdType":"exact","outputInitially":false,"stateType":"str","ifState":"","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":190,"y":2000,"wires":[["4d3a4850a6a9647c"]]},{"id":"4d3a4850a6a9647c","type":"change","z":"a25f8a10e201ae6f","name":"","rules":[{"t":"set","p":"urlaub","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":2000,"wires":[[]]},{"id":"bfe57e2a35b419a4","type":"server","name":"Home Assistant","version":5,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":": ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"default","statusTimeFormat":"h:m","enableGlobalContextStore":false}]
Filtern kannst du später mit einer Switch Node:
Das ist halt auch “schneller” - weil Du dann bei jeder Abfrage nicht wieder mit HA kommunizieren musst, sondern nur bei Änderungen wird die globale Variable geändert - das ist wesentlich effizienter, als dauernd den Entitätenstatus abzufragen. Geht natürlich auch mit “on” “off” - oder was auch immer. Je nachdem was halt für ein State aus Deiner Urlaubsentität rauskommt.
Das Gleiche empfiehlt sich im Übrigen auch bei An/Abwesenheit - also alles wo man ggf. einen Flow blockieren muss, wenn man nicht da ist etc.
