Seit ich einen Sensor hinzugefügt habe und wieder entfernt habe kriege ich ihn nicht mehr verbunden In HomeKit
homeassistant.components.homekit_controller.config_flow
Quelle: components/homekit_controller/config_flow.py:452
Integration: HomeKit-Gerät ([Dokumentation](https://www.home-assistant.io/integrations/homekit_controller), [Probleme](https://github.com/home-assistant/core/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+homekit_controller%22))
Erstmals aufgetreten: 11:39:44 (2 Vorkommnisse)
Zuletzt protokolliert: 11:51:34
Pairing attempt failed with an unhandled exception
File "/usr/local/lib/python3.12/site-packages/aiohomekit/controller/coap/pairing.py", line 111, in _ensure_connected
await self.connection_future
File "/usr/local/lib/python3.12/site-packages/aiohomekit/controller/coap/connection.py", line 404, in connect
await self.get_accessory_info()
File "/usr/local/lib/python3.12/site-packages/aiohomekit/controller/coap/connection.py", line 413, in get_accessory_info
_, body = await self.enc_ctx.post(OpCode.UNK_09_READ_GATT, 0x0000, b"")
File "/usr/local/lib/python3.12/site-packages/aiohomekit/controller/coap/connection.py", line 194, in post
res_pdu = await self.post_bytes(req_pdu)
File "/usr/local/lib/python3.12/site-packages/aiohomekit/controller/coap/connection.py", line 171, in post_bytes
response = await self.coap_ctx.request(request).response
File "/usr/local/lib/python3.12/site-packages/aiocoap/protocol.py", line 606, in _run_outer
await cls._run(app_request, response, weak_observation, protocol, log)
File "/usr/local/lib/python3.12/site-packages/aiocoap/protocol.py", line 665, in _run
blockresponse = await blockrequest.response
aiocoap.error.LibraryShutdown
During handling of the above exception, another exception occurred:
File "/usr/src/homeassistant/homeassistant/components/homekit_controller/config_flow.py", line 452, in async_step_pair
return await self._entry_from_accessory(pairing)
File "/usr/src/homeassistant/homeassistant/components/homekit_controller/config_flow.py", line 580, in _entry_from_accessory
name = await pairing.get_primary_name()
File "/usr/local/lib/python3.12/site-packages/aiohomekit/controller/abstract.py", line 264, in get_primary_name
accessories = await self.list_accessories_and_characteristics()
File "/usr/local/lib/python3.12/site-packages/aiohomekit/controller/coap/pairing.py", line 147, in list_accessories_and_characteristics
await self._ensure_connected()
File "/usr/local/lib/python3.12/site-packages/aiohomekit/controller/coap/pairing.py", line 113, in _ensure_connected
raise AccessoryDisconnectedError("failed to connect")
aiohomekit.exceptions.AccessoryDisconnectedError: failed to connect
