Hallo zusammen ich habe heute meine sensor.yaml und Ausgelager in jeweils einen extra Ordner wie von Smart Home Bastler im Video die Sensoren gingen alle bis zum Update und laufen auch noch aber werden als Fehler angezeigt
Logger: homeassistant.components.template.template_entity
Source: components/template/template_entity.py:194
Integration: Template (documentation, issues)
First occurred: 20:27:57 (6 occurrences)
Last logged: 20:27:57
TemplateError('ValueError: Template error: float got invalid input ‘unknown’ when rendering template ‘{{ 1000e**(19.016-(4064.95/(float(states(‘sensor.th_lf_chris_temperature’))+236.25))) 100/(461.66(float(states(‘sensor.th_lf_chris_temperature’))+273.15)) * float(states(‘sensor.th_lf_chris_humidity’))/100 | float }}’ but no default was specified’) while processing template 'Template<template=({{ 1000e**(19.016-(4064.95/(float(states(‘sensor.th_lf_chris_temperature’))+236.25))) 100/(461.66(float(states(‘sensor.th_lf_chris_temperature’))+273.15)) * float(states(‘sensor.th_lf_chris_humidity’))/100 | float }}) renders=4>’ for attribute ‘_attr_native_value’ in entity ‘sensor.absolute_humidity_ch’
TemplateError('ValueError: Template error: float got invalid input ‘unknown’ when rendering template ‘{{ 1000e**(19.016-(4064.95/(float(states(‘sensor.th_lf_kuche_temperature’))+236.25))) 100/(461.66(float(states(‘sensor.th_lf_kuche_temperature’))+273.15)) * float(states(‘sensor.th_lf_kuche_humidity’))/100 | float }}’ but no default was specified’) while processing template 'Template<template=({{ 1000e**(19.016-(4064.95/(float(states(‘sensor.th_lf_kuche_temperature’))+236.25))) 100/(461.66(float(states(‘sensor.th_lf_kuche_temperature’))+273.15)) * float(states(‘sensor.th_lf_kuche_humidity’))/100 | float }}) renders=4>’ for attribute ‘_attr_native_value’ in entity ‘sensor.absolute_humidity_kh’
TemplateError('ValueError: Template error: float got invalid input ‘unknown’ when rendering template ‘{{ 1000e**(19.016-(4064.95/(float(states(‘sensor.th_lf_nik_temperature’))+236.25))) 100/(461.66(float(states(‘sensor.th_lf_nik_temperature’))+273.15)) * float(states(‘sensor.th_lf_nik_humidity’))/100 | float }}’ but no default was specified’) while processing template 'Template<template=({{ 1000e**(19.016-(4064.95/(float(states(‘sensor.th_lf_nik_temperature’))+236.25))) 100/(461.66(float(states(‘sensor.th_lf_nik_temperature’))+273.15)) * float(states(‘sensor.th_lf_nik_humidity’))/100 | float }}) renders=4>’ for attribute ‘_attr_native_value’ in entity ‘sensor.absolute_humidity_nk’
TemplateError('ValueError: Template error: float got invalid input ‘unknown’ when rendering template ‘{{ 1000e**(19.016-(4064.95/(float(states(‘sensor.th_lf_schafzimmer_temperature’))+236.25))) 100/(461.66(float(states(‘sensor.th_lf_schafzimmer_temperature’))+273.15)) * float(states(‘sensor.th_lf_schafzimmer_humidity’))/100 | float }}’ but no default was specified’) while processing template 'Template<template=({{ 1000e**(19.016-(4064.95/(float(states(‘sensor.th_lf_schafzimmer_temperature’))+236.25))) 100/(461.66(float(states(‘sensor.th_lf_schafzimmer_temperature’))+273.15)) * float(states(‘sensor.th_lf_schafzimmer_humidity’))/100 | float }}) renders=4>’ for attribute ‘_attr_native_value’ in entity ‘sensor.absolute_humidity_schlaf’
TemplateError('ValueError: Template error: float got invalid input ‘unknown’ when rendering template ‘{{ 1000e**(19.016-(4064.95/(float(states(‘sensor.th_lf_wohnzimmer_temperature’))+236.25))) 100/(461.66(float(states(‘sensor.th_lf_wohnzimmer_temperature’))+273.15)) * float(states(‘sensor.th_lf_wohnzimmer_humidity’))/100 | float }}’ but no default was specified’) while processing template 'Template<template=({{ 1000e**(19.016-(4064.95/(float(states(‘sensor.th_lf_wohnzimmer_temperature’))+236.25))) 100/(461.66(float(states(‘sensor.th_lf_wohnzimmer_temperature’))+273.15)) * float(states(‘sensor.th_lf_wohnzimmer_humidity’))/100 | float }}) renders=4>’ for attribute ‘_attr_native_value’ in entity ‘sensor.absolute_humidity_wz’
Und den
Logger: homeassistant.config
Source: config.py:501
First occurred: 20:27:19 (1 occurrences)
Last logged: 20:27:19
Invalid config for [template]: invalid template (TemplateSyntaxError: expected token ‘end of statement block’, got ‘%’) for dictionary value @ data[‘sensor’][1][‘state’]. Got “{% if states.calendar.ics.state == ‘on’ %} Du musst heute {{ states.sensor.mullabholung_heute.state }} Tonne rausstellen! {% else % {%endif%}”. (See /config/template/Müllabholung.yaml, line 0).
Ich weiß echt nicht was jetzt los ist
Hat jemand eine Idee
Für eure Hilfe wäre ich sehr dankbar
