Hallo ich versuche jetzt schon seit einiger Zeit meine 3 SMA Wechselrichter in Home Assistant einzubinden bekomme aber immer nur meinen hybrid Wechselrichter hinein hat es jemand schon geschafft mehrere Wechselrichter in HA zu intigrieren.
Lg Felix
Welche Geräte hast du denn konkret?
Hast du es schon mit meiner Integration probiert?
The SMA integration currently available in Home Assistant only supports devices that use the Webconnect standard.
This integration supports almost all SMA devices like inverters, hybrid inverters, battery inverters and energy meters.
# Supported Devices
* (as before) Webconnect devices
* EnnexOS-based devices (currently e.g. Tripower X)
* Devices with a Speedwire-Interface
* Energy Meter (EMETER-10 + 20) and Sunny Home Manager 2
A list of devices that have been successfully tested can be found [here](https://github.com/littleyoda/pysma/blob/master/README.md)
Please see also the [Frequently Asked Questions](https://github.com/littleyoda/ha-pysmaplus/blob/main/docs/faq.md) of this integration, but also the
[Frequently Asked Questions](https://github.com/littleyoda/pysma/blob/master/doc/faq_DE.md) of the underlying library.
# Installation
* HACS must be installed
* Then add the following integration via HACS
SMA Devices Plus
Diese Datei wurde abgeschnitten. Original zeigen
Danke ich probiere es einmal aus
