### The problem
Recently received Sky Connect. When trying to set up with incl…uded USB extention, Home Assistant errors out and is unable to start/set it up. This continues with all USB ports, and two other USB extention cords (both work with Zwave stick). This issue also persists through hardware restarts. Error log attached.
### What version of Home Assistant Core has the issue?
2023.1.7
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
ZHA
### Link to integration documentation on our website
_No response_
### Diagnostics information
[home-assistant_zha_2023-01-25T19-01-30.354Z.log](https://github.com/home-assistant/core/files/10502641/home-assistant_zha_2023-01-25T19-01-30.354Z.log)
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
```txt
2023-01-25 02:15:23.085 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration keymaster which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-25 02:15:23.088 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-25 02:15:46.378 ERROR (MainThread) [zigpy.application] Couldn't start application
File "/usr/local/lib/python3.10/asyncio/tasks.py", line 456, in wait_for
return fut.result()
asyncio.exceptions.CancelledError
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 145, in startup
await self.connect()
File "/usr/local/lib/python3.10/site-packages/bellows/zigbee/application.py", line 124, in connect
self._ezsp = await bellows.ezsp.EZSP.initialize(self.config)
File "/usr/local/lib/python3.10/site-packages/bellows/ezsp/__init__.py", line 104, in initialize
await ezsp._startup_reset()
File "/usr/local/lib/python3.10/site-packages/bellows/ezsp/__init__.py", line 95, in _startup_reset
await self.reset()
File "/usr/local/lib/python3.10/site-packages/bellows/ezsp/__init__.py", line 124, in reset
await self._gw.reset()
File "/usr/local/lib/python3.10/site-packages/bellows/uart.py", line 251, in reset
return await asyncio.wait_for(self._reset_future, timeout=RESET_TIMEOUT)
File "/usr/local/lib/python3.10/asyncio/tasks.py", line 458, in wait_for
raise exceptions.TimeoutError() from exc
asyncio.exceptions.TimeoutError
2023-01-25 02:15:46.399 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 1 of 3)
return fut.result()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 174, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 169, in new
await app.startup(auto_form=auto_form)
await self.reset()
2023-01-25 02:15:54.471 ERROR (MainThread) [zigpy.application] Couldn't start application
return fut.result()
await self.reset()
2023-01-25 02:15:54.486 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 2 of 3)
return fut.result()
await self.reset()
2023-01-25 02:16:02.559 ERROR (MainThread) [zigpy.application] Couldn't start application
return fut.result()
await self.reset()
2023-01-25 02:16:02.576 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 3 of 3)
return fut.result()
await self.reset()
2023-01-25 02:16:02.581 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry SkyConnect v1.0 for zha
return fut.result()
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 382, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 111, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 189, in async_initialize
raise exc
await self.reset()
2023-01-25 02:16:03.094 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Home Assistant Sky Connect' for homeassistant_sky_connect integration not ready yet: None; Retrying in background
2023-01-25 02:16:29.246 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: myq
2023-01-25 02:17:29.337 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: myq
2023-01-25 02:18:29.424 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: myq
2023-01-25 02:19:17.268 ERROR (MainThread) [homeassistant.config_entries] Cannot find integration otbr
2023-01-25 02:19:17.277 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 841, in async_create_flow
integration = await loader.async_get_integration(self.hass, handler_key)
File "/usr/src/homeassistant/homeassistant/loader.py", line 790, in async_get_integration
raise int_or_exc
homeassistant.loader.IntegrationNotFound: Integration 'otbr' not found.
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 229, in async_init
flow, result = await task
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 247, in _async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 844, in async_create_flow
raise data_entry_flow.UnknownHandler from err
homeassistant.data_entry_flow.UnknownHandler
2023-01-25 06:57:12.590 WARNING (MainThread) [homeassistant.helpers.service] Unable to find referenced entities lock.kitchen_lock or it is/they are currently not available
2023-01-25 11:01:13.232 WARNING (MainThread) [homeassistant.helpers.service] Unable to find referenced entities lock.kitchen_lock or it is/they are currently not available
### Additional information
_No response_
