wie kann ich mit Nodered auswerten, ob es an einem Shelly angeschlossenen Taster ein Long- bzw. ein Shortpress gegeben hat?
Grüße und Danke
Christian
Grüße und Danke
Christian
Klingt spannend. Kannst Du mit den Inhalt des json schicken oder kannst du vielleicht den Flow exportieren?
Grüße und danke
Christian
Gerne:
[{"id":"2637a3101970bb4c","type":"server-events","z":"5e38a40b1ab38ea9","name":"Shelly-Button1","server":"a1aba8eb.bfd618","version":3,"exposeAsEntityConfig":"","eventType":"shelly.click","eventData":"{\"device\":\"shellybutton1-98CDAC2C2DDE\"}","waitForRunning":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"$outputData(\"eventData\").event.click_type","valueType":"jsonata"}],"event_type":"","x":1018,"y":216,"wires":[["bc1c5cf4b1d38bd5"]]},{"id":"bc1c5cf4b1d38bd5","type":"switch","z":"5e38a40b1ab38ea9","name":"Shelly-KLICK","property":"payload.event.click_type","propertyType":"msg","rules":[{"t":"eq","v":"single","vt":"str"},{"t":"eq","v":"double","vt":"str"},{"t":"eq","v":"triple","vt":"str"},{"t":"eq","v":"long","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":1208,"y":216,"wires":[[],[],[],[]]},{"id":"a1aba8eb.bfd618","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
Du musst eben noch die Entität “shellybutton…” anpassen.
Danke. Werde versuchen das umzusetzen.
