Ich habe jetzt nocheinmal die ältesten Backups zurückgespielt. Leider bekomme ich immer bei der Überprüfung der Konfiguration in den Entwicklerwerkzeugen diesen Fehler:
Invalid config for ‘shelly’ at shelly3em.yaml, line 120: ‘sensor’ is an invalid option for ‘shelly’, check: shelly->sensor
Ich habe die Dateien shelly3em.yam. und utility_meter.yaml mittels des include Befehls integriert. Waru mich das getan habe, weiß ich nicht mehr.
hier die Shelly3em.yaml
# Shelly 3EM templates for 3-phase Net Import, Export and Consumption(if you have solar generation details)
# This uses the shelly instantaneous power sensors to achieve the best possible accuracy.
# Shelly Sensors are sensor.l1_power, sensor.l2_power, sensor.l3_power for the three phases
# Solar generation in W is used to calculate consumption via sensor.power_solargen
# V1.0 Initial release by Uksa007
# V1.1 add float(0) to Consumption template to stop log warnings.
# V1.2 add Friendly names to Utility Meter sensors
# V1.3 remove negative spikes from power consumption due to different update timing of solar sensor
# V1.4 change round: 2 for small value users.
# - platform: template
# sensors:
# # Template sensor for values of power import (active_power > 0)
# power_import:
# friendly_name: "Power Import"
# unit_of_measurement: 'W'
# value_template: >-
# {% if (states('sensor.l1_power')|float + states('sensor.l2_power')|float + states('sensor.l3_power')|float) > 0 %}
# {{ states('sensor.l1_power')|float + states('sensor.l2_power')|float + states('sensor.l3_power')|float }}
# {% else %}
# {{ 0 }}
# {% endif %}
# availability_template: "{{
# [ states('sensor.l1_power'),
# states('sensor.l2_power'),
# states('sensor.l3_power')
# ] | map('is_number') | min
# # Template sensor for values of power export (active_power < 0)
# power_export:
# friendly_name: "Power Export"
# {% if (states('sensor.l1_power')|float + states('sensor.l2_power')|float + states('sensor.l3_power')|float) < 0 %}
# {{ (states('sensor.l1_power')|float + states('sensor.l2_power')|float + states('sensor.l3_power')|float) * -1 }}
# {% else %}
# {{ 0 }}
# {% endif %}
# # Template sensor for values of power consumption
# power_consumption:
# friendly_name: "Power Consumption"
# {% if (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) < 0 %}
# {% elif (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) > 0 %}
# {{ (states('sensor.power_solargen')|float(0)) - states('sensor.power_export')|float(0) }}
# {% else %}
# {{ states('sensor.power_import')|float(0) + states('sensor.power_solargen')|float(0) }}
# {% endif %}
# # Sensor for Riemann sum of energy import (W -> Wh)
# - platform: integration
# source: sensor.power_import
# name: energy_import_sum
# unit_prefix: k
# round: 2
# method: left
# # Sensor for Riemann sum of energy export (W -> Wh)
# source: sensor.power_export
# name: energy_export_sum
# unit_prefix: k
# round: 2
# method: left
# # Sensor for Riemann sum of energy consumption (W -> Wh)
# source: sensor.power_consumption
# name: energy_consumption_sum
# unit_prefix: k
# round: 2
# method: left
############### Hier Ende des eigentlichen Shelly3em Sensorbereichs #########
Hier die utility_meter.yaml
energy_import_daily:
source: sensor.energy_import_sum
name: Energy Import Daily
cycle: daily
energy_import_monthly:
name: Energy Import Monthly
cycle: monthly
energy_export_daily:
source: sensor.energy_export_sum
name: Energy Export Daily
cycle: daily
energy_export_monthly:
name: Energy Export Monthly
cycle: monthly
energy_consumption_daily:
source: sensor.energy_consumption_sum
name: Energy Consumption Daily
cycle: daily
energy_consumption_monthly:
name: Energy Consumption Monthly
cycle: monthly
Hier die configuration.yaml
# THEMES
frontend:
themes: !include_dir_merge_named themes
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
############## Helium include ############################
###### ergänzt für Nachrichten an App
mobile_app:
action:
- service: notify.mobile_app_iPhone_von_Alwin_3291
title: "TV wurde angeschaltet"
message: "Fernseher wurde angeschaltet"
######################### VU Integration ###############################
#media_player: !include vuplus.yaml
# - platform: enigma2
# host: 192.168.1.99
# name: VU+ Wohn
# use_channel_icon: true
# host: 192.168.1.60
# name: VU+ Schlaf
############ Example configuration.yaml entry WOL VU Schlaf #############
switch:
- platform: wake_on_lan
mac: 00:1D:EC:06:A9:30
# Wetterwarnung Deutscher Wetterdienst
# sensor:
# - platform: dwd_weather_warnings
# region_name:
# region_name:
#################### TEMPLATE BEREICH ###############################
## Die Einbindung der Template-Sensoren wurde ausgelagert
# Hier werden die !include-Direktiven für sensor und utility_meter separat platziert
utility_meter: !include utility_meter.yaml
####### TEMPLATE BEREICH ENDE #########################################
#################### Modbus WR SMA Tripower einbinden #################
modbus: !include modbus.yaml
shelly: !include shelly3em.yaml
########### Email Benachrichtigung konfigurieren #################
#notify:
#- name: Homeassistant_Email
#platform: smtp
#server:
#sender:
#recipient:
#username:
#password:
#encryption: starttls
################### Email Ende ######################################
# netatmo:
# client_id:
# client_secret:
# waste_collection_schedule source configuration
# Test der ID´s hier: https://www.mariotti.de/abfallkalender-in-home-assistant-einrichten-mit-mymuell-als-datenquelle/
# Dies müsste richtige Ergebnisse für MMLD liefern: https://mymuell.jumomind.com/mmapp/api.php?r=dates&city_id=71133&area_id=1443
waste_collection_schedule:
sources:
- name: jumomind_de
args:
service_id: mymuell
city_id:
area_id:
sensor:
# ------- Garbage Collection -------
# Nächste Abholung
- platform: waste_collection_schedule
name: "Nächste Abholung"
value_template: '{{value.types|join(", ")}}{% if value.daysTo == 0 %} Heute{% elif value.daysTo == 1 %} Morgen{% else %} in {{value.daysTo}} Tagen{% endif %}'
# Nächste Restmüll-Abholung
types:
- Hausmüll
# - Restmüll
# Nächste Biomüll Abholung
types:
- Grünabfall
# Nächste gelber-Sack Abholung
types:
- Gelber Sack
# Nächste Papiermüll Abholung
types:
- Blaue Tonne
############### Ab hier von https://community.home-assistant.io/t/shelly-3em-3-phase-net-metering-templates-for-import-export-and-consumption/390237 #############
sensor:
sensors:
power_import:
value_template: >-
{% else %}
{{ 0 }}
{% endif %}
power_export:
value_template: >-
{% else %}
{{ 0 }}
{% endif %}
power_consumption:
value_template: >-
{% else %}
{% endif %}
unit_prefix: k
round: 2
method: left
unit_prefix: k
round: 2
method: left
unit_prefix: k
round: 2
method: left
#utility_meter:
# energy_import_daily:
# source: sensor.energy_import_sum
# name: Energy Import Daily
# cycle: daily
# energy_import_monthly:
# name: Energy Import Monthly
# cycle: monthly
# energy_export_daily:
# source: sensor.energy_export_sum
# name: Energy Export Daily
# cycle: daily
# energy_export_monthly:
# name: Energy Export Monthly
# cycle: monthly
# energy_consumption_daily:
# source: sensor.energy_consumption_sum
# name: Energy Consumption Daily
# cycle: daily
# energy_consumption_monthly:
# name: Energy Consumption Monthly
# cycle: monthly
