Hallöle,
habe 2 kleine Probleme mit dem rtl433 to MQTT addon,
- bei meiner Bresser Wetterstation kann ich seit dem 23er Update keine Regenmenge pro Minute/Tag/Monat mit dem statistic sensor anzeigen, es kommt unavailable oder unknown.
entity_id: sensor.rain_outside_bresser61
state_characteristic: change_sample
#state_characteristic: change_second
#state_characteristic: total
max_age:
minutes: 2
#sampling_size: 2
#precision: 4
- platform: statistics
max_age:
hours: 24
precision: 2
state_characteristic: mean
max_age:
days: 30
#sampling_size: 500
precision: 2
- Ich habe einen 2 Bresser Temperatur/Feuchtigskeits Sensor, der auf das gleiche Topic, wie die Hauptstation published, wollte es im mqtt Sensor über ein availability über die Sensor Id steuern , nur zeigt er bei beiden das gleiche an.
state_topic: rtl_433/bresser61/humidity
icon: mdi:water-percent
unit_of_measurement: "%"
availability_template: "{{ value_json['id'] == '244' }}"
unique_id: "244"
#value_template: “{{ value | float | round(default=0) }}”
#value_template: "{{ [value] }}"
availability_template: "{{ value_json['id'] == '318832891' }}"
unique_id: "318832891"
MQTT BROKER OUTPUT
{"time" : "2023-04-07 21:43:36", "model" : "Bresser-6in1", "id" : 318832891, "channel" : 0, "sensor_type" : 1, "wind_max_m_s" : 0.000, "wind_avg_m_s" : 0.000, "wind_dir_deg" : 22, "rain_mm" : 255.600, "startup" : 1, "flags" : 1, "mic" : "CRC"}
{"time" : "2023-04-07 21:43:48", "model" : "Bresser-6in1", "id" : 318832891, "channel" : 0, "battery_ok" : 1, "temperature_C" : 8.600, "humidity" : 83, "sensor_type" : 1, "wind_max_m_s" : 0.000, "wind_avg_m_s" : 0.000, "wind_dir_deg" : 22, "uv" : 0.000, "startup" : 1, "flags" : 0, "mic" : "CRC"}
Tuned to 433.920MHz.
{"center_frequency" : 433920000, "frequencies" : [868272000, 433920000], "hop_times" : [600]}
Allocating 15 zero-copy buffers
{"time" : "2023-04-07 21:43:51", "model" : "Bresser-3CH", "id" : 40, "channel" : 3, "battery_ok" : 1, "temperature_F" : 69.200, "humidity" : 59, "mic" : "CHECKSUM"}
Danke und schöne Ostern
