Node-Red Heizungssteuerung
So ich habe das Problem jetzt auf etwas andere weise gelöst, aber ebenfalls in Node Red… ein paar Feineinstellungen sind noch nötig aber soweit läuft es super :slight_smile:
Seht hier:
[{"id":"8e2f976f9c4fe5a2","type":"server-state-changed","z":"20f73031b9c7424c","name":"Raumtemperatur","server":"4c1c95c5.da8acc","version":6,"outputs":1,"exposeAsEntityConfig":"","entities":{"entity":["sensor.temperatur_buro"],"substring":[],"regex":[]},"outputInitially":false,"stateType":"str","ifState":"","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":280,"y":1260,"wires":[["df4111c0b4702611"]]},{"id":"56bb969a3394a023","type":"api-current-state","z":"20f73031b9c7424c","name":"Welche Modus ist eingestellt?","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_buro_strasse_heizung","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":570,"y":920,"wires":[["2ed2cbdb920e9291"]]},{"id":"327e1dd83ea25522","type":"change","z":"20f73031b9c7424c","name":"Setze Modus","rules":[{"t":"set","p":"modus_heizung_büro_straße","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":880,"wires":[[]]},{"id":"1c1dd056d8e67b51","type":"api-current-state","z":"20f73031b9c7424c","name":"Welche Modus ist eingestellt?","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_buro_garten_heizung","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":570,"y":1640,"wires":[["ad793eece66c9032"]]},{"id":"258c6a87fe10d256","type":"change","z":"20f73031b9c7424c","name":"Setze Modus","rules":[{"t":"set","p":"modus_heizung_büro_garten","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":1600,"wires":[[]]},{"id":"4b9198d6ae4fdac7","type":"switch","z":"20f73031b9c7424c","name":"auto / heat / off","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"auto","vt":"str"},{"t":"eq","v":"heat","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":1020,"y":920,"wires":[["fc87bf49b31defe8"],["33286911cf297443"],["33d4257ae6da149c"]]},{"id":"429e22095adc3ffd","type":"switch","z":"20f73031b9c7424c","name":"auto / heat / off","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"auto","vt":"str"},{"t":"eq","v":"heat","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":1020,"y":1640,"wires":[["ecabe1d07afd10be"],["3f5e6b27fb189d0b"],["9392cad4d4196ff0"]]},{"id":"33d4257ae6da149c","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist Steckdose aus?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.steckdose_buro_heizung_strasse","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1270,"y":940,"wires":[[],["cc7029a010a29ba9"]]},{"id":"cc7029a010a29ba9","type":"api-call-service","z":"20f73031b9c7424c","name":"Steckdose aus","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.steckdose_buro_heizung_strasse"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":1480,"y":940,"wires":[[]]},{"id":"9392cad4d4196ff0","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist Steckdose aus?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.steckdose_buro_heizung_garten","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1270,"y":1720,"wires":[[],["e806c9bbd2582776"]]},{"id":"e806c9bbd2582776","type":"api-call-service","z":"20f73031b9c7424c","name":"Steckdose aus","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.steckdose_buro_heizung_garten"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":1480,"y":1720,"wires":[[]]},{"id":"33286911cf297443","type":"api-current-state","z":"20f73031b9c7424c","name":"Welche Temperatur ist eingestellt?","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_buro_strasse_heizung","state_type":"num","blockInputOverrides":true,"outputProperties":[{"property":"entity","propertyType":"msg","value":"$entity().attributes.temperature","valueType":"jsonata"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1320,"y":880,"wires":[["ac9650c2d9ef9f90"]]},{"id":"3f5e6b27fb189d0b","type":"api-current-state","z":"20f73031b9c7424c","name":"Welche Temperatur ist eingestellt?","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_buro_garten_heizung","state_type":"num","blockInputOverrides":true,"outputProperties":[{"property":"entity","propertyType":"msg","value":"$entity().attributes.temperature","valueType":"jsonata"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1320,"y":1660,"wires":[["bd083867b37e3e6d"]]},{"id":"37b8d3c69271b6c1","type":"api-current-state","z":"20f73031b9c7424c","name":"Fenster zu?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.tur_fenster_kontakt_buro","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1570,"y":820,"wires":[["d0a657015eaca9bc"],["1a7e9e3fa11cac61"]]},{"id":"05ed41d1e95d66ae","type":"api-current-state","z":"20f73031b9c7424c","name":"Fenster zu?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.tur_fenster_kontakt_buro","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"5","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1570,"y":1600,"wires":[["1004b583a5e51a92"],["f50a35a2e1e61ebb"]]},{"id":"f50a35a2e1e61ebb","type":"api-call-service","z":"20f73031b9c7424c","name":"Temperatur auf 5Grad schalten","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.thermostat_buro_garten_heizung"],"labelId":[],"data":"{\"temperature\":5}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"climate","service":"set_temperature","x":1870,"y":1620,"wires":[[]]},{"id":"1a7e9e3fa11cac61","type":"api-call-service","z":"20f73031b9c7424c","name":"Temperatur auf 5Grad schalten","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.thermostat_buro_strasse_heizung"],"labelId":[],"data":"{\"temperature\":5}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"climate","service":"set_temperature","x":1870,"y":840,"wires":[[]]},{"id":"51e920fc673caa96","type":"switch","z":"20f73031b9c7424c","name":"Vergleich Soll zu Ist Temp.","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"msg.entity + 0.5","vt":"jsonata"},{"t":"lt","v":"msg.entity - 1","vt":"jsonata"}],"checkall":"true","repair":false,"outputs":2,"x":2080,"y":780,"wires":[["cfe49715e6d82dbe"],["d02841a9f9da661a"]]},{"id":"d0a657015eaca9bc","type":"api-current-state","z":"20f73031b9c7424c","name":"Raumtemperatur","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.temperatur_buro","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1830,"y":780,"wires":[["51e920fc673caa96"]]},{"id":"1004b583a5e51a92","type":"api-current-state","z":"20f73031b9c7424c","name":"Raumtemperatur","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.temperatur_buro","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1830,"y":1560,"wires":[["5ed684e0567cef29"]]},{"id":"cfe49715e6d82dbe","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist Steckdose aus?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.steckdose_buro_heizung_strasse","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2350,"y":740,"wires":[[],["75100163a417f463"]]},{"id":"75100163a417f463","type":"api-call-service","z":"20f73031b9c7424c","name":"Steckdose aus","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.steckdose_buro_heizung_strasse"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":2560,"y":740,"wires":[[]]},{"id":"9bc5a0800dd796ef","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist Steckdose aus?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.steckdose_buro_heizung_garten","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2350,"y":1520,"wires":[[],["e2a5bacbf1ee4aac"]]},{"id":"e2a5bacbf1ee4aac","type":"api-call-service","z":"20f73031b9c7424c","name":"Steckdose aus","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.steckdose_buro_heizung_garten"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":2560,"y":1520,"wires":[[]]},{"id":"d02841a9f9da661a","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist Steckdose aus?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.steckdose_buro_heizung_strasse","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2350,"y":800,"wires":[["ef638972b40436ff"],[]]},{"id":"ef638972b40436ff","type":"api-call-service","z":"20f73031b9c7424c","name":"Steckdose an","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.steckdose_buro_heizung_strasse"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_on","x":2560,"y":800,"wires":[[]]},{"id":"5c15d7cc07fc2382","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist Steckdose aus?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.steckdose_buro_heizung_garten","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2350,"y":1580,"wires":[["356b7e7674105dbe"],[]]},{"id":"356b7e7674105dbe","type":"api-call-service","z":"20f73031b9c7424c","name":"Steckdose an","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.steckdose_buro_heizung_garten"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_on","x":2560,"y":1580,"wires":[[]]},{"id":"fc87bf49b31defe8","type":"api-current-state","z":"20f73031b9c7424c","name":"Welche Temperatur ist draußen?","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.temp_luftfeuchte_sensor_balkon_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1330,"y":640,"wires":[["f19b4ecb633cda5b"]]},{"id":"f19b4ecb633cda5b","type":"switch","z":"20f73031b9c7424c","name":"<=15 / >=17","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"15","vt":"num"},{"t":"gte","v":"17","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":1570,"y":640,"wires":[["644e0b818af170b0"],["92b0c95b459f1068"]]},{"id":"ecabe1d07afd10be","type":"api-current-state","z":"20f73031b9c7424c","name":"Welche Temperatur ist draußen?","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.temp_luftfeuchte_sensor_balkon_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1330,"y":1420,"wires":[["cb21a73405a83198"]]},{"id":"cb21a73405a83198","type":"switch","z":"20f73031b9c7424c","name":"<=15 / >=17","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"15","vt":"num"},{"t":"gte","v":"17","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":1570,"y":1420,"wires":[["3d8d784862e0cd85"],["8e1b03dc63c81c91"]]},{"id":"87bc66ddd0f3b201","type":"api-call-service","z":"20f73031b9c7424c","name":"Temperatur auf 5Grad schalten","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.thermostat_buro_strasse_heizung"],"labelId":[],"data":"{\"temperature\":5}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"climate","service":"set_temperature","x":2030,"y":640,"wires":[["cfe49715e6d82dbe"]]},{"id":"32d06c6b038ed8fe","type":"api-call-service","z":"20f73031b9c7424c","name":"Temperatur auf 5Grad schalten","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.thermostat_buro_garten_heizung"],"labelId":[],"data":"{\"temperature\":5}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"climate","service":"set_temperature","x":2030,"y":1420,"wires":[["9bc5a0800dd796ef"]]},{"id":"644e0b818af170b0","type":"api-current-state","z":"20f73031b9c7424c","name":"Fenster zu?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.tur_fenster_kontakt_buro","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1770,"y":560,"wires":[["d004c1e2ad9b6da6"],["87bc66ddd0f3b201"]]},{"id":"d004c1e2ad9b6da6","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist jemand zu Hause?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.schalter_helfer_fur_automation_ist_jemand_zu_hause","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2060,"y":560,"wires":[["a089522bfa3331e6"],["c7ac544a70733334"]]},{"id":"3d8d784862e0cd85","type":"api-current-state","z":"20f73031b9c7424c","name":"Fenster zu?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.tur_fenster_kontakt_buro","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"5","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1770,"y":1340,"wires":[["1458d3897f9a1fd4"],["32d06c6b038ed8fe"]]},{"id":"1458d3897f9a1fd4","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist jemand zu Hause?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.schalter_helfer_fur_automation_ist_jemand_zu_hause","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2060,"y":1340,"wires":[["c99adadc7d07e0e6"],["39ab0788513a2868"]]},{"id":"c7ac544a70733334","type":"ha-number","z":"20f73031b9c7424c","name":"Absenk-Temp.","version":1,"debugenabled":false,"inputs":1,"outputs":1,"entityConfig":"4948f1601c526e53","exposeAsEntityConfig":"","mode":"get","value":"payload","valueType":"msg","outputProperties":[{"property":"temperature","propertyType":"msg","value":"","valueType":"value"},{"property":"previousValue","propertyType":"msg","value":"","valueType":"previousValue"}],"x":2350,"y":560,"wires":[["933522594acb1f8b","2580fbc2c8b064e1"]]},{"id":"20aa880794677d7c","type":"api-call-service","z":"20f73031b9c7424c","name":"Setze Temperatur","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.thermostat_buro_strasse_heizung"],"labelId":[],"data":"{\"temperature\": \"{{temperature}}\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","blockInputOverrides":true,"domain":"climate","service":"set_temperature","x":3150,"y":560,"wires":[["2088f74aa1eaa2f3"]]},{"id":"2088f74aa1eaa2f3","type":"api-current-state","z":"20f73031b9c7424c","name":"Raumtemperatur","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.temperatur_buro","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3350,"y":560,"wires":[["f8806ff649389bae"]]},{"id":"e942130b80ed754c","type":"api-current-state","z":"20f73031b9c7424c","name":"Montag und Freitag","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.montag_und_freitag","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2370,"y":260,"wires":[["d531d8b4379fb502"],[]]},{"id":"d5c932806c3b309c","type":"api-current-state","z":"20f73031b9c7424c","name":"Dienstag bis Donnerstag","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.dienstag_bis_donnerstag","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2390,"y":340,"wires":[["3c93c98f6239a20c"],[]]},{"id":"5d8a1762b9095ba1","type":"api-current-state","z":"20f73031b9c7424c","name":"Samstag bis Sonntag und Feiertage","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.samstag_und_sonntag","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2420,"y":420,"wires":[["7124754a40744e77"],[]]},{"id":"d531d8b4379fb502","type":"time-range-switch","z":"20f73031b9c7424c","name":"07:30 bis 21:00 Uhr","lat":"51.5681229","lon":"7.233671559138333","startTime":"07:30","endTime":"21:00","startOffset":0,"endOffset":0,"x":2690,"y":260,"wires":[["92d83f023b0e4e56"],["4e10be976196575d"]]},{"id":"4e10be976196575d","type":"time-range-switch","z":"20f73031b9c7424c","name":"07:30 bis 21:00 Uhr","lat":"51.5681229","lon":"7.233671559138333","startTime":"07:30","endTime":"21:00","startOffset":0,"endOffset":0,"x":2910,"y":260,"wires":[["92d83f023b0e4e56"],["d9601e77e25ba561"]]},{"id":"3c93c98f6239a20c","type":"time-range-switch","z":"20f73031b9c7424c","name":"15:00 bis 21:00 Uhr","lat":"51.5681229","lon":"7.233671559138333","startTime":"15:00","endTime":"21:00","startOffset":0,"endOffset":0,"x":2690,"y":340,"wires":[["92d83f023b0e4e56"],["2c3d73bcdf558a95"]]},{"id":"2c3d73bcdf558a95","type":"time-range-switch","z":"20f73031b9c7424c","name":"15:00 bis 21:00 Uhr","lat":"51.5681229","lon":"7.233671559138333","startTime":"15:00","endTime":"21:00","startOffset":0,"endOffset":0,"x":2910,"y":340,"wires":[["92d83f023b0e4e56"],["d9601e77e25ba561"]]},{"id":"7124754a40744e77","type":"time-range-switch","z":"20f73031b9c7424c","name":"08:00 bis 22:00 Uhr","lat":"51.5681229","lon":"7.233671559138333","startTime":"08:00","endTime":"22:00","startOffset":0,"endOffset":0,"x":2690,"y":420,"wires":[["92d83f023b0e4e56"],["2c99fcbcb644935e"]]},{"id":"2c99fcbcb644935e","type":"time-range-switch","z":"20f73031b9c7424c","name":"08:00 bis 22:00 Uhr","lat":"51.5681229","lon":"7.233671559138333","startTime":"08:00","endTime":"22:00","startOffset":0,"endOffset":0,"x":2910,"y":420,"wires":[["92d83f023b0e4e56"],["d9601e77e25ba561"]]},{"id":"f4b033fe4ec4973d","type":"ha-number","z":"20f73031b9c7424c","name":"Normal-Temp.","version":1,"debugenabled":false,"inputs":1,"outputs":1,"entityConfig":"215dcff2eeacf9cb","exposeAsEntityConfig":"","mode":"get","value":"payload","valueType":"msg","outputProperties":[{"property":"temperature","propertyType":"msg","value":"","valueType":"value"},{"property":"previousValue","propertyType":"msg","value":"","valueType":"previousValue"}],"x":3210,"y":340,"wires":[["0b68fc2d9d77445b","0ae2d121dd994fc6"]]},{"id":"0ae2d121dd994fc6","type":"api-call-service","z":"20f73031b9c7424c","name":"Setze Temperatur","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.thermostat_buro_strasse_heizung"],"labelId":[],"data":"{\"temperature\": \"{{temperature}}\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","blockInputOverrides":true,"domain":"climate","service":"set_temperature","x":4010,"y":340,"wires":[["4a6be12a131c2050"]]},{"id":"4a6be12a131c2050","type":"api-current-state","z":"20f73031b9c7424c","name":"Raumtemperatur","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.temperatur_buro","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":4230,"y":340,"wires":[["cb1f9e49c748f4e5"]]},{"id":"cb1f9e49c748f4e5","type":"switch","z":"20f73031b9c7424c","name":"Vergleich Soll zu Ist Temp.","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"msg.temperature + 0.5","vt":"jsonata"},{"t":"lt","v":"msg.temperature - 1","vt":"jsonata"}],"checkall":"true","repair":false,"outputs":2,"x":4480,"y":340,"wires":[["e7766c99fc880db7"],["6625f48485fd4fcb"]]},{"id":"753ea3a6f27e3f1f","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist Steckdose aus?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.steckdose_buro_heizung_strasse","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3870,"y":520,"wires":[[],["bf6d73a2f94035b6"]]},{"id":"bf6d73a2f94035b6","type":"api-call-service","z":"20f73031b9c7424c","name":"Steckdose aus","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.steckdose_buro_heizung_strasse"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":4080,"y":520,"wires":[[]]},{"id":"0b5549de011a1f8d","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist Steckdose aus?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.steckdose_buro_heizung_strasse","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3870,"y":580,"wires":[["798e8e3a7f4e3693"],[]]},{"id":"798e8e3a7f4e3693","type":"api-call-service","z":"20f73031b9c7424c","name":"Steckdose an","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.steckdose_buro_heizung_strasse"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_on","x":4080,"y":580,"wires":[[]]},{"id":"e7766c99fc880db7","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist Steckdose aus?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.steckdose_buro_heizung_strasse","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":4750,"y":300,"wires":[[],["280e7fa30d39a858"]]},{"id":"280e7fa30d39a858","type":"api-call-service","z":"20f73031b9c7424c","name":"Steckdose aus","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.steckdose_buro_heizung_strasse"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":4960,"y":300,"wires":[[]]},{"id":"6625f48485fd4fcb","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist Steckdose aus?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.steckdose_buro_heizung_strasse","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":4750,"y":360,"wires":[["0aa4fcaf78d78d02"],[]]},{"id":"0aa4fcaf78d78d02","type":"api-call-service","z":"20f73031b9c7424c","name":"Steckdose an","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.steckdose_buro_heizung_strasse"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_on","x":4960,"y":360,"wires":[[]]},{"id":"e3a933e85c1e002b","type":"switch","z":"20f73031b9c7424c","name":"Temp. schon gesetzt?","property":"temperature","propertyType":"msg","rules":[{"t":"neq","v":"payload","vt":"msg"}],"checkall":"true","repair":false,"outputs":1,"x":3780,"y":340,"wires":[[]]},{"id":"1ffc6d364ed514e7","type":"api-current-state","z":"20f73031b9c7424c","name":"Welche Temperatur ist eingestellt?","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_buro_strasse_heizung","state_type":"num","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"$entity().attributes.temperature","valueType":"jsonata"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3500,"y":340,"wires":[["e3a933e85c1e002b"]]},{"id":"70998460ca60fc09","type":"switch","z":"20f73031b9c7424c","name":"Temp. schon gesetzt?","property":"temperature","propertyType":"msg","rules":[{"t":"neq","v":"payload","vt":"msg"}],"checkall":"true","repair":false,"outputs":1,"x":2920,"y":560,"wires":[["20aa880794677d7c"]]},{"id":"2580fbc2c8b064e1","type":"api-current-state","z":"20f73031b9c7424c","name":"Welche Temperatur ist eingestellt?","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_buro_strasse_heizung","state_type":"num","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"$entity().attributes.temperature","valueType":"jsonata"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2640,"y":560,"wires":[["70998460ca60fc09"]]},{"id":"5c0feb2943e3b7f8","type":"server-state-changed","z":"20f73031b9c7424c","name":"Fenster wurde geschlossen","server":"4c1c95c5.da8acc","version":6,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["binary_sensor.tur_fenster_kontakt_buro"],"substring":[],"regex":[]},"outputInitially":false,"stateType":"str","ifState":"off","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":620,"y":1160,"wires":[["f86501f378ddc2a6"],[]]},{"id":"81627ec614406c09","type":"api-call-service","z":"20f73031b9c7424c","name":"Setze Modus","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.thermostat_buro_strasse_heizung"],"labelId":[],"data":"{\"hvac_mode\": \"{{flow.modus_heizung_büro_straße}}\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","blockInputOverrides":true,"domain":"climate","service":"set_hvac_mode","x":890,"y":1140,"wires":[["173b6e44c5be1c26"]]},{"id":"1b3cfb48731bb2d6","type":"api-call-service","z":"20f73031b9c7424c","name":"Setze Modus","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.thermostat_buro_garten_heizung"],"labelId":[],"data":"{\"hvac_mode\": \"{{flow.modus_heizung_büro_garten}}\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","blockInputOverrides":true,"domain":"climate","service":"set_hvac_mode","x":890,"y":1200,"wires":[["de389544c6ab782e"]]},{"id":"173b6e44c5be1c26","type":"api-current-state","z":"20f73031b9c7424c","name":"Welche Modus ist eingestellt?","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_buro_strasse_heizung","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1130,"y":1140,"wires":[["706cda6a48cf8378"]]},{"id":"de389544c6ab782e","type":"api-current-state","z":"20f73031b9c7424c","name":"Welche Modus ist eingestellt?","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_buro_strasse_heizung","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1130,"y":1200,"wires":[["219cd7e4e3b8ca9f"]]},{"id":"706cda6a48cf8378","type":"switch","z":"20f73031b9c7424c","name":"heat?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"heat","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1350,"y":1140,"wires":[["be01f14316287dcd"]]},{"id":"219cd7e4e3b8ca9f","type":"switch","z":"20f73031b9c7424c","name":"heat?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"heat","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1350,"y":1200,"wires":[["511916a47b8c9c36"]]},{"id":"6139746d198af2a9","type":"api-call-service","z":"20f73031b9c7424c","name":"Setze Temperatur","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.thermostat_buro_strasse_heizung"],"labelId":[],"data":"{\"temperature\": \"{{flow.temperatur_heizung_büro_straße}}\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","blockInputOverrides":true,"domain":"climate","service":"set_temperature","x":1730,"y":1140,"wires":[[]]},{"id":"4030adbcb92919e6","type":"api-call-service","z":"20f73031b9c7424c","name":"Setze Temperatur","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.thermostat_buro_strasse_heizung"],"labelId":[],"data":"{\"temperature\": \"{{flow.temperatur_heizung_büro_garten}}\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","blockInputOverrides":true,"domain":"climate","service":"set_temperature","x":1730,"y":1200,"wires":[[]]},{"id":"bc78912fb9c0a1ef","type":"server-state-changed","z":"20f73031b9c7424c","name":"Fenster wurde geöffnet","server":"4c1c95c5.da8acc","version":6,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["binary_sensor.tur_fenster_kontakt_buro"],"substring":[],"regex":[]},"outputInitially":false,"stateType":"str","ifState":"on","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1500,"y":700,"wires":[["92b0c95b459f1068","6358d08bc1d03caa"],[]]},{"id":"b0b40792d3629640","type":"server-state-changed","z":"20f73031b9c7424c","name":"Fenster wurde geöffnet","server":"4c1c95c5.da8acc","version":6,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["binary_sensor.tur_fenster_kontakt_buro"],"substring":[],"regex":[]},"outputInitially":false,"stateType":"str","ifState":"on","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1500,"y":1480,"wires":[["8e1b03dc63c81c91","7220305e55de0e42"],[]]},{"id":"6358d08bc1d03caa","type":"api-current-state","z":"20f73031b9c7424c","name":"Welche Temperatur ist eingestellt?","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_buro_strasse_heizung","state_type":"num","blockInputOverrides":true,"outputProperties":[{"property":"entity","propertyType":"msg","value":"$entity().attributes.temperature","valueType":"jsonata"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1820,"y":700,"wires":[["532f1e8fd4df79b8"]]},{"id":"532f1e8fd4df79b8","type":"change","z":"20f73031b9c7424c","name":"Setze Temperatur","rules":[{"t":"set","p":"temperatur_heizung_büro_straße","pt":"flow","to":"entity","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":2070,"y":700,"wires":[[]]},{"id":"be01f14316287dcd","type":"delay","z":"20f73031b9c7424c","name":"","pauseType":"delay","timeout":"20","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1530,"y":1140,"wires":[["6139746d198af2a9"]]},{"id":"511916a47b8c9c36","type":"delay","z":"20f73031b9c7424c","name":"","pauseType":"delay","timeout":"20","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1530,"y":1200,"wires":[["4030adbcb92919e6"]]},{"id":"7220305e55de0e42","type":"api-current-state","z":"20f73031b9c7424c","name":"Welche Temperatur ist eingestellt?","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_buro_garten_heizung","state_type":"num","blockInputOverrides":true,"outputProperties":[{"property":"entity","propertyType":"msg","value":"$entity().attributes.temperature","valueType":"jsonata"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1820,"y":1480,"wires":[["addaae2f83c0a0e3"]]},{"id":"addaae2f83c0a0e3","type":"change","z":"20f73031b9c7424c","name":"Setze Temperatur","rules":[{"t":"set","p":"temperatur_heizung_büro_garten","pt":"flow","to":"entity","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":2070,"y":1480,"wires":[[]]},{"id":"39ab0788513a2868","type":"ha-number","z":"20f73031b9c7424c","name":"Absenk-Temp.","version":1,"debugenabled":false,"inputs":1,"outputs":1,"entityConfig":"4948f1601c526e53","exposeAsEntityConfig":"","mode":"get","value":"payload","valueType":"msg","outputProperties":[{"property":"temperature","propertyType":"msg","value":"","valueType":"value"},{"property":"previousValue","propertyType":"msg","value":"","valueType":"previousValue"}],"x":2350,"y":1340,"wires":[["9ef6c44af80ea7d9","1ef8b95e849ec5aa"]]},{"id":"188ad5b682a2e6c3","type":"api-call-service","z":"20f73031b9c7424c","name":"Setze Temperatur","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.thermostat_buro_garten_heizung"],"labelId":[],"data":"{\"temperature\": \"{{temperature}}\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","blockInputOverrides":true,"domain":"climate","service":"set_temperature","x":3150,"y":1340,"wires":[["bafe09d0503b2290"]]},{"id":"bafe09d0503b2290","type":"api-current-state","z":"20f73031b9c7424c","name":"Raumtemperatur","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.temperatur_buro","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3350,"y":1340,"wires":[["fa693a4b548eaaf5"]]},{"id":"881f041f857e1f4a","type":"api-current-state","z":"20f73031b9c7424c","name":"Montag und Freitag","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.montag_und_freitag","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2370,"y":1040,"wires":[["2c1101bc2c6cd5b5"],[]]},{"id":"99fc05b3a4496073","type":"api-current-state","z":"20f73031b9c7424c","name":"Dienstag bis Donnerstag","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.dienstag_bis_donnerstag","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2390,"y":1120,"wires":[["fd88c4078d5f4b61"],[]]},{"id":"8b61b660752549f8","type":"api-current-state","z":"20f73031b9c7424c","name":"Samstag bis Sonntag und Feiertage","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.samstag_und_sonntag","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2420,"y":1200,"wires":[["4ce76b0d64f81638"],[]]},{"id":"2c1101bc2c6cd5b5","type":"time-range-switch","z":"20f73031b9c7424c","name":"07:30 bis 21:00 Uhr","lat":"51.5681229","lon":"7.233671559138333","startTime":"07:30","endTime":"21:00","startOffset":0,"endOffset":0,"x":2690,"y":1040,"wires":[["8c93a98e30692ecf"],["6272a8bf999bc824"]]},{"id":"6272a8bf999bc824","type":"time-range-switch","z":"20f73031b9c7424c","name":"07:30 bis 21:00 Uhr","lat":"51.5681229","lon":"7.233671559138333","startTime":"07:30","endTime":"21:00","startOffset":0,"endOffset":0,"x":2910,"y":1040,"wires":[["8c93a98e30692ecf"],["c225a2ac778de22b"]]},{"id":"fd88c4078d5f4b61","type":"time-range-switch","z":"20f73031b9c7424c","name":"15:00 bis 21:00 Uhr","lat":"51.5681229","lon":"7.233671559138333","startTime":"15:00","endTime":"21:00","startOffset":0,"endOffset":0,"x":2690,"y":1120,"wires":[["8c93a98e30692ecf"],["824473c278756d2e"]]},{"id":"824473c278756d2e","type":"time-range-switch","z":"20f73031b9c7424c","name":"15:00 bis 21:00 Uhr","lat":"51.5681229","lon":"7.233671559138333","startTime":"15:00","endTime":"21:00","startOffset":0,"endOffset":0,"x":2910,"y":1120,"wires":[["8c93a98e30692ecf"],["c225a2ac778de22b"]]},{"id":"4ce76b0d64f81638","type":"time-range-switch","z":"20f73031b9c7424c","name":"08:00 bis 22:00 Uhr","lat":"51.5681229","lon":"7.233671559138333","startTime":"08:00","endTime":"22:00","startOffset":0,"endOffset":0,"x":2690,"y":1200,"wires":[["8c93a98e30692ecf"],["493caf0d539d8b66"]]},{"id":"493caf0d539d8b66","type":"time-range-switch","z":"20f73031b9c7424c","name":"08:00 bis 22:00 Uhr","lat":"51.5681229","lon":"7.233671559138333","startTime":"08:00","endTime":"22:00","startOffset":0,"endOffset":0,"x":2910,"y":1200,"wires":[["8c93a98e30692ecf"],["c225a2ac778de22b"]]},{"id":"d8343d5d4eb41d47","type":"ha-number","z":"20f73031b9c7424c","name":"Normal-Temp.","version":1,"debugenabled":false,"inputs":1,"outputs":1,"entityConfig":"215dcff2eeacf9cb","exposeAsEntityConfig":"","mode":"get","value":"payload","valueType":"msg","outputProperties":[{"property":"temperature","propertyType":"msg","value":"","valueType":"value"},{"property":"previousValue","propertyType":"msg","value":"","valueType":"previousValue"}],"x":3210,"y":1120,"wires":[["59d0edd62c4a32c2","4dd239abbfc10284"]]},{"id":"59d0edd62c4a32c2","type":"api-call-service","z":"20f73031b9c7424c","name":"Setze Temperatur","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.thermostat_buro_garten_heizung"],"labelId":[],"data":"{\"temperature\": \"{{temperature}}\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","blockInputOverrides":true,"domain":"climate","service":"set_temperature","x":4010,"y":1120,"wires":[["e05158eac3e72609"]]},{"id":"e05158eac3e72609","type":"api-current-state","z":"20f73031b9c7424c","name":"Raumtemperatur","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.temperatur_buro","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":4230,"y":1120,"wires":[["6b9eb66d3c86029c"]]},{"id":"bab63e787ed71921","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist Steckdose aus?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.steckdose_buro_heizung_garten","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3870,"y":1300,"wires":[[],["1f9d35c74421fc06"]]},{"id":"1f9d35c74421fc06","type":"api-call-service","z":"20f73031b9c7424c","name":"Steckdose aus","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.steckdose_buro_heizung_garten"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":4080,"y":1300,"wires":[[]]},{"id":"4cfd47b5561e131b","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist Steckdose aus?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.steckdose_buro_heizung_garten","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3870,"y":1360,"wires":[["b5d53fdadf5707c6"],[]]},{"id":"b5d53fdadf5707c6","type":"api-call-service","z":"20f73031b9c7424c","name":"Steckdose an","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.steckdose_buro_heizung_garten"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_on","x":4080,"y":1360,"wires":[[]]},{"id":"ce38419713de3484","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist Steckdose aus?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.steckdose_buro_heizung_garten","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":4750,"y":1080,"wires":[[],["7a0ad575073a9bd7"]]},{"id":"7a0ad575073a9bd7","type":"api-call-service","z":"20f73031b9c7424c","name":"Steckdose aus","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.steckdose_buro_heizung_garten"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":4960,"y":1080,"wires":[[]]},{"id":"451a4703d86046db","type":"api-current-state","z":"20f73031b9c7424c","name":"Ist Steckdose aus?","server":"4c1c95c5.da8acc","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.steckdose_buro_heizung_garten","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":4750,"y":1140,"wires":[["8fee15658e083656"],[]]},{"id":"8fee15658e083656","type":"api-call-service","z":"20f73031b9c7424c","name":"Steckdose an","server":"4c1c95c5.da8acc","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.steckdose_buro_heizung_garten"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_on","x":4960,"y":1140,"wires":[[]]},{"id":"a9d5d439c0568412","type":"switch","z":"20f73031b9c7424c","name":"Temp. schon gesetzt?","property":"temperature","propertyType":"msg","rules":[{"t":"neq","v":"payload","vt":"msg"}],"checkall":"true","repair":false,"outputs":1,"x":3780,"y":1120,"wires":[[]]},{"id":"a574919df77b72cf","type":"api-current-state","z":"20f73031b9c7424c","name":"Welche Temperatur ist eingestellt?","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_buro_garten_heizung","state_type":"num","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"$entity().attributes.temperature","valueType":"jsonata"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3500,"y":1120,"wires":[["a9d5d439c0568412"]]},{"id":"4f8ddc2688117552","type":"switch","z":"20f73031b9c7424c","name":"Temp. schon gesetzt?","property":"temperature","propertyType":"msg","rules":[{"t":"neq","v":"payload","vt":"msg"}],"checkall":"true","repair":false,"outputs":1,"x":2920,"y":1340,"wires":[["188ad5b682a2e6c3"]]},{"id":"1ef8b95e849ec5aa","type":"api-current-state","z":"20f73031b9c7424c","name":"Welche Temperatur ist eingestellt?","server":"4c1c95c5.da8acc","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_buro_garten_heizung","state_type":"num","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"$entity().attributes.temperature","valueType":"jsonata"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2640,"y":1340,"wires":[["4f8ddc2688117552"]]},{"id":"5867f71552841be1","type":"comment","z":"20f73031b9c7424c","name":"Büro","info":"","x":250,"y":180,"wires":[]},{"id":"6b9eb66d3c86029c","type":"switch","z":"20f73031b9c7424c","name":"Vergleich Soll zu Ist Temp.","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"msg.temperature + 0.5","vt":"jsonata"},{"t":"lt","v":"msg.temperature - 1","vt":"jsonata"}],"checkall":"true","repair":false,"outputs":2,"x":4500,"y":1120,"wires":[["ce38419713de3484"],["451a4703d86046db"]]},{"id":"fa693a4b548eaaf5","type":"switch","z":"20f73031b9c7424c","name":"Vergleich Soll zu Ist Temp.","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"msg.temperature + 0.5","vt":"jsonata"},{"t":"lt","v":"msg.temperature - 1","vt":"jsonata"}],"checkall":"true","repair":false,"outputs":2,"x":3600,"y":1340,"wires":[["bab63e787ed71921"],["4cfd47b5561e131b"]]},{"id":"f8806ff649389bae","type":"switch","z":"20f73031b9c7424c","name":"Vergleich Soll zu Ist Temp.","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"msg.temperature + 0.5","vt":"jsonata"},{"t":"lt","v":"msg.temperature - 1","vt":"jsonata"}],"checkall":"true","repair":false,"outputs":2,"x":3600,"y":560,"wires":[["753ea3a6f27e3f1f"],["0b5549de011a1f8d"]]},{"id":"5ed684e0567cef29","type":"switch","z":"20f73031b9c7424c","name":"Vergleich Soll zu Ist Temp.","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"msg.entity + 0.5","vt":"jsonata"},{"t":"lt","v":"msg.entity - 1","vt":"jsonata"}],"checkall":"true","repair":false,"outputs":2,"x":2080,"y":1560,"wires":[["9bc5a0800dd796ef"],["5c15d7cc07fc2382"]]},{"id":"ac9650c2d9ef9f90","type":"junction","z":"20f73031b9c7424c","x":1460,"y":820,"wires":[["37b8d3c69271b6c1","4faec99506d7a839"]]},{"id":"bd083867b37e3e6d","type":"junction","z":"20f73031b9c7424c","x":1460,"y":1600,"wires":[["05ed41d1e95d66ae","f3e8ab9fe08e5beb"]]},{"id":"4faec99506d7a839","type":"junction","z":"20f73031b9c7424c","x":1480,"y":740,"wires":[["632cbe0637e60f0e"]]},{"id":"632cbe0637e60f0e","type":"junction","z":"20f73031b9c7424c","x":1920,"y":740,"wires":[["51e920fc673caa96"]]},{"id":"f3e8ab9fe08e5beb","type":"junction","z":"20f73031b9c7424c","x":1480,"y":1520,"wires":[["dd30e6bbcd61836d"]]},{"id":"dd30e6bbcd61836d","type":"junction","z":"20f73031b9c7424c","x":1920,"y":1520,"wires":[["5ed684e0567cef29"]]},{"id":"df4111c0b4702611","type":"junction","z":"20f73031b9c7424c","x":400,"y":1260,"wires":[["56bb969a3394a023","1c1dd056d8e67b51"]]},{"id":"ad793eece66c9032","type":"junction","z":"20f73031b9c7424c","x":720,"y":1640,"wires":[["429e22095adc3ffd","258c6a87fe10d256"]]},{"id":"2ed2cbdb920e9291","type":"junction","z":"20f73031b9c7424c","x":720,"y":920,"wires":[["4b9198d6ae4fdac7","327e1dd83ea25522"]]},{"id":"933522594acb1f8b","type":"junction","z":"20f73031b9c7424c","x":2480,"y":520,"wires":[["975db69fe1e6128d"]]},{"id":"975db69fe1e6128d","type":"junction","z":"20f73031b9c7424c","x":3440,"y":520,"wires":[["f8806ff649389bae"]]},{"id":"a089522bfa3331e6","type":"junction","z":"20f73031b9c7424c","x":2220,"y":340,"wires":[["e942130b80ed754c","d5c932806c3b309c","5d8a1762b9095ba1"]]},{"id":"92d83f023b0e4e56","type":"junction","z":"20f73031b9c7424c","x":3100,"y":340,"wires":[["f4b033fe4ec4973d"]]},{"id":"d9601e77e25ba561","type":"junction","z":"20f73031b9c7424c","x":3060,"y":460,"wires":[["44b8b90154a0e97b"]]},{"id":"44b8b90154a0e97b","type":"junction","z":"20f73031b9c7424c","x":2240,"y":520,"wires":[["c7ac544a70733334"]]},{"id":"b8c5caa7a5754d58","type":"junction","z":"20f73031b9c7424c","x":4320,"y":300,"wires":[["cb1f9e49c748f4e5"]]},{"id":"0b68fc2d9d77445b","type":"junction","z":"20f73031b9c7424c","x":3340,"y":300,"wires":[["ac94a856bd19be6f"]]},{"id":"f86501f378ddc2a6","type":"junction","z":"20f73031b9c7424c","x":780,"y":1160,"wires":[["81627ec614406c09","1b3cfb48731bb2d6"]]},{"id":"92b0c95b459f1068","type":"junction","z":"20f73031b9c7424c","x":1700,"y":640,"wires":[["87bc66ddd0f3b201"]]},{"id":"8e1b03dc63c81c91","type":"junction","z":"20f73031b9c7424c","x":1700,"y":1420,"wires":[["32d06c6b038ed8fe"]]},{"id":"9ef6c44af80ea7d9","type":"junction","z":"20f73031b9c7424c","x":2480,"y":1300,"wires":[["7f51d92cea6be69a"]]},{"id":"7f51d92cea6be69a","type":"junction","z":"20f73031b9c7424c","x":3440,"y":1300,"wires":[["fa693a4b548eaaf5"]]},{"id":"c99adadc7d07e0e6","type":"junction","z":"20f73031b9c7424c","x":2220,"y":1120,"wires":[["881f041f857e1f4a","99fc05b3a4496073","8b61b660752549f8"]]},{"id":"8c93a98e30692ecf","type":"junction","z":"20f73031b9c7424c","x":3100,"y":1120,"wires":[["d8343d5d4eb41d47"]]},{"id":"c225a2ac778de22b","type":"junction","z":"20f73031b9c7424c","x":3060,"y":1240,"wires":[["f443df312570766a"]]},{"id":"f443df312570766a","type":"junction","z":"20f73031b9c7424c","x":2240,"y":1300,"wires":[["39ab0788513a2868"]]},{"id":"5ca44053187ad992","type":"junction","z":"20f73031b9c7424c","x":4320,"y":1080,"wires":[["6b9eb66d3c86029c"]]},{"id":"4dd239abbfc10284","type":"junction","z":"20f73031b9c7424c","x":3340,"y":1080,"wires":[["5ca44053187ad992"]]},{"id":"ac94a856bd19be6f","type":"junction","z":"20f73031b9c7424c","x":3620,"y":300,"wires":[["b8c5caa7a5754d58"]]},{"id":"4c1c95c5.da8acc","type":"server","name":"Home Assistant","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":":","statusYear":"numeric","statusMonth":"numeric","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m:s","enableGlobalContextStore":false},{"id":"4948f1601c526e53","type":"ha-entity-config","server":"4c1c95c5.da8acc","deviceConfig":"2a6d5c0770745470","name":"NR Absenk-Temp. Büro","version":6,"entityType":"number","haConfig":[{"property":"name","value":"NR Absenk-Temp. Büro"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":"config"},{"property":"device_class","value":"temperature"},{"property":"unit_of_measurement","value":"°C"},{"property":"min_value","value":5},{"property":"max_value","value":30},{"property":"step_value","value":""},{"property":"mode","value":"auto"}],"resend":false,"debugEnabled":false},{"id":"215dcff2eeacf9cb","type":"ha-entity-config","server":"4c1c95c5.da8acc","deviceConfig":"2a6d5c0770745470","name":"NR Normal-Temp. Büro","version":6,"entityType":"number","haConfig":[{"property":"name","value":"NR Normal-Temp. Büro"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":"config"},{"property":"device_class","value":"temperature"},{"property":"unit_of_measurement","value":"°C"},{"property":"min_value","value":5},{"property":"max_value","value":30},{"property":"step_value","value":""},{"property":"mode","value":"auto"}],"resend":false,"debugEnabled":false},{"id":"2a6d5c0770745470","type":"ha-device-config","name":"Temperatureingabe","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""}]
