ich benötige Unterstützung, um den Fehler zu lösen, da hier keine Lösung finde.
Fehlermeldung:
Logger: homeassistant.components.template.template_entity
Source: components/template/template_entity.py:194
Integration: Template (documentation, issues)
First occurred: 13:50:51 (2 occurrences)
Last logged: 13:51:36
TemplateError(‘ValueError: Template error: float got invalid input ‘None’ when rendering template ‘{{ float(state_attr(‘sensor.growatt_totalgenerateenergy’, ‘OutputPower’)) }}’ but no default was specified’) while processing template ‘Template<template=({{ float(state_attr(‘sensor.growatt_totalgenerateenergy’, ‘OutputPower’)) }}) renders=4>’ for attribute ‘_attr_native_value’ in entity ‘sensor.growatt_inverter_ac_power’
Eintrag aus der Configuration.yaml
template:
- sensor:
name: "Growatt inverter AC Power"
unit_of_measurement: W
device_class: power
unique_id: "growatt_inverter"
state: "{{ float(state_attr('sensor.growatt_totalgenerateenergy', 'OutputPower')) }}"
Vorab vielen Dank für die Unterstützung.
hquer
