Was läuft das schief…mein FullBackup hätte 23,6 GB …zuviel für GoogleDrive
Im Recorder hätte ich viel ausgeschlossen:
include:
domains:
- sensor
- switch
- light
- automation
- climate
entities:
- sensor.solaredgemod_ac_energy_kwh
- sensor.bezugszaehler_cost
- sensor.solaredgemod_m1_imported_kwh
- sensor.solaredgemod_m1_exported_kwh
- sensor.solaredgemod_m1_imported_kwh_cost
- sensor.solaredgemod_m1_exported_kwh_compensation
- sensor.rounded_solardedgeproduktion2
# - sensor.bezugsanteil
entity_globs:
- sensor.*km
exclude:
domains:
- automation
- alert
- automation
- binary_sensor
- camera
- climate
- counter
- customizer
- device_tracker
- group
- input_boolean
- input_datetime
- input_number
- input_select
- input_text
- light
- media_player
- proximity
- scene
#- sensor
- script
- sun
- switch
- persistent_notification
- person
- remote
- timer
- updater
- variable
- weather
- zone
entity_globs:
- sensor.*_activity*
- sensor.*_ascended*
- sensor.*_average_active_pace*
- sensor.*_battery_state*
- sensor.*_bssid*
- sensor.*_connection_type*
- sensor.*_current
- sensor.*_current_consumption
- sensor.*_descended*
- sensor.*_distance*
- sensor.*_last_update_trigger*
- sensor.*_sim*
- sensor.*_ssid*
- sensor.*_steps*
- sensor.*_storage*
- sensor.*_voltage
- sensor.clock*
- sensor.date*
- sensor.glances*
- sensor.load_*m
- sensor.time*
- sensor.uptime*
- sensor.solaredgemod*
- sensor.netatmo*
- sensor.doorbird*
- sensor.ebusd*
- sensor.mqtt*
- sensor.rounded*
#- sensor.hausverbr*
- sensor.load*
#- sensor.ein*
#- sensor.bezug*
entities:
- sensor.last_boot
- sensor.home_assistant_v2_db
- sensor.memory_free
- sensor.memory_use
- sensor.memory_use_percent
- sensor.processor_use
- weather.openweathermap
event_types:
- service_removed
- service_executed
- platform_discovered
- homeassistant_start
- homeassistant_stop
- feedreader
- service_registered
- call_service
- component_loaded
- logbook_entry
- system_log_event
- automation_triggered
- script_started
- timer_out_of_sync
