Frigate Hass Cards - Livestream immer HD obwohl SD eingestellt
Kann mir einer sagen wieso die Livestreams über Frigate Hass-Cards trotz meinen Einstellungen weiterhin per mainstream (HD) übertragen werden und das Klicken auf HD Button keinen Unterschied macht?
type: custom:frigate-card
cameras:
  - camera_entity: camera.front
    live_provider: go2rtc
    dependencies:
      cameras:
        - front_sub
    title: Front HD
    hide: true
    frigate: {}
      occupancy: false
      motion: true
      entities:
        - binary_sensor.front_all_occupancy
view:
  default: live
  camera_select: live
  dark_mode: 'off'
  update_seconds: 5
  timeout_seconds: 10
  update_force: true
  scan:
    enabled: true
    untrigger_seconds: 10
menu:
  style: hidden
  buttons:
    substreams:
      icon: mdi:high-definition
live:
  preload: true
  auto_mute: all
  auto_pause: never
  auto_play: all
  lazy_load: false
  controls:
    next_previous: {}
  layout:
    fit: cover
  microphone:
    disconnect_seconds: 2
media_gallery:
  controls:
    thumbnails:
      show_details: true
media_viewer:
  auto_pause: hidden
  auto_mute: all
  auto_play: never
image:
  layout: {}
Frigate config:
mqtt:
  # Optional: Enable mqtt server (default: shown below)
  enabled: True
  # IP mqtt Broker von HA
  host: 192.168.***
  # Optional: port (default: shown below)
  port: 1883
  user: ***
  password: ***
database:
  path: /config/frigate.db
detectors:
#  coral:
#    type: edgetpu
#    device: usb
  cpu1:
    type: cpu
    num_threads: 3
  cpu2:
    type: cpu
    num_threads: 3
ffmpeg:
  hwaccel_args: preset-rpi-64-h264
go2rtc:
  streams:
    front:
      - rtsp://USER:PW@192.168.***:554/h264Preview_01_main # <- stream which supports video & aac audio.
      - "ffmpeg:front#audio=opus" # <- copy of the stream which transcodes audio to opus
    front_sub:
      - rtsp://USER:PW@192.168.***:554/h264Preview_01_sub # <- stream which supports video & aac audio.
      - "ffmpeg:front_sub#audio=opus" # <- copy of the stream which transcodes audio to opus
    hof:
      - rtsp://USER:PW@192.168.***:554/11 # <- stream which supports video & aac audio.
    hof_sub:
      - rtsp://USER:PW@192.168.***:554/12 # <- stream which supports video & aac audio.
# Kamera von Front
cameras:
  # Kameraname
  front:
    ffmpeg:
      output_args:
        record: preset-record-generic-audio-copy
      inputs:
        - path: rtsp://127.0.0.1:8554/front # RTSP Stream High Res
          input_args: preset-rtsp-restream
          roles:
            - record
        - path: rtsp://127.0.0.1:8554/front_sub # RTPS Stream Low Res
          roles:
            - detect
    detect:
      enabled: True # <---- disable detection until you have a working camera feed
      width: 640
      height: 360
    objects:
      track:
        - person
#      filters:
#        person:
#          threshold: 0.74
    snapshots:
      enabled: False
#      timestamp: True
#      bounding_box: True
      retain:
        default: 7
    record:
      enabled: False
      events:
        retain:
          default: 7
#    motion:
#      mask:
#        - 2024,238,1528,171,1330,189,1124,214,1081,342,751,336,748,379,379,385,0,407,0,192,0,0,837,0,2560,0,2560,157,2560,360
#        - 1194,1920,1041,1783,0,1791,0,1920
#      zones:
#        Bewegung Front:
#        coordinates: 0,1920,0,0,2560,0,2560,1920
    live:
      stream_name: front_sub
# Kamera vom Hof
  hof:                                                            #Kameraname
    ffmpeg:
      output_args:
      inputs:
        - path: rtsp://127.0.0.1:8554/hof    #RTSP Stream High Res
          roles:
            - record
        - path: rtsp://127.0.0.1:8554/hof_sub          #RTPS Stream Low Res
          roles:
            - detect
    detect:
      width: 640
      height: 352
    objects:
      track:
        - person
      filters:
        person:
          threshold: 0.74
    snapshots:
      enabled: False
#      timestamp: True
      retain:
        default: 7
    record:
      enabled: False
      events:
        retain:
          default: 7
#    motion:
#      mask:
#      zones:
#        Bewegung Hof:
    live:
      stream_name: hof_sub
# Optional: birdseye configuration
# NOTE: Can (enabled, mode) be overridden at the camera level
birdseye:
  # Optional: Enable birdseye view (default: True)
  enabled: False
  # Optional: Restream birdseye via RTSP (default: False)
  # NOTE: Enabling this will set birdseye to run 24/7 which may increase CPU usage somewhat.
  restream: False
  # Optional: Width of the output resolution (default: 1280)
  width: 1280
  # Optional: Height of the output resolution (default: 720)
  height: 720
  # Optional: Encoding quality of the mpeg1 feed (default: 8)
  # 1 is the highest quality, and 31 is the lowest. Lower quality feeds utilize less CPU resources.
  quality: 15
  # Optional: Mode of the view. Available options are: objects, motion, and continuous
  #   objects - cameras are included if they have had a tracked object within the last 30 seconds
  #   motion - cameras are included if motion was detected in the last 30 seconds
  #   continuous - all cameras are included always
  mode: continuous
# Optional
ui:
  # Optional: Set the default live mode for cameras in the UI (default: mse)
  live_mode: webrtc
  # Optional: Set a timezone to use in the UI (default: use browser local time)
  timezone: Europe/Berlin
  # Optional: Use an experimental recordings / camera view UI (default: false)
  use_experimental: False
  # Optional: Set the time format used.
  # Options are browser, 12hour, or 24hour (default: browser)
  time_format: 24hour
  # Optional: Set the date style for a specified length.
  # Options are: full, long, medium, short
  # Examples:
  #    short: 2/11/23
  #    medium: Feb 11, 2023
  #    full: Saturday, February 11, 2023
  # (default: short).
  date_style: full
  # Optional: Set the time style for a specified length.
  # Examples:
  #    short: 8:14 PM
  #    medium: 8:15:22 PM
  #    full: 8:15:22 PM Mountain Standard Time
  # (default: medium).
  time_style: medium
  # Optional: Ability to manually override the date / time styling to use strftime format
  # https://www.gnu.org/software/libc/manual/html_node/Formatting-Calendar-Time.html
  # possible values are shown above (default: not set)
  strftime_fmt: "%d/%m/%Y %H:%M"
Hat sich erledigt. Hab es hingekriegt.
Kannst du deine Lösung zeigen?
Beispiel mit einer Überwachungskamera.
title: FRIGATECARD
path: frigatecard
subview: false
type: sidebar
badges: []
cards:
  - type: vertical-stack
    cards:
      - type: custom:frigate-card
        cameras:
          - camera_entity: camera.cam1
            title: Cam1 SD
            frigate:
              camera_name: cam1_sub
              occupancy: false
              motion: true
              entities:
                - binary_sensor.cam1_all_occupancy
            dependencies:
              cameras:
                - cam1_sub
            webrtc_card: {}
            go2rtc:
              modes: []
            title: Cam1 HD
            hide: true
        menu:
          style: hidden
          buttons:
            substreams:
            expand:
              enabled: false
        view:
          default: live
          camera_select: live
          dark_mode: "off"
          update_seconds: 5
          timeout_seconds: 10
          update_force: true
          scan:
            enabled: true
        live:
          preload: true
          auto_mute: all
          auto_pause: never
          auto_play: all
          lazy_load: false
          controls:
            next_previous: {}
          layout:
            fit: fill
          microphone:
        media_gallery:
          controls:
            thumbnails:
              show_details: true
        media_viewer:
          auto_pause: hidden
          auto_mute: all
          auto_play: never
        image:
          layout: {}
    view_layout:
      position: main
  - square: false
    type: grid
    columns: 1
    cards:
      - type: picture
        image_entity: image.cam1_person
