meine ESP32CAM v.AI-Thinker funktioniert nicht und es kommen die Fehlermeldung:
[E][esp32_camera:123]: Setup Failed: ESP_ERR_NOT_FOUND
[E][component:082]: Component esp32_camera is marked FAILED
[E][esp32_camera_web_server:097]: Setup Failed
[E][component:082]: Component esp32_camera_web_server is marked FAILED
Obwohl der gleiche Code auf einer anderen Cam (gleiches Modell) seit längerem einwandfrei läuft.
Hat jemand eine Idee was ich ändern muss?
esphome:
friendly_name: TestESP32Cam
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxx"
ota:
- platform: esphome
password: "xxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Testesp32Cam Fallback Hotspot"
password: "xxx"
captive_portal:
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
resolution: 800x600
output:
- platform: gpio
pin: GPIO4
binary_sensor:
- platform: status
name: "ESP32Cam YT status"
sensor:
- platform: wifi_signal
name: "ESP32Cam YT WiFi Signal"
update_interval: 60s
light:
- platform: binary
output: gpio_4
- port: 8080
mode: stream
- port: 8081
mode: snapshot
